Question about Grundfos UP10-16BU/ATLC Comfort Series 1/33 HP Recirculator Pump with Union
Grundfos Model 15-10su7ptlc pump does not seam to be running..just installed and no hot water
  • Grundfos Master
  • 5,245 Answers
1) Check that plumbing is correct:
http://waterheatertimer.org/Water-heater-recirculation-system.html
2) The timer has 2 choices: thermostat operation or timed operation.
http://waterheatertimer.org/images/IMG_9325-grundfos-timer-800.jpg
http://waterheatertimer.org/How-to-set-timers.html
3) Add comment and say what you discover
Posted on Jan 16, 2013
  • 82 Answers
SOURCE: Grundfos installation with Buderus boiler. Pump
Do you have more than one zone? If so, it is difficult to tell if the circulator in question is actually running. A trick is to get a screwdriver and place the metal end on the front of the circ and the other on your ear. You will hear it if it is running. If you do hear it, is the circulator itself very hot to the touch? If it is, it may be burnt out, or the zone needs to be bled of air. Another doubtful, but possible, answer is that the circulator is installed backwards. There is an arrow on it and it should be aimed towards the flow of water.
Posted on Dec 31, 2009
  • 61 Answers
SOURCE: My hot water heater sprung a leak and after
pumps of this type will fail quickly without water. They are lubricated, and cooled by the fluid that runs through them.
Posted on Jan 03, 2010
SOURCE: After replace the cold water
Many times when pipes are worked on, the work loosens sediment that was built up in the pipe.
Sediment is probably why cold water line was replaced.
That's why faucet aerators get clogged up after pipes are worked on.
It sounds like your grundfos pump got clogged too.
Immediately unplug the pump so motor is not overheating.
Motors are meant to turn freely and can be damaged when blocked.
Take apart the pipes at grundfos pump and see if you can clean out the line.
If line cannot be cleaned or pump doesn't restart, then the grundfos has to be replaced.
Also look at adjoining pipes and see if there is a clog in nearby elbow, especially where galvanized and copper pipes join..
Posted on Dec 26, 2010
SOURCE: I have a Grundfos Comfort System. At the tap
Sounds like you have sediment built up in the pipes, and maybe the furthest faucet is the gathering place.
Take off each shut-off valve at furthest faucet and connect a water hose that flows into nearby toilet bowl.
You can buy garden-hose-to-1/2-pipe adapter at hardware.
Open water so it flushes the line into toilet bowl.
Then clean out valves and reassemble shut-offs and grundfos connection.
Remove faucet aerator and flush line up to faucet.
Install new aerator.
Posted on Dec 30, 2010
SOURCE: Same problem as another writer
If the pump is hot, the motor has overheated and will stop working. There's no cure for motor at this point. Be sure to de-lime and de-scale re-circulation pumps occasionally.
Return pump and exchange for new. Sounds like you already diagnosed the problem correctly.
Posted on Apr 10, 2011
My grundfos hot water circulator works great. how often should I set it to circulate the hot water, ever hour, before morning shower or evening shower.
Last one I installed, I used a PIR sensor to control it, so that whenever someone walked towards the bathroom or kitchen, the pump will start up and run for 15 minutes. It really depends how often you use hot water - if only certain times of day, then it would be wasting power to run the pump, and heat loss from the pipes (unless very well insulated). If you have a regular pattern of use, then you could use a timer/programmer as you would on your normal hot water or heating. If your piping is plastic, then don't run pump continuously, as some plastic piping is not recommended for continuous circulation at normal hot water temperatures.
Oct 21, 2017 | Grundfos Hardware & Accessories
Grundfos pump problems
I've just had a ideal i35 boiler fitted, the grundfos ump3 economic pump has failed / seized and has been replaced 4 times since the boiler was installed 7 months ago.
It has just stopped working again and ideal are refusing to attend.
any advise would be appreciated.
Aug 14, 2014 | Grundfos Pumps Grundfos UP15-29SF 1 12 Hp...
After installing the thermo bypass valve on the furthest sink faucet from the water heater, the sink faucet has no pressure, and there is hot water slowly comling out of the cold water valve.
It sounds like the installation loosened sediment inside pipe.
Remove sink aerator and see if you can flush open the faucet.
Also check if other faucets are receiving hot water from hot-and-cold taps that says if grundfos is pumping hot water from the water heater correctly.
When recirculation pump is running, both hot and cold water lines have hot water.
If other faucets have hot water in both lines, then that tells you the blockage is localized in furthest faucet supply lines.
You may have to dissemble those supply lines and flush the sediment out.
Dec 30, 2010 | Grundfos Comfort System Recirculator ...
Just bought a house and it has a grundfos timer/pump attached at the hot water tank. I have no hot water and the timer doesn't turn (as I've seen other timers do). Is it supposed to turn so that the...
Grundfos is a sealed unit and not a repairable item.
The timer dial should turn.
And pins located around dial control ON-OFF functions as timer dial rotates.
Does the receptacle have power?
If receptacle has power, and Grundfos is not working, then it is broken.
Grundfos manuals for UP series pumps do not show breakdown or parts list of any kind.
http://www.us.grundfos.com/web/download.nsf/Pages
Bigger question:
Why don't you have hot water?
Is water heater functioning?
Water heater is a separate appliance from Grundfos pump.
Grundfos pump circulates hot water from tank into the lines so there is no waiting for hot water ... but hot water heater should still make hot water.
Add a comment about water heater if that is also a problem.
You could have 2 problems, and water heater is main issue.
For do-it-yourself electric water heater repairs:
http://waterheatertimer.org/6DIY.html
Nov 20, 2010 | Grundfos The UP1510B5ATLC 125th HP 1...
Grundfos submersible well pump with Grundfos CU301 control. Control box shows no contact to pump. What is the problem or problems?
Grundfos is a p. o. s. I have a new system cu 301 and I have had to get it repaired twice by Fogle Pump and Supply. These guys are real rip of artists in Washington State and should be reported to the BBB. Dont Use Fogle if you need a well
Sep 15, 2010 | Grundfos RCP-96 Recirculation Pump for...
My Grundfos Comfort System is not working. I has been installed correctly....the pump is running, I checked and replaced the valve....still no immediate hot water. The installation instructions...
Turn on the hot water at the farthest faucet from the water heater. Once hot water is at that sink immediately go check other taps in the home. If you have to wait more then 10 seconds for hot water at other taps then you have a branched system.
Sep 01, 2010 | Grundfos Comfort System Recirculator ...
Grundfos installation with Buderus boiler. Pump which is assigned to hot water throughout house, seems to be working (noise and vibration indicate that) but hot water doesn't pass the valve. Pipe below...
Dec 25, 2009 | Grundfos Comfort System Recirculator ...
Grundfos recirculating retro fit hot water out of the cold side
they have it installed wrong it is pulling from the wrong side, it is supposed to pull ot water up to the fixture but then if it stays hot on the cold side they are backwards
May 27, 2009 | Grundfos RCP-96 Recirculation Pump for...
Grundfos UP10-16BU/ATLC Comfort Series 1/33 HP Recirculator Pump with Union Logo
195 people viewed this question
Top Grundfos Hardware & Accessories Experts
Gene Haynes
Mike Magnay
Mike Magnay
Are you a Grundfos Hardware and Accessory Expert? Answer questions, earn points and help others
