Question about GE WJSR2070B Top Load Washer
GE wjse4150b2ww wont fill with water etc below
It then stays on the wash cycle til completed then eventually shuts off, when i turn it back on it has the light on the wash cycle again, right where it left off. Where is the issue and how can i fix it?
  • Anonymous Jan 28, 2009
    Washer will not start. Has power and lid switch has been jumpered.
5 Suggested Answers
SOURCE: GE WASHER WON'T GO THROUGH THE DRAIN CYCLE AFTER WASH CYCLE
Most likley it's the drain pump! check the wiing and pump
Posted on Jul 09, 2008
  • 7 Answers
SOURCE: GE model # WJSE4150B2WW won't fill
Try washer on warm water. If you get one or the other.You need water valve. If you get none. You may need water level switch or the hose to the switch could be plugged.
Posted on May 05, 2009
  • 512 Answers
SOURCE: water will not shut off in washing machine
Check to load size selector switch, sounds like tube came off of it. The tube goes from switch to bottom of tube, tells machine what size load and when to turn off water.
Posted on Aug 18, 2009
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
Water wont go into the machine but the wash light comes on here a clink but dosent fill with water an start cycle help plz
IF YOU ARE SURE THE WATER SUPPLY IS ON. SHUT OFF WATER TO MACHINE AND REMOVE HOSES ON BACK OF MACHINE AND CK SCREEN ON VALVE THEY CAN BECOME PLUGED AND WILL BLOCK WATER FLOW. PUT THE HOSES IN A BUCKET AND TURN ON JUST TO BE SURE IT IS NOT ANOTHER PLUMBING PROBLEM.
Apr 21, 2014 | Indesit WA 115 Front Load Washer
GE WPRE8100 washer starts to fill and immediately shuts off
I would suspect the washer control panel or timer is the problem.
Jul 25, 2017 | GE Profile WPRE8100G
Slow leak under unit cannot find problem. what specific should i look for?
It is most likely a hose connection from the pump to drain. What you could do is fill up the washer with cold water and color the water with food coloring let the washer rn thru a cycle. on its completion of the wash cycle and after it drains do not let it fill back up. Turn the water supply taps off and til the washer over on its front. With a tissue,(white), find the spot arond the connections where the color has dripped from. Repair that conection and with the washer back uprite run thru a complete cycle to test for leaks as well to purge the color out of the system. You either must do the later or run like h--l if the wife gets that color on her clothes. lol
Sep 28, 2010 | Kenmore 23822 Top Load Washer
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Apr 03, 2009 | GE WJSR2070B Top Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
GE WJSR2070B Top Load Washer Logo
48 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
