Question about Canon ZR850 Mini DV Digital Camcorder
Stuck in "Record Mode."
Used this new camcorder for 5 days with great results. Suddenly, it is stuck in "record pause" mode and I cannot get it out. I should be able to get it out by pushing the white start button, but when I do that nothing happens.
    Problem Solver:
  • 40 Answers
Take it back to the dealer while you can! Either let them show you how to prevent this or give you a new one.
Posted on Jul 14, 2007
SOURCE:
My panasonic vhsc camcorder will playback video and sound but it will not record sound what is wrong?
Sounds like the tape particles have stuck to the sound heads, just buy a head cleaner for camera, run it on record mode for 25 seconds max ok.
May 25, 2010 | Panasonic VHS-C PV-L354 Camcorder
Wont let me record! Flashes "Protection!"
My Samsung camcorder one day displays protection. Used or new tape no difference. Used the menu options to remove protection and it gives me a play mode alert. Regardless I can not record in protection mode. Help!
Feb 08, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Canon zr40 stuck in pause mode
Remove the battery.   Wait 10 seconds.  Put it back in and see if that resets it.
Sep 09, 2008 | Canon ZR40 Mini DV Digital Camcorder
Samsung vp-d351
proper focus in any camera will see colors ..or else record in b& w and in bad focus... make sure your macro mode is off and norm-auto on... most focus problems are due to dropping or stuck lenses.
night mode might mean your day sense has gone bad... the white balance etc.look for a default setting and turn it on.
larry
Aug 22, 2008 | Cameras
Doesn't record
Camera is in safe guard mode want you to remove and replace battery still in safe guard mode
Dec 21, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Help
Web link with the manual is http://www.rcapearl.com/pdf/TH11xx_IB.pdf
If your lazy he's the cut and paste from the manual;
1. To start voice recording, press M twice to access the Home menu.
2. Press or to highlight “Voice Recording". Then press to advance. (thats the key you would press to skip ahead a song)
3. Press or to highlight “Record”. Then press to access voice recording
mode.
4. Press when the display shows “Ready” to start voice recording.
5. Press to pause record. Press again to resume recording.
I had a hard time myself with this fuction so don't feel alone. I used the voice record to record a lecture and it was surprising sensitive but then again I had the professer put it in is front shirt pocket. It would over modulate a bit but was audioable and served its fuction for me
RoB Goins
RobertGoins@hotmail.com
Nov 22, 2007 | RCA OPAL M4001 MP3 Player
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Stuck in Play-Pause mode.
Simply press REC/PAUSE to return to normal Playback mode.
Sep 06, 2005 | RCA CC-432 Camcorder
Canon ZR850 Mini DV Digital Camcorder Logo
108 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
