Question about Brother CS6000i Computerized Sewing Machine
I HAVE A SINGER CURVY 8780 SEWING MACHINE AND I CANT GET THE TENSION CORRECT THE MACHINE SEWS FOR A COUPLE OF INCHES AND THEN BEEPS AND STOPS SEWING. MY BOOK DOESNT GIVE ANY SOLUTION FOR THIS
bargainbox
  • 1388 Answers
SOURCE: stitching looping
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....the question you pose could have 2 meanings....this reply is for looping thread.
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
cc3f045.jpg...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes. ie a different colour top and bottom just for the test.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is, and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine case....no case ? then make some sort of cover ! Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you need any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 23, 2008
dizzythevamp
  • 9 Answers
SOURCE: Brother Sewing Machine CS-100
actually e2 is the button hole lever being down. e6 means that the thread is tangled and to prevent the motor from overheating the machine automatically stops. All you have to do is re-thread the machine and take the bobbin out, untangle it and put it back in and sew. This usually works. If it keeps happening, there could be a few things wrong.
1. if you are using thick fabric your tension should be lower. normal tension is 5.
2. your machine is out of alignment. take it in to a service center, they can fix it in 5 minutes. to find a service center near you go to http://www.brother-usa.com/service/
3. your needle is old or bent and should be replaced.
4. Your needle is too thick, standard is 80. The thicker the fabric, the thicker the needle.
Posted on Jan 06, 2009
Sewtech1
  • 69 Answers
SOURCE: Tension problem?
Make sure the machine is threaded correctly.
Make sure your tension is set on 5.
Check and make sure there is no fluff or cotton stuck in your upper tension unit(Between the tension plates
Posted on Jun 28, 2009
bargainbox
  • 1388 Answers
SOURCE: top tension is making a loop as I sew, bottom
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
TOP THREAD TENSION:
BOBBIN TENSION:
TOP LOADER:
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
back properly.
165ca5c.jpg FINISHING UP
OTHER ISSUES:
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Aug 19, 2009
SOURCE: sewing machine XL 5500 settings
Your bobbin is probably too loose. When you set a new bobbin, stop every now and then and try with your fingers nail if it's nice and tight enough. Not extremely tight, but tight, not loose and moves easily when you set your finger between the threads.
With most fabrics (99%) the plate is fine at the the top position, just with very thick and "fragile" (satins etc) you might need to adjust it.
Settings: Tightest tension for the thinnest materials, more loose for the thicker ones, better have a test piece, it rarely goes under 5 anyway.
Posted on Aug 25, 2009
I have a Singer Curvy 8780. All I want to do is sew a straight stitch. What are the settings?
You'll need stitch pattern 01 in the first group after you press the utility stitch button (top button on the left of the 4 way arrow keys). Press button A (the left most up-arrow below the LCD screen). Use buttons B (move left) & C (move right) to select the needle position and D (shorter) & E (longer) to adjust the stitch length. E is the right-hand button in the group. Start with the tension set to Auto and adjust as needed based on your fabric and thread. For normal straight seams, start with the default settings.
Singer has the manual for the Curvy 8780 on the product site: http://www.singerco.com/products/1545/8780-curvy#type-support . The direct link to the manual is http://www.singerco.com/uploads/download/089a99d1802347d9441d83e8a591e6d0db17b80c.pdf . See page 30 for the stitch pattern; page 40 starts a longer discussion of straight stitching.
I hope this helps.
May 25, 2016 | Singer Sewing Machines
I have a singer curvy 8780 I can't sew at all as soon as the needle goes down the machine makes one long beep and the display screen goes blank. The display is still lit but shows nothing. Help
Sounds like your machine is experiencing a failure of a computer component. Suggest service or, if cost prohibitive, looking for a new machine.
Nov 14, 2015 | Singer Sewing Machines
How do i make my singer curvy 8780 stop sewing after i have finished sewing my fabric
Sounds like your brushes in your motor are worn. Either that or your foot peddle is sticking.
Feb 23, 2015 | Singer Curvy 8770 Electronic Sewing...
My singer curvy 8770 keeps beeping and stops I have cleaned it retarded threaded it sews for a minute then beeps then stops continues.this machine is only 3 months old I need some answers
Are you getting any error messages? This page may help: http://www.manualslib.com/manual/364636/Singer-8770-Curvy.html?page=30
It would be something really simple like the bobbin winder not completely in the right position. I hope the troubleshooting page will help.
Jan 17, 2015 | Singer Curvy 8770 Electronic Sewing...
Sews about 5 stitches then stops and beeps. stitches look fine, just will not keep sewing
count the beeps and refer to the owners manaul as for troublshooting tips
Dec 03, 2013 | Singer 8780 Sewing Machine
Singer curvy beeps twice and quits sewing
I have the same problem and no any solution, someone can help, please.
Mar 05, 2013 | Singer Curvy 8770 Electronic Sewing...
Singer 2009 Athena ( came with singer Curvy instructions as the machines look Alike). The machine sews a few stitches and then beeps and stops. I have ruled out the auto buttonhole pulldown lever, and the...
sounds like the new top tension dial is not working either
there could be something wrong with the computer part of the machine
is the power cord plugged in correctly?
also is the foot pedal plugged in correctly?
have you had the foot pedal check to see if there is something wrong with it?
I would suggest having the machine check, there are lemons even in sewing
machines
May 31, 2012 | Singer Sewing Machines
Singer 8770 beeps twice then stops stitching
do you have a manual?
try a new needle
adjust the top tension
try rethreading the machine top & bobbin
May 16, 2012 | Singer Curvy 8770 Electronic Sewing...
Singer curvy beeps 4 times and stops sewing
when you thread the machine make sure to use every thread guide
check to see if the bobbin is in correctly
try changing the needle--normally flat side goes to the back
the needle that your sewing with is it the right one for the thread & fabric
clean under the needle plate & bobbin area for lint or loose threads
Mar 31, 2012 | Singer Curvy 8770 Electronic Sewing...
Brother CS6000i Computerized Sewing Machine Logo
117 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
