Question about Dishwashers
Newly installed Kohler Vinnata faucet and we can't get water from it. Water was working fine prior to replacing. Installed per installation instructions? Anyone have suggestions? Kohler not open u
  • sylvia Aug 29, 2013
    We have the same faucet and the water just trickles. I have checked the pressure in the lines coming to the faucet and it excellent, we have cleaned the screen - nothing found. We can get water, just not enough for our on-demand hot water tank to even supply it. It's just a slow trickle.
  • Lisa Hughes Aug 30, 2013
    I have the same problem with my Vinnata. Kohler has sent replacement hose, replacement head. It works for a couple of months then slowly trickles. I am having the problem now. I removed the head and the water pressure is fine without it. Checked the screens, clean. Rescrewed the head back on and now it leaks from the o-ring on the hose. Water sprays everywhere. I am so fed up!
    Genius:
  • Dishwashers Master
  • 1,669 Answers
Please go on line and question the Kohler tech:
www.ereplacementparts.com/kohler-k690-vinnata-kitchen-sink-faucet-parts-c-1...
Posted on Jan 12, 2013
Installed a new kohler pull out spray faucet and the flow is not sufficient to start my instant demand hot water heater. Have taken out the aerator and screen and still not enough flow. Checked the...
Should be valves under your sink for the faucet. #1
Make sure they are opened up enough.
If either device is new, they should support this issue.
Old plumbing can also cause this. Build up in the lines.
They can only be replaced to fix. Some water heaters have adjustable valves, make sure if you have them they are opened as needed. Remember, too low flow can cause over heated water.
Oct 31, 2013 | Kohler K-560-VS Bellera Bellera Pull-Down...
Leaking Kohler Vinnata kitchen faucet.
you must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
Nov 08, 2012 | Kohler K-690-VS Vinnata kitchen sink...
I just had a new price pjister series 40 (Ashfield collection) single control lavatory faucet installed. Our contractor installed it yesterday and he is now out of town for a week. Since the sink and...
You have already checked the two obvious things now make sure the two supply lines from the shut off valves are not kinked or turned it such away as to close off the water flow. If that is ok then there may be some debris in the internal filter screens.
Keep in mind that this faucet design will not put water out at a high pressure if it did it would splash all over the place.
Mar 08, 2011 | Price Pfister 042-YP0E Ashfield Single...
Faucet installed 9/94 and still looks like new. But in past few days have begun seeing slow drip running down from one of the inner metal flexible hoses when faucet is on and for maybe 5-10 min after water...
Try tighten the hoses, if this don't work the seal in hose connectors may need replaced, very simple and cheap to replace. over time the hot water will wear down the seal it will go bad with pressure and water period. It's a good thing to change these all while you are there.
Jan 18, 2010 | Kohler K-12176-PB Fairfax Single Handle...
I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and hasn't stopped leak. What now?
turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
Nov 04, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Aug 31, 2009 | Plumbing
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
No water passes from faucet to hand sprayer
try soaking it in some CLR calcium lime and rust remover .
Mar 15, 2009 | Kohler Model 10430: Fort® Single-control...
Kohler single lever kitchen faucet,no hot water
no its somthing in water filter rust or dirt in line.take apart and drain line. thank you for useing fixya please rate me
Feb 26, 2009 | Kohler K-10416-BN Fort½ Single Control...
Dishwashers Logo
133 people viewed this question
Top Dishwashers Experts
