Question about Plumbing
Moen kitchen faucet, motion sensor, model 87350ESRS, control box leaks from factory installed cold water supply hose.
  • 659 Answers
SOURCE: Moen 7065 leaking at base of lever control in kitchen faucet
Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
Posted on Apr 05, 2009
SOURCE: Moen single lever kitchen faucet leaking at base
check underneath spout ... if is plastic then is a "less expensive" model and the base and some internal parts may be also made of plastic. Is it a model 7100,7400 or 7600? this appears on stem on opposite side of spout... The base may be "out of round" (or "eccentric") from many yearsand may continue to leak even after replacing bottom o-ring. I have learned that if the faucet is older and plastic, advise the person to invest the money in a new Moen faucet: if you are paying someone to do the work, save time & money by having them make the switch instead of tryting to fix w/ a new o-ring, if you want to try to dis-assemble faucet and replace o-ring:
While you are changing o-ring might as well replace cartridge, get cartridge form same place you get o-ring, cartridges are supposed to be free (depending on hardware store) ...someone there should be able to help w/ dissasembly .. i hope ..
Plug drain(s) add some warm water to sink to be able to wash and rinse parts if needed, shut water off, relieve pressure by turning tap on ... plug drains!!! (tiny screws love drains...)
Most MOEN single handles: just pull top off straight up, most are just press fit on. This exposes screw. Before taking screw out make sure you have a clear area to set parts in order of removal taking care to remember alignment and order. Remove screw ...
Internal parts are usually threaded plastic so go easy on things ... unscrew retainers, remove lever control making note on how it engages the cartridge etc... this helps you figure out re-assembly
pull entire spout housing straight up (might resist a bit if crudded up) hold up to light and see if out of round.. you'll now see the brass interior...pinch out o-ring and replace. Silicone lubricant may help (get from same place as o-ring, cart. they should have little free packs..) slide spout housing back over ... re-assemble all in reverse, do not over-tighten plastic retainers, hand-tight ok .. if still leaks
might want a new one ... hope this helps
Posted on May 17, 2009
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
  • 127 Answers
SOURCE: Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
Posted on Oct 18, 2009
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    What is it when cold water runs hot doesn't
    1. Check hot water supply by testing other faucets.
    2. Check that the hot water hose connecting to the faucet is intact.
    3. May need to change the valve/cartridge.
    Jan 07, 2014 | Moen Chateau Loop-Handle Kitchen Faucet...
    Moen single handle pull out kitchen faucet is clogged
    There are flow checks in either the hot and cold supply lines, or there is one on the hose. It sounds like it is failing. If it's an older model, then the flo checks will be located right at the end of the two copper tubes coming out of the faucet, and can be removed using needle nose pliers. If it's a newer model, then the check is in the hose and the hose will need to be replaced.
    Jul 30, 2017 | Moen Plumbing
    I am having a leak with the hydrolock going to the sprayer hose on a new Moen faucet. I have taken it apart a few times to make sure it's together right, but I can't get it to stop leaking.
    Three years ago, I installed a Moen kitchen faucet with sprayer
    in one of my rental units. Moen twice sent replacement
    Hydrolock kits, as I couldn't get them to seal. While waiting for the Moen parts to arrive, I used a short length of heater hose purchased at AutoZone, held on by two small hose clamps. After all three Hydrolocks had failed to seal, I just left the heater hose in place. Three years and no problems. ..and no more Moens, either.
    Sep 16, 2011 | Moen 87530 Touch Control Single Handle...
    Re: Moen single-lever kitchen faucet like the 7100. When I replace the lever, it only goes up. I can't get it to go down. I'm pretty sure the cartridge is in right, with the U-clip and the other screw-on...
    The water supply should have no bearing on the working motion of the faucet cartridge or handle. On both models of Moen faucet, the handle needs to be hooked under the cartridge's top cam bearing. It is a bit tricky sometimes. Here's the parts view for 7300 and 7310 Moen Kitchen faucet. Parts view for 7100 Moen.
    If you need further assistance please let us know.
    Sep 16, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    Moen two-handle kitchen faucet, 1990's model installed new a few years ago, is leaking underneath at the center where the spray hose would connect. I didn't use the hose, though. The nut was tight. It...
    The nuts used for capping off the sprayer attachment will bottom out and not seal. Unless there is tape or thread compound on the nut, it can spray a tiny jet up under the faucet when the faucet is activated. If there is clearly water leaking from above that, then the o ring for the spigot may be failing and need replacing. If this is the case, it will only leak when the faucet is activated. There is always the possibility of a crack in the casting of the faucet body; hope not:)
    Aug 22, 2010 | Moen 7910 Chateau Two-Handle Kitchen...
    I have a Moen kitchen faucet with a leak.
    By "leak in the stem" I assume you mean you're getting water in the cabinet below the faucet. High likelihood is it's the hose - either loose where it connects to the faucet or the sprayer. You can pull it out and check to be sure it's tight at the sprayer. To check the faucet end, you'll need to be under the cabinet with a light. If you don't find one of those connections loose, it's likely one or the other is leaking, due to a hose defect or washer (or missing washer).
    The only way to see that is to turn the faucet on full (cold) with the sprayer pulled out and look for a leak in the hose behind the sprayer. If not there, leave the water running (may need another person to hold the sprayer) and inspect under the cabinet with your light for a leak either in the hose or at the connection to the faucet. If the problem is the hose or one of the nuts, it's an easy deal to buy a replacement hose - Home Depot stocks Moen.
    Feb 02, 2018 | Moen Plumbing
    Low hot water pressure in kitchen faucet
    I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
    Oct 14, 2009 | Moen & Replacement Cartridge
    I have very little water press on the hot water side
    Dis-assemble the faucet to get to the valve. The handle comes off and you access the valve from the top, usually by removing a screw on ring.
    You will robably find contamination in the hot side of the valve.
    You can find instructions on the Moen website.
    Sep 09, 2009 | Moen 7310 Legend Single-Handle Kitchen...
    Plumbing Logo
    531 people viewed this question
    Top Plumbing Experts
    Andrew Bugbee
    Tom Chichester
    Gil Shultz
    Are you a Plumbing Expert? Answer questions, earn points and help others
