Question about Kirby Ultimate G Bagged Upright Vacuum
Vac blows air out rather than sucking air in.
I can't seem to get the vac to **** the air in, it seems to act as a blower rather than a vacum.
  • 1 more comment
  • jplucero42 Jan 26, 2009
    No.
  • Rocky
    Rocky May 11, 2010
    It had happen to us only 2 times when technician switched wires when re-connecting to power switch (inside the unit). For it just start spinning other direction with no one actually doing anything to it - not sure what happened.
    I am sure we can find the problem and fix this but we have to have it here.
    (just to make sure if you are using the hose you are attaching it instead of the nozzle NOT in place of the bag...)
  • Rocky
    Rocky May 11, 2010
    Did you do ANYTHING inside. Did you reconnect wires?
  • 357 Answers
Shop Vac MAC 12-200D my shop vac is blowing air instead of sucking air. How do I fix it
this might sound silly but have you got the pipe in the blowing end instead of the sucking end hope this helps
Oct 09, 2016 | Shop Vac Vacuums
Sucking and blowing
Shop-Vac® Brand. The Original Wet/Dry Vac™
https://www.shopvac.com/
Shop-Vac® is proud to be an American-based company. ... When we say the Shop-Vac® is powerful, we're talking debris cleaning, leaf-blowing, heavy-duty, wet or ... Many of our vacs are backed with a 3 to 5 year warranty, but we've seen ... I had just gotten back from work, so my arm was hurting, and I really didn't want to ...
My ShopVac Blows - WOOD Community
community.woodmagazine.com > Forums > Tools and Tool Buying
Nov 23, 2009 - My ShopVac suddenly started blowing dust out the exhaust ports. I don't mean a little dust, it blows almost as much dust as it sucks in!!!! ... ... I'd look it over very carefully looking for tears or splits. Might be a good idea just .... A few months ago I purchased a Dust Deputy and hooked it up to my shop vacuum.
10 Shop-Vac Vacuum Hacks For Around The House - Thrillist
https://www.thrillist.com/.../10-shop-vac-vacuum-hacks-for-around-the-...
Sep 14, 2015 - Simply flip the switch from suck to blow and blow leaves to your heart's... you really need to get your act together if you're using a Shop-Vac for ...
Shop Vacs...and dust control? - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Cleaning Tips
Jan 09, 2016 | Shop Vac Vacuums
My shop vac is not sucking anything only blowing air out of the open hole where the hose should go if I wanted to blow something. I want it to vacuum not blow out. The filter sleeve and dry cloth are...
I just had the same problem, the vac wouldn't suck in. Turned out to be because the filter was WET. It works great when I take the filter off before sucking up water or liquids! Not sure if this applies in your case, but definitely something to keep in mind. : )
Jan 17, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
How do i change from leaf blower tovac? vac will only blow i need to cahange it to vac mode
fell on top of vacum for the place where the air is being sucked in that is the vacum port put hose on this port
Oct 22, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
My shop vac is blowing air out and not sucking. How do I get it to suction?
make sure top is sealed up properly also check to see if hose is not plugged in hose or inside vaccum
Aug 28, 2009 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Have a Sears shop vac, mod 113.172. The motor doesn't take in
If the motor turns, you should have suction. Put the hose on the exhaust side of the motor if there is a connection, and try to blow it out. If you can't, try using a garden hose or toilet snake to clear the hose. IF the hose is clear, and the problem continues, check the float in the cage below the motor. It should be down at the bottom of the cage. Also, if you haven't been using a bag or foam cover for the cage, it is possible for leaves to clog the motor.
Mar 15, 2009 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Husky 6 gallon dry/vac wont **** in air, only blows air out
Maybe you have the vac hose plugged into the blow out port.
Nov 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Shop vac
is the filter in place and in good condition. To find the filter just unhook the top and lift it off.
Nov 01, 2008 | Shop Vac (464-38-10) Canister Wet/Dry...
Kirby Ultimate G Bagged Upright Vacuum Logo
329 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
