Question about Vacuums
Remove hood Hoover U1318
Remove hood
  • Larry Pridgen Jan 13, 2013
    I want to fix the mechanism that holds the vacuum upright during storege. One tooth is broken off mechanism.
How do l change a belt on my hoover bagless cleaner?
Hi there! To replace your belt follow these quick steps below.
1. Remove your nozzle or hood, whichever your manual states.
2. Remove the brushroll and slide the old belt off.
3. Replace with specific genuine Hoover belt for your vacuum.
4. Slide the belt over the metal motor shaft.
5. Slide the brushroll through the belt and allow the belt to rest on the portion of the brush roll without any bristles.
5. With brushroll in place pull and slide the brushroll into nozzle making sure that the brushroll end caps are in the correct orientation.
6. Replace the nozzle or hood.
For more specific instructions please provide your model number. Hope this was helpful!
Sep 18, 2014 | Hoover Vacuums
How to take hood of hoover u6437-900 vacuum cleaner
Hi! The hood on the cleaner shouldn't be removed. If you want to access the belt or the brush-roll the bottom place can be removed. To remove the bottom plate Disconnect cleaner from outlet. Use a Phillips screwdriver to remove the 5 screws on the bottom plate. Lift off bottom plate. Hope this was helpful!
Aug 01, 2014 | Hoover Vacuums
How do I remove the roller from the hoover c1429 vacuum cleaner in order to change the belt. Thanks.
That is an elite style upright. You will need to remove the hood by releasing for tabs around the outside of the hood/base. The brush will simply lift up. You may need to pry on the base with a flat blade GENTLY to get tabs on the ends of the roller out. I'll include a link to the correct belt.
Belt- http://www.vacuummedic.com/product.php?id=8
Good Luck!
Aug 22, 2012 | Hoover Vacuums
How to remove hood from hoover steam cleaner deluxe I can not find how to remove hood its on top of nose of steam cleaner
Hi Lisa,
Do you need to clean the nozzle or do you need to do repairs inside? You only remove the hood to do repairs. For cleaning the nozzle, refer to your owner's manual as to what to do after you finish cleaning. There is a description for how to clean the nozzle.
If you need to do repair, please reply back. Thanks,
Handie Andie
Apr 24, 2011 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
I have no owners manual and need to replace the belt on a Hoover powermax model #:U5242-930 can you help thanks Bab
I don't see this unit on the Hoover support site. However other Powermax vacuums come up in the search for manuals: http://www.hoover.com/CustomerService/manuals/Default.aspx .
Most of the units have very similar belt replacement procedures. First unplug the vacuum. Then press the handle release lever and place the handle in the low position. Next remove the hood by turning the two slots either side of the hood with a coin. Rotate the hood towards the front of the unit and remove it. Then remove the agitator brush roll and the old belt. Discard the old belt.
With the lettering to the outside, slide the new belt over the motor pulley. (The old belt should have been on the pulley. If the belt broke and isn't in place, look for it on the right as you look at the front of the vacuum above the agitator brush roller's position.) Slide the agitator brush roller through the belt and place the belt in the belt guide on the roller. Grasp the agitator and put it into position. Fit it into the rectangular slot on the left. Then pull it into position on the right side of the vacuum. Check if the agitator and the belt turn freely and that the belt isn't pinched between the agitator and the bottom of the unit. Replace the hood by aligning the tabs with the slots on the base. Then turn the coin slots to secure the hood.
I hope this helps.
Feb 01, 2011 | Hoover Powermax U5242-930 Vacuum
Remove bottom of cover on vacuum bottom. Making a
on this model, the bottom does not come off but the top does. on the top hood there are 2 latches to turn with a screwdriver and the hood will come off.
Oct 17, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Can't get to motor to connect belt after removing brush cover
I followed the instructions that were supplied @ the FixYa site, to remove the hood. Removing the hood was the problem. Just follow the online users manual pages 22 thru 26. you must spread the hood by the rear wheels to remove. Thank You Very Much. Delano
Jun 29, 2009 | Hoover Soft Light Supreme U4262-930 Bagged...
Hoover self propelled U6630900 idler arm lock
Remove the bottom plate (4 screws), remove belts and brush roller. There may be 1 small screw in the center front of the vac under the brush roller. remove this one. If this is a bagless model you will also need to remove all of the back screws (torx) that hold the lower hose on. This needs to be removed to take the hood off. underneath on each side of the power drive assembly you will have 1 screw, remove them. there is a clip on each side that snaps the front on, push them out with a screwdriver. Then the hood is removed.
Feb 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
Roller on a hoover turboPower 3100 fold away won't turn
the top hood will come off. there should be 2 screws under the front corners and 2 more on top toward the rear of the hood. lift hood off. this will expose another cover, simply remove these 3 screws to get to the roller and belt
Jan 14, 2009 | Hoover U5178-900 Vacuum
Removing the hood to clean the cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41018&thid=498921
Posted by bfy1952 on Apr 08, 2008
How do I remove the cleaner hood the clear see thru plastic to clean under the hood?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5881-900 Vacuum. There may be 2 ways to remove the top cover. There are two screws located on the bottom and there are 2 ways that might work. The clear tube on Hoover’s sometimes will swivel and that is the way to bet the clear tube unclogged, or once you remove the 2 – 4 screws on the bottom the top should lift right off, and then you can serviced your vacuum cleaner. If you have questions you can always contact your local vacuum cleaner dealer in your area or call tech support @ the Hoover @ the factory and ask for tech support.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 08, 2008 | Hoover F5881-900 Vacuum
Vacuums Logo
181 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
