Question about Kyocera FS-1118MFP Laser Printer
Can't use MFP Features with Network Printer - Windows 7
Hi, I've got this printer installed on the network. I managed to get the drivers installed form the Kyocera site. Printing works fine. I tired to install both Twain / WIA drivers for the scanner. I got WIA driver installed, but does not seem to find network printer. The Twian drivers I eventually got one installed, but in the control-panel driver list it says 'Device not started'. I've tried, updating, uninentalling reinstalling but with no joy. I imagine this is because its over network, rtaher than USB. Then I found the document on the Kyocera site of how to configure the scanner for network use. http://cdn.kyostatics.net/dlc/gb/documentation/installationmanual/ns-fs-1118mfp-ig-uk.-downloadcenteritem-Single-File.downloadcenteritem.tmp/NS-FS-1118MFP-IG-UK.pdf Seems like you can create accoutns on the printed via the webserver console. I enabled SMB, then set up an account called 'PC' where I specifed my PC name as the server name, and an existsing network share as the path - under the SMB section. I followed the advice on scanning from the MFP directly, selecting the destination - PC, and then tried to send. The scan occurs, but produces an error on sending. It then prints a summary page says that an error occured but not whatthe error was - so I have no way to debug it. It seems to me that some 'authentication' to connect to my PC is missing. Surely it needs to know a username and password to connect to on my PC. I tried specifying both a valid user on my PC as well an internal printer user that I created (but those are more to do with physical access to the printer I imagaine) rather than authentication to a SMB location. How on earth can I make this work? The document above suggests it should be possible. Also then considered even maybe using a physical print server, but the descriptions appear so vague. Many say spports Multi Function - for most devices, but hard to find a dveice list or know that it support Win7. Can anyone tell me of one of these print servers that actually works for this device on Win7? Also, how do these print-servers work, since I will still have to address the printer as if it were a nework printer even though its connected from the print-server to the device as USB. Does the server effectively install a generic device driver for MFP's to allow this functionality to work and thn somehow convert that to send over TCP/IP back to the computer? Would I have to have some kind of a bridge driver installed on my PC to understand that message? Regards Grant
3 Suggested Answers
  • 46 Answers
SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Posted on Jun 12, 2009
shawn38
  • 200 Answers
SOURCE: Hi, i have a kyocera fs1016 mfp installed on a
Have you tried just setting it up as an HP? Kyocera machines emulate HP.
Posted on Apr 15, 2011
Can't get windows xp home edition to recognize wireless printer, even after assigning printer TCP/IP address. Windows 7 computer prints to it, but the Windows XP computer can't even find the...
Hi!
You din't wrote what's the model of your printer, but I think we can find a solution:
1. Try to ping the IP adress you assigned to the printer. If that works, please download the latest drivers or installation software from the manufacturer of your printer (or second option use the installation disk that came with your printer). If it does not reply to ping, be sure the IP adress you assigned to the printer is in same range as the IP adresses on your network.
2. It is possible that the installation software itself manage to find the printer on the network, and that means the problem is solved
3. If not, install the printer as it is local attached (e.g USB or LPT port)
4. After installing as local printer, please go to printer proprieties, go to port, choose add a new port, choose standard tcp/ip port and write for the port the IP adress you assigned to the printer.
5. Apply changes and ...that's it.
Please let me know if it helped,
Aug 10, 2011 | Microsoft Windows XP Home Edition
I have Hp laserjet P4014 connected with my Pc (Window 7)over the network but the problem is when you command it to print,it print the whole document in symbols like(???!!!E''';;??><<)...
Hi
Dear this problem for wrong driver, please install the correct driver for windows 7, printer is not synchronize with your printer, download the driver for click hear
and select you correct printer model and select the Windows 7(32bit) and download, after downloading uninstall the old driver and install new driver, and check again..
Thanks 4 using Fixya
Jun 24, 2011 | Office Equipment & Supplies
I cant print wireless on my hp Laserjet 1015 Printer. I have it like a Directed connected shared printer to my PC. By the way, the operative system of my pc in which i have it connected is XP, and it does...
With that, you need to install the printer into your windows 7 computer and windows vista computer.
Even though the printer is installed into your windows xp computer wirelessly and set up as shared printer, you still need to install it on to your other computer because you need to install the driver and other printer's software to maximize the features.
Since the printer is already connected, you just need to run the appropriate installation package, the one that's compatible with your Operating System, and install it via Wireless or via Network. For the correct installation package. You can download it from the hp website and check the Support and Driver's section.
Cheers!
Jun 22, 2011 | HP LaserJet 1015 Printer
How do I setup a wireless printer (hp 6310) into window 7
After installing the product on a network, you turn the computer off and then on, and the product loses functionality. The product no longer prints and the product icon disappears from the Devices and Printers menu in Windows 7.
HP created a software update to resolve this issue. Follow these steps to download and run this update.
1) Click this link, Windows 7 Critical Update to enhance reliability of network connection .
2) Click Download . A window opens with options to run or save the file. Click Run . Follow the on-screen instructions to install the update.
If the printer is not installed on network, then download the full software package from HP.com or Click here and select your operating system and then download the software.
After the software is downloaded, run and install it. Follow the on screen instruction to do a network installation.
Note: You must have a wirless router for the wireless connection of printer with PC. Aslo, goto printer menu and run the wireless setup wizard on the printer.
Regards,
Shrey
May 30, 2011 | HP Officejet 6310 All-In-One InkJet...
I can't find drivers for my Konica Minolta Di1611 printer for windows 7 64 bit
Hey all, after a load of grief, and NO help from the INTERWEB, I have chanced upon a solution. Firstly I installed a new local printer with IP number for network printer and associated network address/port (\\server\konicami). Then I installed the win7 64 bit bizhub162 drivers. Then I installed the win7 64bit BH 164 drivers and put an additional driver of x86 win2000 on the properties (server has win2000). Then, when I selected the BH162 driver in printer properties driver pull down menu, it worked. wahey.
May 06, 2011 | Konica Minolta Di1611
Driver for windows 7 to lexmark x2250
Below is the link to the driver for that particular printer.
http://support.lexmark.com/index?page=content&locale=en&productCode=LEXMARK_X2250&segment=DOWNLOAD&os=WINDOWS_VISTA&oslocale=en_US&actp=DD_LIST&userlocale=EN_US+&id=DR2615
Please make a note to read the file information regarding the All-In-One Center as it is not included with this driver package,
Robert from Blitware
Jun 07, 2010 | Lexmark X2250 All-In-One InkJet Printer
Ine windows 7 fo dp3030
http://www.panasonic.net/pcc/support/mfp/dp-3030/pdl/download.html. then go down on PDL Printer Driver without installer (Beta) and download driver. extract it win some d or e drve and manaually install network printer and Enjoy!!!!!!!
Feb 25, 2010 | Panasonic Workio DP-3030 Printer
Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
I want to use a printer on my network. printer
hi: go to the hp site for downloading driver for windows 7 they are there
Microsoft Windows 7 (32-bit)
Nov 01, 2009 | HP LaserJet 1000 Printer
Kyocera FS-1118MFP Laser Printer Logo
41 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
