Question about General Electric Ge Supra C3 Real Estate Realtor Key Lock Box Dial
Forgot the three letter combation to supra lock box
  • royhogate
    royhogate Jan 15, 2013
    I have an old supra alphabet lock box that I had screwed to my workshop and took it off four or five years ago and forgot the combination to it as it opens with a key which is inside the lock box just never thought I'd for get the three letter combination. thank you Roy
How to bypass pattern lock screen when you forgot the pattern
reset the whole machine to factory lose all apps
Jan 05, 2017 | Tablets & eReaders
Forgot my password
Some passwords are lost for good others can be reset. If it is a link you can login with your email address and lick on the drop down window box that says forgot password, they will email instructions how to reset. If you have locked your computer with a pass word and forgotten it you can work around it . Google ask leo .com. and join the news letter its free and you will find instructions there
Sep 21, 2014 | Tablets & eReaders
I have isuzu elf fire engine local mentinence department cut down the ecc box timer that's why i need electric diagram.
motor swap>?
Problem with 1993 Toyota Supra I have isuzu elf fire engine local mentinence department cut down the ecc box timer that's why i need electric diagram.
Jan 17, 2014 | 1993 Toyota Supra
We are a new business and have these key boxes but do not know the code. how can we reset?
see if the current combination is 0-0-0 as sent from the factory
once you find the combo use a pin or other to depress a button where you can choose another combo
or try here
http://www.ask.com/question/supra-lock-boxes
Oct 15, 2013 | General Electric Supra Max, Industrial Max...
I have a supra touch pad key lock but the code accidently got changed and no one can remember it how do we open it now
Well there are may ways,,, I cant really post them here as this is public and a lot of BAD people use the net too.
I once forgot my combination but I used this basically it will generate every possible combination for you, a 5 digit sequence will take about 20 minutes to go through..
Also I remember once a friend left for vacation. While he was out a clever Thief used battery acid to melt away the plastic coating and then used a chisel and hammer or something abound that thereof to break the rest open.
and as another friend told me, When all else fails a Huge Hammer works.
Please remember these locks are Advanced and you should call a locksmith as it will be wrong of us to tell you how to bypass.
Dec 28, 2012 | Supra 001004 Push Button Lock Box Key Safe
1987 toyota supra a/c clutch slipping & Locking Up
Sounds like an internal problem with the compressor being too hard to turn.
Aug 28, 2012 | 1987 Toyota Supra
I dont know the combination for a supra keysafe that is on a door of a property I have just purchased
Well, you MIGHT be stuck and out of luck, however there are some tricks you can try. Check out the blog on http://suprakey.org/ - they have several solutions for those that need to reset the combination of a Supra Key lockbox!
Good Luck!
May 23, 2012 | Supra 001004 Push Button Lock Box Key Safe
LOST CODE ON SUPRA C LOCKBOX
I have just moved into a house that has a supra combination code key safe mounted on a wall outside the back door , it was put there by the first owner who died ,the second owner never used it and don't know the code,I just thought it would be handy to use as we are going away in June to France and its away of leaving a key in case the alarm goes off while away so a neighbour could deactivate it or the police so they don't have to brake down the door or if I get locked out I could have that key for emergencies so is there a way I could find the code for the safe please?
Aug 31, 2011 | Supra 001004 Push Button Lock Box Key Safe
I have a 83 supra, can see where to read odbc codes from later models but I don't see a diagnostic center located under the hood how to I read the codes?
  • There are two place this could be.
  1. The first place will be a little cord barely dangling from the distributor. There will be nothing else plugged into it. It only has to connector points in it. Take a paper clip and jump one side to the other and put the ignition to the on position.
  2. Some Supras have a box that you test from. You will look for the fuse box under the hood and right next to it is another box that says "diagnostic" on it. Find T or TE1 and jump with a paperclip to E1. The underside of the lid to that box will show you which pin is which. Turn your ignition to the on position.
  3. When the check engine light comes on should it blink nice and steady there are no codes. Other wise it will blink codes in set of 2 digits.
  4. 1983 Supras were the first ones to have a check engine light on the vehicle. So if this is a real early 1983 Supra it may not have a CEL option on it.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 24, 2011 | Supra 19821998 performance Portfolio Books
Im locked out of my laptop the password is three letters of names
I'm assuming that your problem is that yor forgot your password and got locked out of your computer. That's a easily fixed problem if you have a computer that has Internet and a cd drive and a blank cd. Go to google and search dreampackpl. Then click the first link. Read the directions there and follow them. This will allow you to reset your password. Good luck! (Dont try this on a company computer as this can be considered hacking)
Sep 10, 2009 | Microsoft Windows Vista Ultimate Edition
General Electric Ge Supra C3 Real Estate Realtor Key Lock Box Dial Logo
168 people viewed this question
Top General Electric Office Equipment & Supplies Experts
jasbo
jasbo
Are you a General Electric Office Equipment and Supply Expert? Answer questions, earn points and help others
