Question about Singer 7442 Mechanical Sewing Machine
Cannot use automatic needle threader
I have followed the manual's instructions on how to use this feature, but the last part, where you hook the thread and pull it up, is on the opposite side (the left of needle) from the manual.
Also when I set this up, and hook the thread onto this part, it is higher than the needle, and of course won't thread it.
Can you help? The needle is factory set.
The solution to the threader being higher than the needle: Use the handle on the right side to manually raise your needle up to it's highest point. Thant should work!
Posted on Mar 05, 2009
Needle threader won't work on my Singer 4423
The needle threader hook is very tiny and easily bent or damaged.
The needle threader is designed not to turn, if the needle is not at its most upper position to protect the threader - Turn hand wheel until needle reaches its highest position.
Needle not alining with threader hook - Replace needle.
Threader hook bent - Replace with new needle threader hook.
Hope this helps.
Read more from the link I attatched.
Good luck & have a nice day!
Automatic needle threader will not work
Jul 14, 2017 | Singer Sewing Machines
I have a Babylock BMP9 6 needle embroidery machine. The automatic needle threader mechanism is not dropping down far enough to use to thread the needles. Any suggestions on how to fix this?
On older machines that do not have the automatic needle-up feature, the user needs to manually adjust the needle height so the threader will match the needle eye.
Oct 29, 2016 | Sewing Machines
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
Oct 05, 2016 | Sewing Machines
The threader to the needle wont catch the thread
It takes some getting used to, to get these to work properly. Practice. First make sure your needle is in correctly and fully. then make sure that when you engage the needle threader the tiny little hook goes through the eye of the needle. If it doesn't it won't work at all.
Then follow the instructions in the book. Make sure the thread is on the proper side of the tiny hook....
Good luck
Aug 08, 2012 | Euro-Pro Fast and Easy 420 Mechanical...
Automatic threader doesn't work
The automatic needle threader is very tiny and easily bent or damaged; however, it is designed not to turn if needle is not at its most upper position to protect the threader. Turn the hand wheel until the needle is at the highest position. If the needle is not aligning with the threader hook, you will need to replace it. And you can replace the needle threader hook if it is bent. I hope this helps!Jimmy
Mar 27, 2012 | Brother Sewing Machines
Dont no how to work the autmatic theader
You haven't said what make and model but on my Janome 6500 the auto needle threader is a little plastic piece that you pull down on the left of the needle bar. You pull it downwards and it swings over and a little hook comes through the eye of the needle. Now pull your top thread down in front of it and then to the right against the bottom of it. This brings the thread across the front of the needle and the little hook. Let the threading device go and it should pull back out of the needle and upwards again, taking the thread with it and through the eye of the needle. Now, just disenage the thread from the little hook and you should be ready to go.
Most needle threaders are some variation on this, a little wire or hook that comes through the eye from the back to front, so you can introduce the thread into it, then pull it back through the needle eye.
Of course you can always remove the needle from the needle holder, and thread it with a little manual needle threader in the same direction, insert it from the back, put the thread into the wire loop, then pull it back through the needle eye. Then put the needle back into the needle holder flat shank to the back, if your machine doesn't have this feature. Most multi packs of hand sewing needles will come with a little metal needle threader which often just sits there unused.
I hope this assists you with your machine.
May 15, 2011 | Sewing Machines
I have a really hard time getting the needle to thread.l I cannot manually pass the thread through the needle eye: the eye is just too tiny; and I cannot even see the hook part of the automatic threader...
I have that machine, and am wondering if your needle has a burr on it, try a new needle, #11 or #80. You may also have no hook in your automatic threader to go throught needle eye. My first automatic threader was defective, no wire to go through the needle to catch the thread. Take a magnifying glass and look when you change your needle and watch when you pull your threader down, do you see a really fine wire come through the needle eye? If, not yours is defective because it has to pull the thread into a little loop for you to pull your thread through it after you release the lever quickly, Mine was a Singer and they sent me a new one right away, Brother will do the same for you, I am sure. Another thing you can do is go to your dealer and have them inspect it, I went to JoAnn fabrics and that is how I learned that I was not crazy, it was the machine,
Apr 20, 2011 | Brother CS-6000
Automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Dec 21, 2008 | Brother XL-3500
Broke the hook off the automatic needle threader
You can get a new (grey) threader inexpensively that pushes on the bottom of the threader shaft from a dealership. Easy to do it yourself or they can do it in 5 or 10 minutes. Try taking the old one off and looking at it. It pulls right off.
Nov 22, 2008 | Bernina Virtuosa 150
I can't thread the Shark Euro0pro 384 unng the automatic threader
You need to check to see that there is a small hook going through the eye of the needle when you use the threader. A flashlight or bright light will help. So will a magnifying glass. If it isn't, then no amount of trying will help.
If it goes through the eye, you need to see that your thread hooks into it so that the thread can be pulled through.
sewman7
Jun 08, 2008 | Euro-Pro Shark 60 - 384
Singer 7442 Mechanical Sewing Machine Logo
167 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
