Question about Lucent PARTNER18 Corded Phone
How do I progam ringer to ON - lucent partner-18?
The ringer on one of our lucent partner-18 phones does not work.
I do not have a manual. Could you please let me know how to do this function?
Many thanks!
  • 19,396 Answers
From manual:
Line Ringing
This feature determines how each outside line or pool assigned to an extension
rings. You can specify Immediate Ring, Delayed Ring (telephone rings after a
20-second delay), or No Ring.
Delayed Ring is useful for backup coverage on shared lines or pools, such as for
secretaries who cover each other’s lines. No Ring is useful for all extensions
except 10 when an operator answers all calls, or for telephones with no regular
users, such as those in conference rooms.
To change the way outside lines or pools ring at an extension:
1 Press f00ssc at extension
10 or 11.
2 Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all lines or pools assigned to the extension.
The following ringing options can be shown by the green light next to the line or pool button:
• Immediate Ring — on steady
• Delayed Ring — flashes slowly
• No Ring — flutters quickly
• Immediate Ring is the factory setting for lines; No Ring is the factory setting for pools.
3 Press the line or pool button until the button light shows the correct setting
4 Continue programming, or exit programming mode.
Posted on Jan 23, 2009
    Brigadier General:
  • 3,614 Answers
Make sure and check this of the following SETTINGS on the Handset feature is turned on.
A. Check the Do Not Disturb or Call Forwarding is turned on.
  • If Do Not Disturb or Call Forwarding is turned on, turn it off.
SECOND:
B. Check Line Ringing is programmed for No Ring or Delayed Ring.
  • Check the Line Ringing setting for the extension.
THIRD:
C. If Line Ringing is set for No Ring or Delayed Ring, change the setting if appropriate.
If Line Ringing is set for Immediate Ring and this phone is part of a combination extension,
Extensions: Phone Does Not Work Properly.”
  • If Line Ringing is set for Immediate Ring and the phone is on an extension by itself.
LASTLY;
Check and DO this next instructions;
  • Unplug the cord from the base of the problem phone and plug the cord into a phone that you know rings properly.
  • If the replacement phone rings properly, the problem phone is defective. Call the AT&T Helpline* to arrange for a replacement.
Posted on Jan 22, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
To program the ringer---
1 Make sure the handset is off.
2 Press G, #.
3 Press 1, 2, 3 or 4 to select your ringer style. You will hear a
sample of the ringer style and the screen will display your selection.
4 Press O.
Turning Ringer Off
Press G, #.
2 Press 0.
3 Press O. The screen displays RINGER OFF SELECTED.
Checking Handset Ringer Selection
Press G, #.
2 Press #. You will hear the current ringer style selection.
3 Press O.
Handset Volume
Adjust the handset volume by using + (increase) or - (decrease) on the left
side of the handset. There are four volume settings.
Ringer Mute
Press M while the phone is ringing to silence the ringer during only that
call.
Temporary Tone
NOTE:
If you have touch tone service, you do not need to use the
Temporary Tone feature.
If you have dial pulse (rotary) service, this feature allows you to enter codes
or tones needed to operate answering machines, or use electronic banking
services, calling cards, and other special services. This feature will operate
most special services; however, some services may actually require a touch
tone line. To be sure, ask the company that provides the special service.
1 Dial the call, then press *. Any buttons pressed after this send tone
signals.
2 After you hang up, the phone automatically returns to dial pulse
(rotary) dialing.
  • Rylee Smith
    Rylee Smith Jan 22, 2009
    Read G as Prog and O in 4th step as off. Error is regretted.
    Sergeant:
    Scholar:
  • 199 Answers
  • 13,433 Answers
Have a look at this manual
http://www.getempire.com/media/guides/manuals/partner/456804_6.pdf
chapter 5 was about programing the features.
    Brigadier General:
  • 5,158 Answers
To adjust the ringer volume:
  • To increase volume, press + or how do I progam ringer to ON - lucent partner-18? - button_up.gif while the phone is idle
    or ringing and the handset is in its cradle.
  • To decrease volume, press - or button_down.gif while the phone is idle or ringing and the handset is in its cradle.
I need to make one of our lucent phones ring. It was set not to ring at this extention, but now we need to hear the phone and I cant find my instructions.
If the do not disturb feature is in use, try pressing Feature 0 1 (this requires a button with lights). If you were automatically forwarding calls from this extension, press Feature 1 1 then dial the extension number twice.
If you need to increase the ringer volume, then press + or up arrow when the phone is idle or ringing and the handset is in the cradle.
The manual for some Avaya phones are available here: http://support.avaya.com/css/Products Look under P for the Partner series manuals.
I hope this helps.
Feb 14, 2011 | Avaya Lucent Partner 616 Phone
We have a Lucent partner 18-d phone system. Display is telling us to replace systembattery. We cannot locate this.
The "18-d" is the telephone set model. The Partner System control unit is where you will find the system battery. It is located in the Processor Module - usually 2 AA batteries.
Nov 19, 2009 | Lucent PARTNER18 Corded Phone
Partner 18 phone
No reply in a long time.
Closing
Aug 27, 2008 | Lucent PARTNER18 Corded Phone
Manual
A simple Google search found a manual covering the Avaya (Partner) 18d phone.
It can be found here:
Good luck.
Mar 05, 2008 | Avaya Lucent Partner 616 Phone
CHANGING FEATURES? ON LUCENT PARTNER-18
from extension 10 or 11.
feature 00
pres the speed dial you want
feature 600, thype the number in.
repeat for as many as you want to modify
when done, press feature 00
Jan 22, 2008 | Lucent PARTNER18 Corded Phone
Lucent Tech Partner 18 phone manual
www.telemanuals.com
If the message waiting light is on. Is it lit on ext 10? If so, there might be a message in the general mailbox.
Log into voicemail
Use mailbox 9991 #
password is 123456 #
See if there are messages in there.
Dec 14, 2007 | AT&T Partner 18 Phone (315805B)
Ringer for Lucent Partner18D
Are you trying to change if it rings or how it sounds when it rings?
The phone you have (Partner 18D) can be used on several different Avaya phone systems that all program differently. To change when it rings, this would need to done in the system programming (not the phone) All the manuals are avaialble on Avaya's web site but you need to know which system you have before you can start searching. www.avaya.com
Nov 26, 2007 | Lands Phones
Lucent PARTNER18 Corded Phone Logo
252 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
