Question about AEM 2002 Chevy S10 Pickup - 4.3L V6 - Brute Force Air Intakes
How do I get to the fuel injector in my 2002 chevy s10 4.3 vortec motor
I need to find out how to get to the fuel injector so I can replace one of the injectors
    Genius:
  • 1,669 Answers
There is alot to take off the top of the engine to get to them so I recommend you pick up a Haynes service manual at your auto supply store to get the step by step procedure for your particular model and year.
Posted on Jan 12, 2013
How do I check the fuel injectors on 5.7 vortec motor
Get specialist help. You would need shop equipment to check all aspects.
Dec 29, 2014 | Enginetech General Motors 5.7 350 Vortec...
1996 Chevy z71 5.7 vortec. Changed motor and put everything back together and it will not start. Have good spark and fuel. But not getting fuel to injectors. If I take and poor fuel in the intake it tries...
There are several things that tribute to how the injectors fire, but the ECU is what actually fires them, the pick-up inside of the distributor is what tells the ECU when to fire them.
Jul 27, 2014 | Cars & Trucks
94 chevy k1500 v6 vortec acts like running out of gas on idle and when driving constant speed but not when i get on it help plz
Possible restricted injector poppets, you can try to run a heavy duty injector cleaner through the fuel rail , or you may need to replace the whole injector assembly.
Jan 13, 2014 | Cars & Trucks
My 1998 Chevy Blazer crank excessively when I try to start it. It always starts, and runs good when I get it started, but I would really like a smooth start. I have recently changed the fuel filter, spark...
leaky injector/s is flooding motor, mechanically clean or replace. And clean throttle body while you are at it with spray cleaner. Should be almost spotless where large throttle valve opens and closes.
Oct 21, 2010 | 1998 Chevrolet Blazer
I own a 96 chevy k1500 5.7 l vortec and have a no 5 cyl misfire
It could be a faulty fuel injector, try running a fuel injector cleaner through your fuel system. At worst the poppet nozzle has gone bad and will need to be replaced, you can buy the poppet nozzle it self individually at Auto Zone or buy upgrade MFI system which is much better and less pron to fuel leaking room a cracked poppet line or nozzle which will cause what you have described.
Feb 03, 2010 | 1999 Chevrolet Silverado 1500
1999 chevy astro wont start has spark and fuel preasure someone looked at and said they think a injector might be bad under the plentum does this sound right before i start tearing apart motor
if you vehicle has a Vortec engine it's possible for and injector poppet to spring a leak , My $$'s on the fuel pressure regulator . it's underneath the plenum (under throttle plate) and to the rear of the injector spider . most times it leaks fuel into the rear cylinders
Jan 17, 2010 | 1999 Chevrolet Astro
Gas not spraying at throttle body
replace the injector - before you do that test voltage going to the injector- is should pulse on and off to open and close it
Aug 03, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
What years 4.3 vortec will fit in my 2000 Chevy Blazer? Thanks!
The years of 1996 to 2002 with the engine code L35. Just becareful that the year 2002 is the change over year from L35 to LU3. The L35 fuel system is the SCPI (Sequential Central Port Injection)  The LU3 fuel system is the MPFI (Muilti Port Fuel Injection)
Good luck and hope this Helps.
Jul 20, 2009 | 2000 Chevrolet Blazer
1999 chevy blazer wont start
THE FUEL PUMP IS BAD.
if your losing fuel pressure after the pump runs the drain back valve in the pump has failed.
and i doubt that you are seeing enough fuel pressure to run a vortec engine.
low fuel pressure equals a non running vortec
Apr 11, 2009 | 1999 Chevrolet Blazer
AEM 2002 Chevy S10 Pickup - 4.3L V6 - Brute Force Air Intakes Logo
93 people viewed this question
Top AEM Tools & Hardware - Others Experts
D. E. Hev
Tom
Are you an AEM Tool and Hardware - Other Expert? Answer questions, earn points and help others
