Have hotpoint wd860 washer/dryer. Message fy05 appears, any ideas - won't spin
  • 135 Answers
This code relates to a drainage problem and will probably be a blocked filter. Check behind the kick plate at bottom of machine for screw off type filter, if not there it will be in the large pipe from drum to pump at the drum end.
Thankyou for using Fixya.
Posted on Jan 22, 2009
Ultimate hotpoint washer/dryer wd860 1600 spin
F18 is a communication error. Basically this means a PCB card has failed, a wire or plug has become detached. If you are good at DIY it may be worth investigating. Hotpoint advice is to call aservice engineer.If you decide to investigate , look for bad connections, very carefully remove the pcb plugs making a note of exactly where each plug goes back, clean contacts and replace. This has worked for me on more than a few occasions. Replaced after doing a wipe over and replaced. It is worth a shot before paying out service call prices. Loook for obvious damage on the PCB's. ENSURE you mark the plug positions VERY carefully.
Nov 12, 2012 | Hotpoint Ultima WF860 Front Load Washer
Ultima WD860 - dryer has been stuck with 1 minute left for about half an hour. Have turned it off but obviously my stuf is stuck inside.
Please disconnect your WD860 from the power supply. The door lock uses electrical power to stay closed. After you unplug the machine from electrical power, just wait a couple of minutes and the door lock will be released.
Aug 26, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
Hi, i have a hotpoint WD860 washer/dryer and when it is turned on will blow the trip for the house mains, i have found today though that if the door is open it will not blow the trip, any ideas please
reason the machine blows trip probly damaged wire unplug mach remove lid and check wires around dryer unit this is often the scource good luck
Jun 08, 2011 | Washing Machines
How doI get the clips off the Hose
Slide it to the side of the grip teeth this aids removal..
Apr 19, 2010 | Hotpoint Aquarius WD640 Front Load...
Error code
H20 indicates incoming water supply problem.
Check that the water is fully turned on.
Check the inlet hose/s for kinks or restriction.
Make sure there is a good pressure of water to washer.
Please rate my solution.
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
Wd860 trips rcd when spinning
fault with motor you will need to replace
Jun 06, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Keeps going on test cycle
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Mar 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD860 Washer / Dryer
Firstly unplug the machine. Take it outside, use petrol + match. Go Currys and buy anything other than a Hotpoint.
All serious apart from the petrol and match, as that could be dangerous.
Jul 30, 2008 | Washing Machines
Hotpoint WD860 problem
washer wf860 showing f07 error. why
Mar 04, 2008 | Hotpoint Washing Machines
Washing Machines Logo
129 people viewed this question
Top Washing Machines Experts
