Question about Vacuums
Hoover upright self-propelled drive vacuum cleaner u6331-93 will not self-propel
Replaced belt bit still won't work when i torn on red on switch on handle
  • Vacuums Master
  • 18,424 Answers
Here is a video how to fix
Posted on Jan 12, 2013
4 Suggested Answers
small6363
  • 18424 Answers
SOURCE: Hoover Windtunel Self-Propelled Upright Vacuum, Power Drive Not Working
have you checked the belt
http://www.youtube.com/watch?NR=1&v=wRoqZnZ4h0w&feature=endscreen
Posted on Dec 31, 2012
  • 59 Answers
SOURCE: Just replaced the belts on my Hoover Windtunnel II
Check the plastic part, which the the self propelled cable is attached to. (release the handle, tilt it back. You should be able to see the cable attached by a screw to a black plastic arm.) It is either broken or the cable is lose.
Posted on Nov 27, 2010
Agent Don
  • 310 Answers
SOURCE: installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
U6485-900 WindTunnel Self-Propelled I changed the belts but there is not enough tension on the brush drive belt to get it to rotate
I had the exact same problem with my Hoover U6485-900 Anniversary upright, self propelled, vacuum. It would move backwards and forwards, had good vacuum, but wouldn't pick up much because the brush/roller was not turning very well. I replaced the main drive belt (38528035) and it now works great. The old belt had stretched and was slipping under load. Thanks for the great suggestions.
Aug 02, 2013 | Hoover U6485900 Bagged Upright Vacuum
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Self-propel switch arm broke off where control cable was attached. Looking for instructions as to how to gain access to that switch arm to replace it.
Greetings from GoVacuum,
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
We have also put together a very helpful video for your vacuum cleaner on how to replace the belts. The belts on this model are also a frequent issue we see with these self-propelled Winddtunnels. In fact, for best results you should change the belts once a year, even if they are not broken, because they do heat up and stretch to a point where they don't work as well as a new belt would. The video also explains how you can maintain the roller brush will help you get the longest life possible out of your belts.
Video Repair on How To Replace The Belts Hoover Windtunnel Self-Propelled;
I hope that this information was helpful to you in repairing your Hoover. If you did find this helpful, may you please rate the repair by clicking the the Thumbs Up Icons in the top right hand corner of this repair to help me start out here on Fixya? I really do appreciate it, thank you so much!
Feel free to request a repair clarification if you have any questions or concerns you'd like to address.
Chris J.
GoVacuum
Feb 22, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Self propelled feature does not work. I replaced
There is a cable from the handle down to the transmission on this machine that breaks all the time or the cable is mounted to a plastic piece that is broken. That will need to be replaced.
Nov 28, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Installing belt on hoover self propelled upright vacuum
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jun 02, 2008 | Hoover Ultra U6430-900 WindTunnel Bagged...
Brush won't turn and self propel doesn't work
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=619779
Brush won't turn and self propel doesn't work (by 2 users)
Posted by brucelk on May 24, 2008
I have replaced both the v-belt and the larger belt with Hoover brand belts and the brushes still don't turn properly and the self-propel function doesn't work. It seems that when I lower the handle all the way down toward the floor it works fine, but no one can vacuum this way. Is there an adjustment to belts to tighten them up? Otherwise I have to get it in to the only repair shop in town which is an hour's drive.X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has the Same Problem Comment by chartsell, posted on May 29, 2008 I have replaced both the belts as well. I have tightened the screws as someone else as suggested. The brush still will not turn unless you lower the handle almost to the ground. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 Windtunnel Vacuum. It is not so much the belts, the 2 belts are only part of the solution. The average belt change is every 4 to 6 months as a rule and to change them @ the same time. The Hoover Self-Propelled works on when the handle is lower to a comfortable position then the self-propelled drive may just need and adjustment. There is a self-propelled rod that controls the self-propelled feature and it either needs adjustment or replacement or the part that hold it may be broken but either one can be fixed. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 24, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
61 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
