Heater won't refire after it warms up
Hi, Thank you for your solution reply, however I cannot find a CAD flame sensor on of the Ready Heater Parts web sites. They do mention ignitors and ignition control assembly. Are they in anyway the same thing as the CAD flame sensor ? If not, do you know who I can purchase this part through ? Thanks again, Mike
  • wereloc8 Jan 23, 2009
    Dear Ira, The BTU output is 150,000 and the model # is R150B
    This is one of those bullit style portable heaters some people call
    them salamanders or wheelbarrow design. Thanks so much, Mike
    ( wereloc8@hotmail.com )
  • Ira Bowles
    Ira Bowles May 11, 2010
    What is the BTU output of your heater and model # ? I think I found what you need on reddyparts.com but I believe that you can get it a lot cheaper if the part will fit. Ignitors are not the same, if you have good spark yours is fine. Let me know and I will do my best to find what you need for a reasonable price.
    Ira
  • 92 Answers
If you go to mrheater.com and click on the forced air kerosene heater parts tab you need part #26865 cad cell/flame sensor, it's $2.23 the wires will be a different color and also the plug ends so just clip the wires of the old and new one and splice it to the old wires, there is no wrong way to hook them up, no hot or ground it just completes a circuit. Most parts from this company will work with any heater of comparible btu's. you can also call 800-251-0001 Hope this does it for you. I checked reddy heater and the same part lists for $18.08
Posted on Jan 23, 2009
We have a model TS210KT kerosene heater and it runs for 15 sec. and then E1 CAD Cell Shutdown code comes up and the heater shuts down
  1. 1) Check wiring to Cad Cell (per wiring schematic in manual). Test heater.
  2. 2) Clean Cad Cell photo cell.
    a) Slide Cad Cell out of Cad Cell holder.
    b) Push the photo cell out of the white rubber Cad Cell housing by
    pushing on the blue and white wires.
    c) Clean the photo cell with a soft cloth and rubbing alcohol.
    d) Pull the photo cell back into the Cad Cell housing and reinstall into
    holder.
    e) Test heater.
  3. 3) If the heater still does not operate, replace Cad Cell. Test heater.
  4. 4) Replace oil flame control assembly. Test heater.
    Owners Manual with full details here.
Dec 08, 2011 | Mr. Heater Heating & Cooling
I have a unit that has built in thermostat. When
my ready heater pro115 model numberr115 keeps shutting off
Dec 20, 2009 | Reddy R115DT Oil Filled Utility Heater
Heater will not refire
make sure its not a problem with the low voltage wiring to the stat. the other problem with not firing i either pressure switch not making or the flame sensor is dirty/thermal coupler (not sure which one it has)
Nov 21, 2009 | Dyna-Glo Heating & Cooling
Cad flame sensor
go to Mr.heater.com and get a CAD flame sensor for any heater with the same btu output. They are all basically the same. The wires will be a different color so just splice them to you old wire harness, there is no wrong way to connect them. I just did the same thing with my dyna glo and it works perfectly. Most heater parts ar interchangeable they just have different wireing.
Jan 22, 2009 | Reddy Heater-30-55,000 BTU Variable
CAD flame sensor is bad, 3$ part and easy to install.
Jan 22, 2009 | Reddy Heating & Cooling
I have a Reddy heater pro 155.
Check all of your air filters but most likely it's the CAD flame sensor.
Jan 22, 2009 | Reddy R155D Utility Heater
Built in thermostat and fuels
diesel fuel requirs a hotter spark for ignition and burns pretty dirty, better off with K1 kerosene. You could change the ignition system to a mutifuel but it's not cheap and may not mount to your current houseing but would still work. As for restarting it is one of two things: the hight heat limit control or most likely teh CAD flame sensor, both of which you can get from Mr. Heater for less than 3 bucks each. the mount for the limit control is different but you can simply remount it to your heater mount. Same thing with the flme sensor, the wires are different but you can splice the to your wire harness and it will be fine. there is no wrong way to hook them up so don't worry about ground or hot.
Jan 20, 2009 | Reddy Heater-30-55,000 BTU Variable
Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
All Pro Heater
most parts for kero heaters are interchangable. go to desatech dot com for parts. check for a reset button for your heater. if no reset, does the fan run? your unit can use one of two ignition parts. a spark generator with a spark plug or a hot surface igniter. the unit uses a cad cell flame detector. you might need to replace this.
Nov 18, 2007 | All-Pro Kerosene Garage Shop Heaters - All...
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
