Question about Frigidaire GLTF2940ES Front Load Washer
My washer washes for about ten minutes stops lights start flashing and it resets to like its starting over again and shuts off how can i fix this
  • Official Brand Answer
  • 4,342 Answers
Hi shaen1257 - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly, faulty pump or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? With this information I can advise you further on what the main issue could possibly be.
Posted on Jan 15, 2013
SOURCE: Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Posted on Apr 27, 2008
Excellency
  • 20 Answers
SOURCE: Washer Pauses and Shuts down Repeatedly
Check the cold water line into the unit. Remove the hose from the washer and clean the screen. flush the line while it is disconnected into a bucket or small garbage can. Your washer wont advance without a fill and most fills/rinses are with cold water
Posted on Dec 10, 2008
  • 3 Answers
SOURCE: the wash beeps all the time
I had the same problem about a year ago. Out of the blue, the washer would start beeping and blinking. While the washer would run fine, it was annoying. Anyways, I had the service guy in and he had to replace the control board panel (under warranty). Without warranty, the cost of the part would be ~ 150.00. It was fine after that.
Posted on Jan 14, 2009
  • 190 Answers
SOURCE: err 10 message on Fridgidaire front load washer
The E10 error indicates a long fill error meaning the machine thinks it took to long to fill with water.
            We recommend u to check that the drain tube is now stuck to far into the stand pipe and possible causing as siphoning problem, and that the screens on the water valve inlet are cleaned and not slowing the water flow.
             u can hook the drain hose off, forcethe  water through it with a water hose, unclog the stinky mess and  hook it back up again and  work it.. tat woul do..
Plz rate this solution.. thank you..
Posted on Apr 08, 2009
blueextc3221
  • 15935 Answers
SOURCE: Frididaire (LFT2140FS) Front Loading washer - Did
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
2003 chevy s10 security systems not starting
If when you attempt to start the vehicle, the "theft" or "security" light is flashing; apply parking brake (this turn off the auto headlights), turn ignition on. Security or theft will flash. Leave vehicle in this position for approximately ten minutes. Security or, theft will stop flashing and then you may start the vehicle. This is a VATS security soft reset. If it does not reset after ten minutes you may need to do a hard reset, which is three sets of ten minutes.
Feb 17, 2014 | Chevrolet Vehicle Parts & Accessories
GE WASHER LIGHTS FLASHING BUT NOT WORKING
It won't change because the cycle was incomplete and the safety control is preventing a restart. Until you get professional onsite service; unplug the washer; make certain all of the water is drained out, and disconnect the hoses. Have someone help you tilt the washer forward and lay on the front side. Pick it up again and reach into the tub area and spin the tube around, and kind-of move it side to side. Hook it back up, plug it into the power supply and reset the timer to start a short wash. Try to start and see if you get any action. If after all of that; nothing changed, the timer on the circuit board is stuck where you left off when the unbalanced load shut it down.
Dec 23, 2013 | GE Profile WPRE6100G Top Load Washer
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
Won't start, radio locked, security light flashing and check engine. Disconnected positive battery and connected started. While driving radio locked up again amp dropped out and air quit stopped shut off...
If your vehicle has the GM Passkey system, it is possible the security lockout has been engaged. The way to reset the Passkey system is as follows.
1.Turn the key to the ignition "on" position (but do not start the engine) and leave it in the on position for 10 minutes. After the ten minutes has passed, turn the key to the off position.
2. repeat the above step 2 more times. This will take about 30 minutes.
3.Do not attempt to start the vehicle or use any accessories while performing this reset procedure.
I hope this helps.
Sep 16, 2010 | Chevrolet Monte Carlo Cars & Trucks
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
My washer will not start up again.
try unplugging the washer, letting it sit for a minute or so, then replugging it. this may reset it.
Mar 22, 2009 | Kenmore Washing Machines
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Ariston dish washer model ll64xaus Lights 3&4 flashing and unit wont start
Hi pedretti,
I'm Harvey the Master Plumber.
Your problem is: Ariston dish washer model ll64xaus
Try resetting the d/w. Just turn off the curcuit breaker for ten minutes. Sometimes the control board needs to be reset. If this persists you may have to replace the board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 28, 2008 | Dishwashers
Maytag top load washer
Unplug the machine for ten minutes and then try it again to see if this resets the system!
if not you need hands on service!
bless you
Sep 07, 2008 | Maytag Legacy Series Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
