Question about Keurig Elite B40 Coffee Maker
Need water pump
My machine will not pump water to make coffee
  • 1,511 Answers
Call the company at 1-866-901-3739 for assistance.
Posted on Feb 01, 2014
Fault on Siemens TK76K573, after pump replacement
The water passages in the espresso makes may be clogged. Please descale the machine. Depending on the period for which the descaling was not done, it may need nore than one descaling cycle to remove accumulated Calcium deposits.
Calcium deposits narrow water passages and reduce the pump pressure to push water through the coffee grounds.
Oct 18, 2014 | Coffee Makers & Espresso Machines
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
Coffee machine problems
Does the pump work? The steam and hot water are from the boiler pressure, but the coffee water circuit is separate and needs the pump.
Does the three way solenoid valve click when you try for coffee?
Why did you change the control box, what was the original fault?
Oct 19, 2013 | Coffee Makers & Espresso Machines
Ascaso dream is not pumping water
If you can hear the pump running, I would say you have some blockage in the line
Apr 12, 2013 | Ascaso Dream Espresso Machine
We have this machine that we purchased in Italy in 1995 and it heats (left button) and steams but I can't get the water to pump (right button) through the coffee to go into the cups. Makes a loud clicking...
Obviously you have problem with non return valves at the pump, they are built inn the pump.
  • Remove the filter holder, open the steam valve and command brewing coffee. If water comes from steam valve close it> continue brewing and wait the water from coffee group. After this procedure test it with coffee.
  • If testing with coffee is successful you may work with that pump but always be careful to not leave empty water container.
  • If testing isn't successful you need to change the vibration pump.
Feb 24, 2011 | Elektra (SX) Espresso Machine & Coffee...
When I press the button to select a large cup of coffee the water will run for about two seconds then stop but the pump is still running and the third light stays on. Even when I pull the plug and reset it...
I read a couple reviews on this machine, and it could be that your water pump is bad and need to be replaced.
Another problem could be that the bay beneath the coffee cup is full with water and needs to be drained. I have an nespresso brand espresso machine, and when this bay becomes to full with water, the machine stops brewing espresso/coffee. This function is there to prevent water messes.
These are the only possibilities I can think of. Good luck.
Nov 27, 2010 | Keurig B60 Coffee Maker
My Gaggia Baby C coffee maker has stopped pumping water
From what you have asked the only thing I can suggest is that the pump needs to be replaced. Do you hear the pump vibrating? The lines from the pump may be blocked. Have you tried to descale the machine.
Jun 06, 2009 | Gaggia Baby Espresso Machine
My kitchenaid artisan coffee machine not enough water
if you have water out brewing without handle with coffee, than you check this 3 things:
  1. how fine is grinded the coffe, is it too fine for your machine?
  2. does pump make enough pressure to brew your coffee(you can measure if you attach an gauge to handle or steam pipe.
  3. by any chance your boiler security valve opens too soon and dont let pump to get the needed pressure. (perfect pressure is from 7 to 9 bar)
Mar 31, 2009 | KitchenAid Artisan
Gaggia Espresso Machine bought about 10 years ago
  1. if it is fine ground coffee sometimes you get this result at machines.
  2. low pressure pump = you get water from it but only when handle is out or steam valve open.
  3. pump with non return valve broken = in this case you get water if you open tea valve during pump works. this pump can work long even she has 1 valve damaged, only when she is empty you need to open steam valve and leave pump running while you don't get water from valve.
Feb 15, 2008 | Gaggia Espresso De Luxe Espresso Machine
Keurig Elite B40 Coffee Maker Logo
242 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
