Question about Bissell 1770 Quicksteamer II Upright Vacuum
Why wont my bissell quicksteamer **** up the water?
It won't suck up the water in my carpet after cleaning it.
  • Official Brand Answer
  • 315 Answers
Hey Kailyn, having no suction is a problem. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1092&cid=ccsocial
Posted on Jan 14, 2013
reddevil6
  • 1673 Answers
SOURCE: bissell carpet shampooer
First check that the top cover on the back side hasn't come loose. Sometimes the plastic around the screws break away and the top starts to separate, raising the tank, and no spray. Make sure that the gaket is on the valve at the bottom of the tank and not sitting loose in the hole. Check the pump belt. The pump may be bad.
Posted on Jun 17, 2008
SOURCE: I have a Bissell pro heat carpet cleaner, the
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Posted on Mar 01, 2009
  • 120 Answers
SOURCE: My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Posted on Jul 06, 2009
SOURCE: How do I fix Bissell Quicksteamer leaking from
I have the same problem... seems to be because of a bad, or worn, rubber gasket.
Posted on Jan 02, 2010
  • 4 Answers
SOURCE: Bissell carpet cleaner
I have owned three Bissell cleaners and experienced clogged hoses each and every use. Do not put carpet cleaning solution in these machines. They are not designed correctly. If you have a tough spot, just use some liquid dishwasher detergent and a scrub brush. It will get almost anything out! Try it! Then, use the Bissell with hot water only to clean up any detergent residue.
Have a great day! Bissell Sucks!
Posted on Aug 31, 2010
My Bissell quicksteamer powerbrush pet carpet cleaner model #47B23 will not suck up the water
Check the vacuum pipes for clogging, the dirt hair and carpet fibers do clog them.
Jan 31, 2017 | Bissell Vacuums
My bissell quicksteamer makes a high pitch squeal
Something is caught in your beater bar , causing preasure on another part of machine. This contact is the cause of the noise. GOOD LUCK FRIEND.
Sep 16, 2014 | Vacuums
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
My bissell upright won't **** up the water, but the attachments will
Hey Maria, sorry to hear about the no suction.
Feb 02, 2013 | Bissell 8910 ProHeat Clear View Upright...
My Bissell Pet Carpet Cleaner brushes will not turn around and heater doesn't work?
Hey you may want to check out our website for assistance in troubleshooting your machine. Here's a quick link to the FAQ page.
http://www.bissell.com/faqs/?cid=ccsocial
Jan 01, 2013 | Bissell 1770 Quicksteamer II Upright...
My steam cleaner is not spaying water on the carpet?
I found that if the water is not hot enough it won't create the suction needed for the water to spray. If you have use it in the past it could be that the water tubing could be clod.
Jul 21, 2011 | Bissell 1770 Quicksteamer II Upright...
I have a bissell quickwash model 1950 j 02175. it
the pump belt is off or broken, sometimes when you put too much soap or cleaner in device the belt will slide off the end of the roller, use pinesol to clean this works and doesn't do that, not too much cleaner.
Jul 19, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
BISSELL QUICKSREAMER MODEL 2070
Here is a link, don't know if it will work for you or not:http://bissell.com/images/UserGuides/1960.pdf
But you put you cleaning solution along with hot water in the upper tank, the bottom tank sucks up the water as you clean. Pull the trigger to dispense clean while pulling it back towards you, push it forward and repeat until done. If that link doesn't work, you can call Bissell and order a operator manual.
1-800-237-7691
Mar 17, 2008 | Bissell 1770 Quicksteamer II Upright...
Bissell 1770 Quicksteamer ii
Is the front nozzle fitted correctly, Is the tank seated correctly,
On the dirty water tank there is a sponge filter make sure this is clesn,
Nov 19, 2007 | Bissell 1770 Quicksteamer II Upright...
Bissell 1770 Quicksteamer II Upright Vacuum Logo
544 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
