Question about GE Nautilus 24" Built-in Dishwasher
Having trouble putting door together
We took the door a
part to replace the gasket, now the pieces dont seem to want to go back together
    Scholar:
  • 93 Answers
Whenyou took the door apart did you take note of how so you can reverse the proceedure Sorry it is difficult to explane in words on how to put a door together all I can say is try placeing the panels from the top down and bottom up then if anything works put in all the screws halfway then after all the screws are in then tighten them as evenly as possible
Posted on Jan 23, 2009
Need reassembly instrucstions on American Standard ToeTap Drain
buy another one and use it as a model to put yours back together then take it back for a refund.
Dec 24, 2013 | American Standard Plumbing
LDF6920ST dishwasher leak
you can just replace the gasket and you can use a tube of pool lube its a thick gel that protects it and will hold it in place
Jul 28, 2012 | LG LDS4821ST Stainless Steel 24 in....
I have replaced the contact plate in the foot pedal but am having trouble fitting the two pieces of the foot pedal together again.
I use the solution suggested in a previous posting. This involved using a piece of thread to hold back the contact strip and lining everything up first.
It took a lot of patience and about ten trys to get it right but it worked in the end. Reading that we had thought of the same solution, made us keep on trying. Thank you
Dec 31, 2009 | PfaFF Sewing Machines
Putting inside back together
I found the company website. There is a section on parts. In this section it gave you a schematic diagram of the inside. Very easy to put back together with a picture!!!
Dec 05, 2008 | Frigidaire 18 in. FDR252RB Built-in...
Door handle replacement
I tried different ways of putting the door handle and lock together. It took me 5 hours to eventually work it out. Now the problem is solved.
I took a digital photograph of the lock before I put it back onto the machine, so now I have a permanent record to refer to next time. I say next time, because we've had 2 Servis Washing Machines, and between the 2 machines, the door handle has broken 4 times, through no fault of ours, each time having waited for the time switch to deactivate.
I think by now the company ought to make the plastic piece that keeps snapping, out of aluminium.
Sep 12, 2008 | Washing Machines
Ice Maker Trap door may be broken
I am having the same problem. My husband took off the front panel and we discovered there is a small piece of plastic holding the ice dispenser door in place that is broken so the door doesn't seal.
I called Sears to see if the part is replaceable -- it's not. I have to buy an entire freezer door for $464 because a .10 cent piece of plastic is broken.
This seems to be a common problem. My refrigerator is only 3 years old. Perhaps we need to make a complaint to Sears/Kenmore together.
May 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Need help putting GE oven door back together again
they're called towers. They go on the 2 long screws once you've put the screws through - so they go between the two panels. They are used to space the 2 panels so that they line up flush when they are back together.
Jan 09, 2008 | Kitchen Ranges
We took the oven door off and now can't put it back on
i dont know how you got the door off the is a lock for each hinge
lay the door down with hinges facing up.take a towel pull long piece
of hinge toward you(BE CAREFUL) take other piece up and lock them together do the same to the other hinge it should then go on easy next time lock before taking off
Dec 09, 2007 | Hotpoint RB757 Electric Kitchen Range
Bosch Dishwasher
Hi ED, It sounds like a real problem here. If the springs are still in one piece, my best guess is to to remove the springs from the door. Then attach the springs to the dishwasher body first, then reattach the spring to the door. Not an easy job, good luck. If you have further problems check with www.repairclinic.com, as the repairguru there may be of more help.
Sep 25, 2007 | Bosch 24 in. SGS43C12 Classixx...
GE Nautilus 24" Built-in Dishwasher Logo
101 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
