Question about NetGear WN2000RPT Repeater
I loose my connection
Internet connection stops working after app 1 hour, even though it shows that the signal is on top in to the machine. I have to disconnect and connect again to get it to work!
kap990
  • 28 Answers
SOURCE: can not connect to internet through wireless router...
First thing as ur able to access internet using ethernet cable, that indicates that ur router is fine. Now, also as u mentioned signal strength is excellent still its not getting connected, what u have to do is : click start then run type cmd and press enter it will open up command prompt or if ur using vista then click start >all programs> click accessories>right click command prompt>click run as administrator it will take u to the command prompt screen there  type ipconfig and press enter and check what is the ip address if ip address is like 169.254.----- then that it indicates that ur comp and router are not able to communicate wirelessly u have o set up a new wireless network. and if ip address is like 192.168.0.4 and default gateway is 192.168.0.2 then u don't require to setup a new connection  now in any case run this following command on the same command prompt window netsh int ip reset reset.log and press enter and then run this command netsh winsock reset catalog press enter it will ask u to restart and then restart the laptop after that try connecting if still not able to access internet then connect ethernet cable open internet explorer type in this address 192.168.0.1 and press enter it will ask for username and password that is admin and password respectively and it will take u to netgear settings  and from there setup a new wireles network......... try this if not able to do so revert to me.
Posted on Jun 03, 2008
physicistFL
  • 34 Answers
SOURCE: Netgear DG834Gv3 ceased to get internet connection.
Hello!
Hopefully if you try the following steps, you might be able to get to the problem.
Troubleshooting Steps
  1. Disconnect the router, and make a call with your telephone. If this does not work, contact your phone company.
  2. Reconnect the router, checking that all cables attached to the router and computer are secure.
  3. Check that the WAN light is green or blinking green. This may take several minutes after connecting or rebooting the router. If the WAN light is off or blinking yellow, contact your ISP.
  4. Check the LEDs for the ports with cables are lit. If not, move the cable to a different port. If there are still no lights, then troubleshoot light status, as explained in the router manual.
  5. Check if the LED on the Ethernet adapter in your computer is lit. If it is not, then troubleshoot the adapter, do not continue this document.
  6. Power off the router.
  7. Power the router on again.
  8. If you still cannot log on to the router, then do a hard reset on the router, as described below in reset router.
  9. If you still cannot log on to the router, try to get assistance from Netgear at www.netgear.com.
  10. Run the router's SmartWizard. This lets the router discover whether you have a static or dynamic IP address, and whether you are using PPPoE to connect to your ISP. (For routers without this utility, go to Step 14.)
  11. If a dynamic IP address is discovered, go to Step 15.
  12. If PPPoE is discovered, configure your router with the username and password from your ISP. Click Apply to enter the data. Go to Step 15.
  13. If a static IP address is discovered, configure your router with this information given by your ISP: the IP address for your router, the address of the ISP's DNS, and the address of the gateway. Click Apply to enter the data. Go to Step 15.
  14. If the smart configuration utility does not find an IP address:
    1. Power off the router.
    2. Power on the router.
    3. Go back to Step 10.
  15. Click Test to access NETGEAR's online test page. If the page displays, then you have Internet access!
  16. If the page does not display in a minute, you may need to do something called MAC spoofing, which I listed below.
  17. Find out if the modem's IP address can be seen by looking at the Router's Status Page, as described in the manual. If not, then reboot the router and computer, in that order. Wait for the router to completely reboot before starting your computer.
  18. If the router's IP is seen, then there is a problem with your browser's settings. Your security may be set too high for the Internet service you are trying to use, or your browser may be configured for a dial-up connection. In Internet Explorer you check this using Tools > Internet Options > Security > Default Level. If the slider is set to "High", change it to "Medium". Click Tools > Internet Options > Connections. If the radio buttons in the center are greyed out, then settings for a non-dial-up connection are being used.
Reset for routers with reset button on back panel Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password.If the router was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
MAC Spoofing
  1. Connect the computer that your ISP's installers used to establish Internet connection to the router.If you are unsure which computer was used, call your ISP, and ask what MAC address was registered. Then, using the instructions in the box below find the computer whose MAC address matches their records.
