Question about Asrock H55M-LE LGA1156/ Intel H55/ DDR3/ A&GbE/ mATX Motherboard H55MLE
Cmos battery type - Asrock H55M-LE LGA1156/ Intel H55/ DDR3/ A&GbE/ mATX Motherboard H55MLE
Clear CMOS Jumper JBAT
Unplug the power cord and remove the RTC battery,quarter size watch type battery, for 10 min's.Put the battery back in and power it up.that should clear the cmos
May 19, 2014 | Asrock 775S61 Motherboard
How to open case and change cmos battery on cs5111 also what type of battery
Not hard Ed if you look on the back of the case Most of the time the left side if you are looking from the front will have two thumb screws one top and one bottom. Pull those off then slide the cover off. The cmos battery will look like a big watch battery just pop it out and hit walmart or any drug store that sells watch battery's should not be to had to find
Dec 13, 2013 | ASUS Computers & Internet
Replace cmos battery and case openning
Asus motherboards usually use a lithium CR2032 battery for CMOS. Also, on the top of the old CMOS battery you took out there should be the exact battery type engraved on the surface.
Batteries Plus in Wichita, KS has a good online store for purchasing your replacement battery.
Dec 12, 2013 | ASUS CS5111-AP007
How to remove the cmos battery
The CMOS battery maybe under a palel on the bottom of the laptop or under the keyboard.
The CMOS battery maybe a coin size 3V lithium battery type CR2032.
Apr 21, 2013 | Acer Aspire One PC Notebook
Cmos battery error failure
The CMOS (BIOS) battery keeps the computer'a comfiguration and the Date & Time settings in the CMOS (BIOS) chip in its memory. When the CMOS (BIOS) battery is flat these configuration information is lost.
Replace the CMOS battery with a new one, in most cases this battery is a lithium 3 volt battery type CR2032 and it is coin size battery 18mm in dia.(check it to make sure the type of battery is installed on your motherboard).
When you replace this battery then go into the BIOS and set the Date & Time etc.
Jan 26, 2012 | Intel DG31PR Motherboard
I have an intel g41 motherboard....every time i switchon d pc...it shows check cmos error and the time and date are set to defaluts
This error occurs when the BIOS battery is flat. Replace the BIOS battery, most motherboards use a lithium battery type CR2032, this is a coin size battery. Check the BIOS battery type used on your motherboard before you purchase the battery.
After replacing the battery go to the BIOS setting and set the Date & Time etc. and you will not have this CMOS error.
Aug 10, 2011 | Intel Motherboard
What.s the useful of cmos in this board
CMOS Battery powers the real-time clock and CMOS memory, which retains all the BIOS Settings including date.
CreativeTECH
May 04, 2011 | Compaq (203966-001) Motherboard
My Laptop is Dellstudio15,When I swith on my laptop is showing error while booting it self is: Check date and time settings,System CMOS Checksum is Bad.Please help on this.
This error message means that its time for you to replace you CMOS battery.
CMOS battery is a small battery on the system board that provides power to the Complementary Metal Oxide Semiconductor (CMOS) chip, even while the computer is turned off. This chip contains information about the system configuration (e.g., hard disk type, floppy drive types, date and time, and the order in which the computer will look for bootable disks). The CMOS battery allows the CMOS to preserve these settings.
Hope this information willbe helpful. Thank you for using FIXYA.
Apr 13, 2011 | Computers & Internet
Clock not keeping correct time
There are different types of cmos bat on different motherboard. Some are coin-type. If you have coin type bat for your cmos, get the part number and replace it.
Mar 10, 2009 | Dell Computers & Internet
Cmos battery?
Computer CMOS information CMOS is an on-board semiconductor chip powered by a CMOS battery inside IBM compatible computers that stores information such as the system time
How to replace the CMOS battery. Information about why time may be lost or decreasing rapidly and how to replace your computer cmos battery
Computer Battery Help The first type of battery is the backup battery, which is commonly referred to as the "CMOS battery".
Good Luck, Please dont for get to Vote/Thank You
Dec 19, 2007 | HP Pavilion N3390 Notebook
Asrock H55M-LE LGA1156/ Intel H55/ DDR3/ A&GbE/ mATX Motherboard H55MLE Logo
57 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
