Question about Radio Communications
Radio shack walkie talkie 21-1914 replaced batteries will not charge
Old battery quit charging on one hand set. Bought new batteries, one hand set will not charge. The base works and the hand set will work on regular batteries, just not on the recharging batteries. Radio Shack told me that the recharging part of the walkie talkie my be bad. Cost to fix?
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi pearl,
A simple problem to solve at last!!!
Inside the battery compartment you should find a switch, which indicates Recharge/Normal, make sure you select recharge if your using these batteries, otherwise no charging occurs.
If this does not work, take out the recharchables and select normal on switch, place fully charged normal batteries into the compartment, making sure you put them in the right way around, close the flap and turn on the radio, if this works, then your battery switch is faulty, however, you can get lithium ion batteries, which will last longer than most other high duty batteries.
The cost of getting these radios is not worth the money, unless you are technically minded and buy the repacement switch and repair it yourself.
Otherwise try all of the above, and remember, when charging batteries that are rechargeable, never leave the radio on, as this can wear out your batteries quickly.
I hope this advice is helpful to you.
Best regards,
Peter
Posted on Mar 05, 2013
4 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: I have a gmr885 walkie talkie set...we used them
You might try cleaning the battery contacts and the charger contacts with a pencil eraser. It could be you are not getting good connection. Also check your batteries to see they are installed correctly and are touching the internal battery contacts to the radio. Try switching the battery pack to the opposite radio, as a test to see if one will turn on. It would be highly unusual for both radios and/or chargers to fail at the same time. So the problem is probably something simple.
Posted on Jul 25, 2009
SOURCE: charging walkie talkies
This is more for "mshtexas" than the OP but I'm sure there may be others out there wondering the same thing. The power cord that comes with this unit has a 9.0v output at 200mA with the center pin being positive
Posted on Jul 01, 2009
  • 35 Answers
SOURCE: need a manual for radio shack 21-1936 walkie
The 21-1936 was made for Radio Shack by Uniden and is identical to the Uniden GMR-1038-2
The Uniden version of the manual is available HERE
Posted on Nov 12, 2010
Transister rsdio won't turn on or off
Very likely bad batteries in the handhelds. Make certain they have been charged fully and try again. If not, get new batteries. Batteries go bad even not used, sitting in a box or on a shelf. 1999 are likely nicad chemistry and without a professional battery conditioner, I doubt they will take a charge. You could try to charge and dis charge them your self 10-12 times. Sometimes this will work. Fully charge the battery, put in the radio and turn it on until the radio beeps. Do not let it go dead overnight or you make the problem worse.
Sep 30, 2014 | Radio Shack 1999 Radioshack 6 Transistor...
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Sep 28, 2014 | Motorola Walkie Talkies 2-Way Radio
I bought new batteries for a Motorola Radius SP21 walkie talkie but it still does work.
Here are a handful of things which could be the problem:
1. Check to be certain you have the battery installed the correct direction. With this radio, it is a common mistake to put the battery in backwards. The Motorola logo w/name should be facing forward, and with the radio in an upright position, you should be able to read the words on the battery.
2. Check your charger. The red light should come on and stay on during charging.
3. Clean all battery contacts gently with a pencil eraser to remove dirt/dust/hand oils, then try charging again. If you are using a wall plug charger only (not a drop-in) you may have a problem with the jack on the radio.
4. Check your radio to be certain it is set to the correct frequency and PL code. It must be set identical to your other radios in order for them to communicate with one another. If you need help with this you can give us a call at 800-872-2627, and we'd be happy to walk you through SP21 programming over the phone.
Best regards.
Sep 26, 2014 | Motorola Radius Vhf Sp21 2 Way Radio...
My Cobra MircroTalk walkie-talkies aren't charging. The charge light doesn't turn on and I've made sure u turned Tue units themselves off. The model number is: GA-CQ
If your problem started after replacing the batteries (mine did), see this: http://www.walkie-talkie-radio.co.uk/replacing-cobra-walkie-talkie-rechargeable-batteries.html If that is your problem, you can also fix it by wrapping foil around the bottom of the battery that makes that touches the bottom side charging contact.
Oct 19, 2013 | Radio Communications
Cobra pr 3850wx bought new NiMh 800mAh 1.2v rechargable batteries now the base charger lights won't come on when i put the radios in it
  • A Cobra 3850wx Radio requires 4x600mAh NiMH 1.2V AAA Part # GA-3ANH rechargeable batteries.
  • Not just any AAA rechargeable battery will charge in the unit.
  • All will work in the radio but not all will charge inside the radio. It has to be a specific battery.
  • This is an example of what you need. GA-3ANH batteries which will charge inside your radio. http://www.tomsawyer2wayradios.com/catalog/item/3823249/5076887.htm
Regards, Tony
May 22, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
The battery is fully charged on the walkie talkies and all are on the same channel, however out of 12 walkie talkies only 2 will work. When ever you push the push to talk button the walkie talkie shuts...
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
Nov 09, 2010 | Motorola Walkie Talkie 2-Way Radio
I have a gmr885 walkie talkie set...we used them last weekend as we moved from ct to maine..they were charged well before we left ct and when we got to maine put them in the charger, no lights showed lite...
Jul 24, 2009 | Radio Communications
Charging batteries
the cobras are meant to work with alkaline cells. You bought nicads which are a lower voltage per cell (1.2 to 1.38). Alkalines are about 1.55-1.58
That is why your rechargeables only show a quarter charge, because their terminal voltage is lower and the radio thinks they are not fully-charged.
May 28, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Motorola Walkie-Talkie will not turn on.
Unfortunately problems involving electronics don't fix them self. If the radio did not work and then it worked after a day or two then it is quite possible that you did have water in the radio. if this is the case. then you will probaly have more problems in the short future as the contaminants from the water start to destroy the board. In this case the best thing to do is open the radio and use an electronics parts cleaner like the tuner cleaner from radio shack and clean the board. Trust me, I have had many customers that have ignored the problem and it cost them later.
Good Luck
Patrick
Nov 14, 2008 | Motorola Walkie Talkie 2-Way Radio
Radio Communications Logo
144 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
