Question about Music
Blowing fuses on a crate bv60h - Music
  • 110 Answers
The easy answer is that you may not be using a "Slo-Blo" fuse. If not, then you can find them readily at Radio Shaft. These are a MUST with amplifiers like this. If you ARE using the right kind of fuse, then it may be internal line voltage issue, and requires service. Good luck!
Posted on Jan 14, 2013
I am looking for the proper fuse needed for this amp. I keep purchasing the wrong ones
The fuse rating should be printed on the panet right by the fuse holder. If there's still a question about values, you're best bet is to contact Crate customer service.
Here's the link-
http://www.crateamps.com/support
However, if you're meaning that you keep blowing fuses and therefor think you're instaslling the wrong value, you may have a short in the amp that's casuseing the fuses to blow. In that case, it needs to go to the shop. If you're not a tech, don't poke around inside it. You can make the problem worse, or even get a nasty shock.
Mar 31, 2016 | Crate FlexWave FW120 Guitar Amp Combo w...
Crate power head replace fuse how to /
did it blow a fuse or is it just dead?
Aug 02, 2014 | Crate Music
Why does crate blue voodoo 60 blowes fuse when power switch turned on?
because something in it is shorted..shop time.
Jul 13, 2014 | Crate Music
Gx 15
Amps have fuses inside. Check them if they are blown. After replacing, if it keeps blowing, then you have a short that needs to be fixed. Good luck!
Mar 27, 2014 | Crate Music
I have a Crate GT 15, not getting anything to the speaker when I plug in.
Do you have electronics experience? Inspect the amp for broken or cold solder joints and any burned components. Check to see if the fuse blew and that the output IC's or transistors (not sure what Crate used in these) are not bad. Check your speaker wire as well.
Jan 15, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
It will not work what colud be wrong
its a crate. 60% of all crate amplifiers go back on defects. take the top screws out and slide out the chasis, look at the fuse and determine if its toast. if the fuse is good, get a new amp. if the fuse is bad replace it and you should be good. the circuit board will have the correct fuse to be used printed on the board.
yostamplifier.com
Dec 30, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Bass amp blowing fuses
Hi
Go to www.ezrepair.ca and send it to us.
We will diagnose your unit for free and give you an estimate in a 48H maximum period.
Jun 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate amp blew a house fuse and stopped working. pilot light still works and I can get a distorted signal through the headphones if I play a guitar very loudly through it.
When a piece of equipment causes a fuse to blow or a breaker to trip, it normally means something in the equipment's circuit was shorted. Either because of heat, moisture, a loose screw, loose wire, loose part, a bug, etc. For safety reasons, don't plug it back in and take it to a repair shop.
Hope this helps!
Jun 04, 2009 | Crate Music
Crate tube amp will not power up but cooling fan tries to run
Yes.
Are you saying that the only indication that it is running at all is that the fans are running? So the tubes don't light up? No indicators on the front of the amp?
Power supplies that provide multiple voltages, which your amp has, can provide some of the voltages while having a problem that prevents them from providing others, all while not blowing a fuse. If you are not confident in your ability to work on a piece of electronic equipment that has 120VAC coming in and at least 175VDC or more present inside it, bring it to a service center.
The good news is that it is probably not horribly serious. Problems like this can almost always be repaired in a cost effective manner.
Feb 11, 2009 | Crate Blackheart BH15H Handsome Devil...
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
