Question about Minolta X-370S 35mm SLR Camera
Camera is dead: no LED lights in the viewfinder
Hi - this camera wasn't used for while (~2years). I added new batteries but it seems dead: no LED light are lighting up in the viewfinder and the shutter does not respond. Now, I saw many posts about shutter issues related to dried-out capacitors, but in all those cases, LED lights would work. Few posts alluded to "electrical" issues, like shorts, preventing power to pass to all the parts in the camera. I tested voltages out of the battery case, and on the circuit that you would see when opening the bottom of the camera, and voltage is fine over there. Anybody had the same problem? Anyone able to suggest what else I could check?
  • 3,828 Answers
Left unused for two years
=***** for a camera
see if it fits in the waste basket
Posted on Apr 06, 2017
poolseman
  • 206 Answers
SOURCE: film advance lever stuck
This sounds like shutter release problem and can be fixed by replacing a 3v 220 mf capacitor ( leaking by now because they do not last more than 8-10 years and your camera is 25 years old ). You can do it your -self but will need a soldering iron and a replacement capacitor : remove bottom cover and locate small ( usually black in colour ) capacitor on the right hand side of the camera. Unsolder -- keeping an eye on polarity which is marked on the outside of the capacitor-- and replace with new one. Switch camera on and it should release the shutter and you are back in the saddle.
Posted on Nov 14, 2007
cammedic
  • 667 Answers
SOURCE: My camera doesn't work when I press the shutter release
I think the timing of the shutter winding gears has slipped a tooth or two. look at the picture in this image:
http://www.twid.de/x700/pic03.jpg
Near the motor drive coupler at the bottom you will see a blue and a white gear. Look closely at the blue gear and you will see a line on the top of it. That line needs to be pointed at the center of the white gear when the camera has been released and ready to be advanced again.
If you wish to proceed, I will tell you how to re-time the gears.
Posted on Feb 28, 2008
  • 185 Answers
SOURCE: new batteries...yet it still does not function.
Was the battery's removed before storing camera? If not corrosion on battery cap and contacts in battery holder. Clean with a pencil eraser, careful with the contact in battery comp.
If not fixed then you have flex circuit problems and that means your camera is a" paper weight" as no parts are available for this model.
Posted on Dec 07, 2008
ftw1952
  • 10319 Answers
SOURCE: Minolta X 370 Light Meter woes
Posted on May 23, 2009
  • 44 Answers
SOURCE: Minolta X 300 camera On replacing batteries
on this camera can you lock shutter button down?
may have moved it changing battery.
take out battery may release it
is battery up the right way?
Posted on Feb 15, 2010
In my mp9 camera battery charging is not working and the camera is not switch oning
If you had it stored away for a long period, the batt is dead. Get a new one and give it a try again.
Nov 06, 2015 | Cameras
There is something wrong with my Nikon D3000. It turns on but doesn't show anything on the screen and when I look through the lens it's shows a grainy dark film. It can't be the lense because I...
There seems to be two separate issues here. I'm going to assume you have a charged battery pack in the camera.
First, the screen. Turn the camera on. Do you see the menu when you press the MENU button? Does the shooting info show when you press the Info button? Can you see previously taken photos when you press the Playback button? If none of those show up then something is wrong with the screen (or the battery is dead).
Second, the viewfinder. First, make sure the viewfinder in the back is clean. Now turn the camera on and look through the viewfinder. Do you see the eleven focus marks? Do you see the info at the bottom? Now turn the camera off and remove the lens. Don't touch anything inside the camera! Do you see a mirror at a 45-degree angle? Is it clean? Look at the focusing screen above the mirror. Is it clean? Now look through the viewfinder and point the camera out a window. Do you see a more-or-less white blob, or the same grainy dark film?
Apr 11, 2013 | Cameras
I have a Nikon N65 and put new batteries into the machine. I can't seem to find a thing wrong with it but the screen won't turn on. Any suggestions?
If there's a battery check button, try that to see if you're getting power elsewhere, or see if the functions inside the viewfinder are working. Check to see if the battery contacts are dirty or corroded. If so, use the eraser of a pencil to clean them. If that doesn't help, there's either a dead circuit, or a loose contact and you'll need to contact a repair tech.
You can either contact Nikon directly, find a local reputable shop if you have one in your area, or if you have to go through an online dealer I'd recommend KEH Camera (KEH.com)
Sep 03, 2011 | Nikon N65 35mm SLR Camera
I recieved a brand new Canon Rebel XSi in the mail. I throughly read the manual & assembled it carefully by the book. Kept it in all the correct settings. Also kept it in a warm, dry area. I grabbed...
Hi
You can try doing the steps below
1. Remove the battery from the camera
2. Remove the Memory chip
3. leave the camera for an Hour
4. After which you can install the battery only first
5. Recharge the camera first
6. Later when the camera is charged the battery
7. Install the chip if available
HOPE THIS WILL SOLVE THE PROBLEM
RATE MY SOLUTION
Jul 02, 2011 | Canon EOS Rebel XSi Digital Camera
Problem with viewfinder - focus?! I've been using my Nikon d3000 for over a year now. Few days ago I tried to take a photo but when looking through the viewfinder, the photo wasn't focused. It was...
There's a diopter control near the viewfinder to adjust the viewfinder to your eye. Try adjusting that while peering into the viewfinder and try to get the focus brackets and the data at the bottom of the viewfinder into focus.
Jun 20, 2011 | Nikon D3000 Digital Camera
C50 olympus power up
Is suspect the battery has been damaged Tell me more about the leaving in the USB port- this is not the normal way a battery is charged. Is it different for this model of camera?
Aug 14, 2007 | Olympus Camedia C-50 Zoom Digital Camera
LED light by viewfinder solid yellow(orange) and Camera won't turn on.
Is the color of the LED yellow, or more towards orange? This is what the manual has to say: ? Signal processing in progress after photography ? Charging of flash in progress (Photography is not possible.) If the first option of the 2 is what has it stuck, I would suspect a problem with the card, which you could test using another known good card, or it could be a problem with the camera's processor, which is already a serious repair. If the second one is causing this(charging flash), It's also one for the lab, but not as bad as the other one. Good luck, keep in touch(let us know how it turned out) ;]
Jun 13, 2006 | Toshiba PDR-M5 Digital Camera
Charging battery
Hi Pat, When charging the battery the light should definitely be red. When it turns green it's charged. I would exchange your camera for another PDR-M5 if you can. I actually had to do the same thing - noticed a big difference with the second one - including fit and finish....think that maybe Toshiba has a quality control issue. I just returned mine (second one) yesterday - was a hard decision - love the features - 3X zoom - video - speed, etc.....but got fed up with the picture quality indoors - too many out of focus - couldn't count on it. Also all pictures - in/out - tended to be dark - drab looking - always had to lighten using the software before printing. This is a $1250 camera in Canada after tax w/extra 16 meg smartmedia which you need at the minimum so there are no excuses. Hope you have better luck with yours!
Sep 15, 2005 | Toshiba PDR-M5 Digital Camera
Minolta X-370S 35mm SLR Camera Logo
61 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
