Question about Bosch AquaStar ESVVT 2400/2700 Series Vertical Vent Kit
Bosch 2400 exhaust adapter doesn't fit the stainless flue pipe correctly. Stainless flue per manual spec.
  • 332 Answers
Depending on the unit and the exhust pipe you might have what they call the condensate catcher in wich it has to be piped diffrently,, you will need to cut the end if you read the instuctions it will tell you to cut the outer cover 1/2 inch shorter then the stainless pipe, cutting off the hubb this will make it fit,, make sure to cut it straight so it will seal properly
Posted on Jun 09, 2009
What does E-2 F-3 mean?
What product do you have?
What model? What brand? What does you product manual say?
About how old is product? Is this new installation?
If you have Bosch tankless, copy following links for general troubleshoot start point:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/E2_error_code_troubleshooting-Bosch.pdf
Sep 04, 2012 | Whirlpool Gold G9CE3675XS 36" Smoothtop...
Black soot on outside wall above hot air exhaust. Excess flame, incomplete combustion? How to adjust/correct?
All gas water heaters, tankless and tank-type, require cleaning burner and combustion parts.
Tankless manuals suggest once per year.
Tank-type once every 2-3 years.
Before calling service technician, open following links for Bosch troubleshooting resources:
http://waterheatertimer.org/pdf/TWH-G1-13_Removing_and_cleaning_burners.pdf
Burners do not operate cleanly:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125BOTechSupport/Troubleshoot/tabid/602/Default.aspx
Jun 26, 2011 | Bosch 125BO NG AquaStar Outdoor Natural...
Size of the exhaust vent pipe on a 75 gallon gas water heater? Is it the same size as on a 50 gallon water heater. Brand is GE, mfg 2008
I believe it takes 4" vent pipe up to 100,000 BTU
BTUs are shown on label side of tank.
http://waterheatertimer.org/pdf/Gas-venting-specs.pdf
Does new water heater have power vent? What does manual say?
Are you experiencing vent problem now? When you light a match and put it under vent stack, does smoke immediately get pulled upward? Are furnace and waster heater connected to same venting. Is there dark exhaust stain around vent hood? Does exhaust vent back out of vent hood when furnace kicks on? Are flue pipes stained with rust and white coating? Are vent pipes vertical, or are there level runs? Are the pipes made of galvanized and screwed together with 3 screws at each joint?
Frankly I would double-triple-check any internet answer dealing with possible CO poisoning at your home.
1) Ask local plumber for specific code in your area.
2) Call gas company
3) Post question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
4) Read whole manual for new water heater before buying.
5) Contact manufacturer.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 30, 2011 | Water Heaters
I have a Bosch Water Wizard 960 400 NG. How do I adjust the water temperature??
In New Zealand, the Bosch 960 Water Wizard has a maximum temperature of 55 degrees celsius, for safety reasons, check with your local gas fitter or plumber to see if your system has been set correctly. If water feels hot through some taps in the house, but not others, then there is a good chance your water pipes are not insulated, meaning that the heat from the water is escaping out through the pipes before it gets to the shower, for example. As far as I am aware, there is no way to manually adjust the water temperature of a Bosch 960 Water Wizard, it has to be done by a certified professional gas fitter. Recommendation: Get a more up-to-date gas water heater, that doesn't require a manual restart each time the pilot light goes out.
Feb 26, 2011 | Water Heaters
When the temp. dropped below zero outside the cold air coming down the exhaust froze the water heater. it is installed in a heated basement but there is no way to keep the cold out of the exhaust. any...
You can look into an electric flue damper. It must be tied into the heater controls so the fail-safe is that the heater will not operate unless it senses that the flue is open.
Feb 09, 2011 | Bosch & Tankless Water Heater
The boiler says there is a problem with the fan or flue?
You should be able to hear if fan is running. If it is running & not making squeaking or grinding noises, most likely the flue (pipe that exhausts fumes outside) is plugged. Bird nest, beehive or some other restriction.
Jun 15, 2010 | Water Heaters
Burner goes out when it was running
Here are a few things you need to check.
Make sure that the temperature limiter and the flue gas limits are not tripped.
Make sure that you have at least 30 PSI of water pressure.
Also check to see if you have a plumbing crossover and make sure that it is set correctly.
heatman101
Mar 24, 2010 | Bosch & Tankless Water Heater
Bosch tankless GWH 2400 ELP in use 2-1/2 years. Whenever it is below freezing, we have problems with EC and/or EA errors, and no hot water. Sometimes restart will work. Bosch customer support is useless. I...
are u using well water or hooked up to city line if well water --may be to cold for unit if water is below a certain temp unit usually goes into error or shuts down if un heated space where water heater is u may have to warm [ insulate ,heat tape etc]the incoming water usually water that around 40 degrees causes problems
Feb 03, 2010 | Bosch & Tankless LP Hot Water Heater
Bosch 1600H won't work on windy days
The incorporation of an anti-back flow, flue pipe insert may be your solution, also the pilot flame control may need to be adjusted up a little.
Good luck
Aduz
Mar 24, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch AquaStar ESVVT 2400/2700 Series Vertical Vent Kit Logo
110 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