  2. Disconnect other computers from the router.
  3. (If you do not want to disconnect other computers, you need to know the adapter's MAC address, as described in the box below. Then, in step 6, type Use This MAC Address, entering the adapter's address.)
  4. In an Internet browser type the address 192.168.0.1.
  5. Type admin for the username, password (or 1234) for the password, and click OK.
  6. Go to the Basic Settings > Router Mac Address.
  7. Select Use Computer MAC Address.
  8. Click Apply. This automatically gives the router the computer's MAC address.
  9. Click Test to make sure you are connected. If you are not connected, contact your ISP.
I tried to get everything together to try to help you out.  Hopefully this stuff will get you online!
Ken
Posted on Jan 06, 2009
redhaze89
  • 854 Answers
SOURCE: internet disconnection intermittently
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
You might try Temporarily disabling your firewalls
Disabling Windows Firewall
Note: A firewall is designed to help protect your computer from attack by malicious users or software. Such software includes viruses that use unsolicited incoming network traffic that infects your computer. Before you disable your firewall, you must disconnect your computer from all networks, including the Internet. To disable your Windows firewall, please follow these steps:
Disable Internet Connection Firewall in Windows XP or Windows XP SP1
1. In the Control Panel, double click Network and Internet Connections. Then, click on Network Connections icon.
2. Right click on Local Area Network (LAN) Connection on which you want to disable the Internet Connection Firewall (ICF), and then click on Properties.
3. On the Advanced tab, you will see protect my computer or network check dialogue. Then, click on the Settings tab.
4. Click on OFF then OK.
Disable Windows Firewall in Windows XP SP2
1. Please click on Start, then click Run. Then, type in firewall.cpl and then click OK.
2. On the General tab, click OFF (not recommended) and then click OK.
Getting an intermittent connection from the router can be due to incorrect router configuration, wireless interference, firmware and even a hardware failure. If you are having problems from both your wired and wireless computers, you may try to bypass the router first and connect a single computer to the modem to check if you will get a stable Internet connection. If there will be no problems when you are connected to the modem directly, kindly check the following settings:
1. Please access the web-based utility of the router.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
2. Adjust the MTU setting.
a. Click on the WAN Setup under Advanced tab.
b. Lower down the MTU size to 1492, 1400, 1358 or 1300.
c. Click on the Apply icon.
Note: You may verify from your Internet Service Provider (ISP) the recommended MTU size you can use.
If after adjusting the MTU setting and you still are getting intermittent connections, upgrade the firmware of your router.
3. Upgrade the firmware.
a. Please verify the router version and model either underneath or at its side panel.
b. Go to http://kbserver.NETGEAR.com/downloads_support.asp and please select the model of the router.
c. Click the appropriate version of the router.
d. Select the link of the latest firmware. Click the button Right-click and Save to Download. Save the file to the Desktop.
Note: Please perform firmware upgrade with Wired or Ethernet connection only.
e. Before upgrading, please write down all current settings since you need to enter them manually.
f. Using the computer hardwired on the router, please launch Internet Explorer and access again the router's web-based utility (refer to step 1).
g. Click on Maintenance and then Router Upgrade.
h. Click on Browse and locate the upgraded file in your Desktop. Then click on Upload.
i. Please wait for the router to reboot.
4. After a successful firmware upgrade, you need to reset the router.
Note: Resetting the router will erase all the settings so it needs to be reconfigured afterwards. The router can be reconfigured using the setup CD or by manual configuration.
