Question about GE Spacemaker Washer and Dryer Electric Laundry Center
I need to know how to remove the drain pump from the back of my GE Spacemaker washing machine.
I have the back off and checked the hoses for kinks or something plugging them up( which is not the case) but I don't want to break any of the plastic parts by removing it inorrectly
    Sergeant:
  • 291 Answers
I'm pretty sure the drain pump is in the bottom left or possibly right corner of the machine. The hoses on the back of the machine are going to the inlet water valve. Can you clarify?
Posted on Jan 12, 2013
gittos73
  • 244 Answers
SOURCE: Fixing a clogged pump on GE Profile washer
waht u need to do is get a bucket now take the outlet hose and place it into it low to the ground if water comes out then it will be that your pump is faulty and needs replacing but if it doesnt the only way to do it is towels on the floor and with a low pan place this under the sump hose which should be in the middle of your drum which then leads to the pump pull slowly but not enough for the water to push the hose of do this until empty the only other way is to take it outside and pull the outlet hose of this is the quicker and dryiest out of them all but do do the first part to c if the pump is faulty m8
Posted on Dec 12, 2007
MNTECH
  • 1543 Answers
SOURCE: GE WJSE3110A washer, won't drain
On a scale of 1 -10, I'd rate this about a 3.5 in difficulty.
Un plug machine.
Use a putty knife to push the clips in at the seam of the front panel and the washer's top, about two inches in from each side to allow you to pull the front panel forward and then lift it off the bottom pegs.
If you took off that drain hose, you shouldn't have any water left in the machine, so take the two squeeze hose clamps off the pump hoses, the electrical wires off the pump, and the two 3/8 size bolts holding the pump to the washer's base.
Now check to see if the pump is plugged or obstructed with an object. Replace pump with cleaned out or new pump as necessary.
Posted on Dec 10, 2008
SOURCE: GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Posted on Mar 27, 2009
SOURCE: GE washer WSXH208AWW does not spin and drain out.
my GE washer does not spin out all the time on final spin
Posted on Dec 31, 2009
SOURCE: My GE space saver stackable washing machine will
Im haveing the same exact problem on the same exact machine... I have taken all the pannels off, and drained the water. I was wondering if there may be a way that the pump lost it's prime and needs to be re-primed? (wishfull thinking on my part.) There was no indication that the pump burnt out, it just stopped working instantly with no symptoms. The other functions seem to work, it will agitate the laundry, and then will just stop when it comes to the pump cycle. Any help is appreciated. Thank You.
Posted on Aug 05, 2010
My GE spacemaker top loading washer GUD27ESSJ0WW won't drain.
Most likely the drain pump is plugged with a soak or other small item.
Jun 19, 2017 | GE Washing Machines
Washer won't drain
the drain hose is on the back. it's generally the biggest hose on a washing machine and in most cases black. it could be kinked or clogged. once you locate the hose it's held on with a clamp. undo the clamp and it pulls right off. if no clog or kink there follow the hose to the drain usually on the wall and look there. I doubt it would be or else you would have water all over the floor so my guess is it's not even leaving the washing machine. Also something to keep in mind is that it could be the pump that draws the water out.
Jul 14, 2012 | GE Spacemaker Washer and Dryer Electric...
GE Profile model WPRE6100 only spins slow....
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks and good luck.
    Oct 02, 2010 | GE Profile WPRE6100G Top Load Washer
    Machine will not drain or spin
    Please donot forget to rate and accept my answer...
    Un plug the washer again for 30 seconds plug back in press the start/pause button then press power...This will try to reset your washer.. If it didnt work your pump must be checked...
    Apr 19, 2010 | Roper RAS8445KQ Top Load Washer
    GE top load washer will not advance to drain and spin
    Apr 15, 2010 | GE Profile WPRE6100G Top Load Washer
    Washing cylce completed but is not draining to begin the spinning cyle.
    Apr 14, 2010 | Fisher and Paykel Washing Machines
    GE model number WWA7070VBLHA machine will not
    first,check for any obstructions in the tub to pump then from the pump to the house drain,including and kinked hoses,if the washer senses any back pressure from these it won't drain or spin,also check the pump inside to make sure there are no impellers broken or missing on the pump or debris inside the pump
    Apr 01, 2010 | Washing Machines
    Ge spacemaker spins but wont drain
    first check your hose make sure it not pinched... next you can check the coin trap...its at the back where the drain hose goes in the machine.... turn it and pull it out ... make sure you have something to catch the water....if this do not help you may need a new drain pump... let me know
    Sep 22, 2009 | GE Washing Machines
    Wisr409 machine can't spin
    hi friend,
    Step 1 A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
    Step 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
    Step 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mowermag-glass_10x10.gif or even a bicycle chain should be able to accomplish the task.
    Step 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
    Step 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
    thank u for using fixya
    regards,
    sivaranjini
    Aug 06, 2009 | GE WBSR3140DW Top Load Washer
    Washer does not drain water
    Make sure the drain hose is not kinked
    Dec 27, 2007 | GE Spacemaker WSLP1100D Top Load Washer
    GE Spacemaker Washer and Dryer Electric Laundry Center Logo
    Top GE Washing Machines Experts
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
