Dvd read problem
I have a problem with my dvd (gsa-h21l) has a read problem it doesn't recognize any dvd (empty and/or full of any kind).i try to update the original software from hp but it doesn't work,i can only read and burn cd's.
my pc is a hp desktop win xp proff. sp3 installed,conf. is amd athlon 64x2 dual core3800+ 2.00 ghz 2 gb ram and up to date.just a few months ago i installed nero and i guess than the problem started.
any advice will be highly appreciated...
  • roboraptor Jan 23, 2009
    hi cezlec_06,
    i try it exactly as you've explained it,but nothing changed it won't read or write any dvd's (try it with many different brands maxell-tdk-sony-etc) .any other idea ?!
    thks in advance...
    Problem Solver:
  • 6 Answers
Check the firmware first in the device manager
1. Right click on my computer and choose manage.
2. Under Computer Management, Click on Device Manager
3. Check the dvd/cd-rw device and check if it has a yellow exclamation point or an x mark on it.
-if it has an x mark. you just need to enaeble it or install the updated driver or firmware for your dvd drive but if none or it has an exclamation point continue the steps below:
DELETE upper and lower FILTERS in the Registry Editor
1.Click on Start. Then type in run or the search box, REGEDIT
then click on regedit. A new window will appear which is the registry editor.
2. Click on the plus sign for HKEY_LOCAL_MACHINE
3. Click on the plus sign on SYSTEM
4. Click on the plus sign on CURRENTCONTROLSET
5. Click on the plus sign on CONTROL
6. Click on the plus sign on CLASS
7. Click on the FOLDER for (4D36E965-E325-11CE-BFC1-08002BE10318)
8. On the left pane you should see the UPPER FILTERS or the LOWER FILTERS or BOTH. DELETE BOTH if possible. Right click on it and click on deleter. Once deleted go back to device manager
9.Click the plus sign On the dvd/cd drive in the device manager, and Right click on the firmware and choose uninstall.
10. Click on ACTION in the device manager and choose scan for hardware changes.
-It should automatically detect and install the firware for your dvd drive. You should be able to play any dvd again.
-This problem might be happening because your firmware for the dvd drive is interfering with the burning software that you installed on the system which is NERO.
-Your feedback will be appreciated. Thanks.
Posted on Jan 23, 2009
  • cezlec_06 Jan 23, 2009
    Uninstall your NERO software and then Install it again.
    -go to contorl panel and choose add or remove programs. Uninstall NERO there.
    -Install K-lite codec pack.http://www.free-codecs.com/K_lite_codec_...
    -DOWNLOAD the STANDARD.
    -install it and restart the computer.
    cHeerS!
I have the same problem my DVD-ROM can read CDs but not DVDs I tried your advice but it doesn't worked, If u have a sulotion for me please write me on dardi.idrad@live.com
Posted on Jun 11, 2009
MY HP DVD WRITER HL-DT-ST DVD RAM GSA-H20L WILL NOT RECOGNIZE CD'S OF ANY TYPE AND VARIOUS DVD MEDIA
ya... its lens/laser is getting ruined...!
such symptoms are quite obvious.
check it would be able to read non-empty Disc(pre-written CD's).
but not able to detect/read empty disc.
May be it can read and write branded Disc which comes in packing case such as "sony"
but not ordinary disc which are sold in loose packing.
if it is under warranty period. then it will be repaired or replaced free of cost.
Apr 11, 2011 | LG GSAH20L DVD±RW Dual Layer Burner
LG GSA-5169D DVD w/ Honestech One Touch on Win XP SP3
You got a bad laser in the drive not the laser the reads the laser that writes and this does generally happen when a dvd ram drive goes. Recommend buying a new drive as a replacment laser is upwards of $90 bucks, thanks for using fixya please do accept and rate.
Aug 18, 2009 | LG (GSA-5169D) DVD RW Dual Layer Burner
GSA-H10A CD/DVD not recognizes as a burner
Hello my friend, how are you? regarding on your problem kindly try nero burner software. Here's the link where you can download nero for free. Download Nero Burner.
Kindly install it in your system and then try it... I am using this burner for almost 10 years... Hope it will help your problem solved.
If you need more assistance just reply to this post.
Thanks
Jul 16, 2009 | LG GSA-H10A Burner
My HP GSA-H21L lightscribe burner drive will play a CD but doesn't read a DVD nor will it burn a DVD. Don't know what the problem is but sure would like to! Can someone help? Dee Nickens
There was a known problem with the firmware of HP GSA-H21L lightscribe burner where it will read CD and not DVD.
You can try upgrading the firmware from the link below (note: this is for DVD-RW 16X HL-DT-ST DVDRRW GSA-H21L)
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=pv-41633-1&jumpid=reg_R1002_USEN
If that does not work, you will have to talk to HP support and get it replaced.
Please rate this if it fix your issue.
Jun 04, 2009 | HP Computers & Internet
My lg GSA-H55N dvd writer is not playing Cds but plays Dvds fine
Try and find the latest drivers for your drive.
Hope this helps! :)
Nov 23, 2008 | LG GSA-H55N DVD-RAM Burner
I have bought a GSA-H21L Hitachi LG optical drive but i don't have the driver needed to use it, i have tried to find it online but i cant find it.
been a dvd drive you will not need a driver to run it only software to be able to burn cd's or dvd's nero is downloadable
May 20, 2008 | Computers & Internet
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Cd/dvd will not read the a cd after the first
may be you copy the files to a DVD writer its shows the links in it.
Nov 30, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
258 people viewed this question
David Payne
David Payne