Posted on Apr 10, 2009
anandg27
  • 1272 Answers
SOURCE: Netgear wg111v2 wireless constantly connects and disconnects
Set the security on the wireless router to WEP and perform the steps below to configure settings:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jul 09, 2009
anandg27
  • 1272 Answers
SOURCE: Problem connecting to WNR2000 on laptop running vista
Perform the task below on the wireless VISTA computer:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
Regards
Anand
Posted on Sep 27, 2009
Bluetooth won't work all the time. Doesn't turn on. When it does turn on the screen freezes
well you failed to mention what model or even what processor you have , but I can tell you something from my own experiences with tablets , if you spent less than 200 bucks on it ,theres a pretty good chance your gonna have a Bluetooth not working ,doesn't allways turn on , screen freezing machine !!!!
good (fast) processors and memory costs money , i don't think that good deal is going to out preform a well built machine
Oct 20, 2015 | Tablets & eReaders
My face book works fine on my desk top but it stopped working on my I phone about two hours ago. can you help/
That happened to me this week, too. I tried hard closing the app, restarting the iPhone, updating the app - nothing helped. It turned out my wifi signal was strong, but my router was actually not connecting well to the internet. When I drove "off-site" (ie, Starbucks), FB worked great. Once I got my internet/wifi situation sorted out at home, FB works there, too.
Dec 20, 2014 | AT&T Cell Phones
Viber says that I'm not connected even though I'm connected to internet
I know that Viper has downloads for Mac, windows and other versions , did you down load the version to suit your work station. other wise log into viper and trouble search.
Oct 18, 2014 | Computers & Internet
Put my washing on at a 60 degree wash for 1 hour 40 mins. Went back to machine several hours later, there was tiny amount of water on floor and machine had water in it but the wash had not progressed any...
Sounds like a blockage perhaps the filter needs cleaning or pump blades jammed...If its a Hotpoint then filter is middle of sump hose connected to the drum....
Jan 06, 2011 | Washing Machines
Acer 4810T w/Vista it will not stay connected to internet
i doubt its your unit. if it shows your connected, your connected.wireless routers often loose signal. even if you have a cordless house phone it could easily interupt with your signal also. a lot of times it could be your service provider.
Oct 15, 2009 | Computers & Internet
IPOD Touch wont connect to internet?
Some troubleshooting techniques for this problem would be to connect to another network, maybe your neighbor's (one without a password) and connect back to your network, it could also be a problem with your router/modem even though it shows a full signal, try reconnecting your router or modem.. Whether this works or not, try using the "Easy Wi-Fi" app, its free, download it from the app store, and set it up, it could help in getting a signal or maintaining it. This is a common issue, and sometimes with the ipod touch it may connect and disconnect from the internet. If your computers or other devices are having the same problem you may want to consult your service provider. Hope I helped
Aug 23, 2009 | Apple iPod touch
On a Dell Latitude - no internet connection
The fact that the lights are on and that you get wireless signal means that the computer is making a connection with the router, but the router is not making a connection to the internet.
Try a sequenced power-cycle. Turn off the computer (completely off, not hibernating or sleeping), then turn off your modem (if you have one) and finally turn off your router.
Wait 5 minutes and turn it on in the backwards order. First the router, then the modem and finally the computer. If it's still not working, contact your ISP's tech support, there's probably an outage in the area or another problem with your internet service,
Aug 03, 2009 | Computers & Internet
Internet connection
What sort of modem/router are you using. I had a problem with a DLink which required an updated bios to stop it from turning off the wireless connection even though all the settings said it was to be always on.
Feb 04, 2009 | Computers & Internet
Ipod touch will not connect to internet
Solution #1 is always what apple agent do with iPhone and iPod touch calls. If that doesn't work they always recommend calling your ISP ( internet service provider ) however; you can actually do this yourself.
This may work but simply restart your router. Unplug your wireless G or B router from the wall. Wireless N routers will not work and are not compatible with both of these devices. Even though your computer may be working fine. The iPhone and iPod touches are not compatible with wireless N routers.
After disconnect the wireless router from the wall. Leave it unplugged for 5min or more, then re-connect it. This is called resetting your router.
After resetting your router turn your wi-fi off on your device and turn it back on and you should have some luck. If asks for password. enter in your password to join.
Jul 14, 2008 | Apple iPod touch
Internet connection not detected
Try desconecting the router for a few minutes. Then turn off your pc and power on again your router and pc.
Feb 26, 2008 | Linksys Wireless-G WRT54GS Router...
NetGear WN2000RPT Repeater Logo
47 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
