Question about Panasonic CT-27G13 TV
CT-32HL42 Panasonic will not turn on
When I press the switch, nothing happens. The stand by on light is off but one does not need that to be on if you manually try to turn it on. Also, the remote will not turn it on either. This is what happened. One day I turned the tv off manually. Later that day when I tried to turn it on manually it would not start. Then about a week later, I pushed on it and it did start. I turned it off again, and since then I cannot get the tv to start at all. One thing, this is either a CT-32HL42 or a CT32HX42, but I cannot turn this behemoth around to verify which. I just know the model # from my owner's manual, which shows two model #s for my TV. I imagine there is not much difference.
  • 1 more comment
  • Anonymous Aug 25, 2007
    Hello, What we found out is that the fuse needed to be changed.
    Thank you for input though.
  • Johnnypit Jan 09, 2008
    Panasonic CT-32HX42 TV wont turn on. It starts but then shuts off right away if I unplug it for a little bit.
  • Anonymous Nov 06, 2008
    Hi, have a 2003 Panasonic CT32HC43 HD capable TV that just now won't turn on at all. Went and got a box of fuses from Radio Shack based on everyone's advice and the TV is working fine. The old fuse was and did look bad. I had a pair of angled pliers and was able to get the old fuse out and new in through the small access hole.
    Thanks - you helped me fix the TV
I've had the exact same problem and had a service person repair it for $300. But this problem occurred again and I noticed that this may be a child-proof feature of the TV that many people don’t know about. When turning on the TV you will hear a clicking noise in about a second or two, but if you were to turn on the TV while holding down the TV/VIDEO button on the TV itself then you will not hear this clicking noise and will lock your TV from starting. To reset this lock you will need to unplug the TV for few seconds and then plug it back in which will reset this lock. I have used this feature now for a while since my year old son loves to turn the TV ON/OFF.
Posted on Nov 25, 2008
Thanks for the "fuse" tip. Replacing it cured my 6 year old Panasonic CT32HX42 "no power" problem.
Posted on Sep 15, 2008
Yep that is what it was for us, fuse. I got the fuse an an electrical shop for about $6.
Posted on Feb 03, 2008
    Problem Solver:
  • 8 Answers
Hi, I own the panasonic ct-36hl42
great set, but this has happened again to me and it has happened to me about a 3 yrs ago. I have heard this problem and often it is the fuse next to the plug once you take off the back of the set. I am trying to order one from panasonic but they won't sell me it. It only runs about $3.50. I requested a schematic from panasonic and they won't give me one either. I have had sets in the past , like jvc and they provided shematics for the set, and any time I needed work I would provide the schmatic which the tv repairman was grateful for.
I am finding Panasonic to be a terrible company for support and will never ever buy panasonic again since they seem to enjoy telling you NO they won't give it to you.
I have a samsung lcd flat 40" on the wall and needed service and found samsung much better. I believe Pansonic prefers to sell new stuff and does not give poop about the after market customer.
anyway, I am going to buy the fuse through a local tv repair shop whom I have befriended. He showed me the fuse the last time it broke and showed me how simple it was to replace. Note, the fuse is located next to the power plug once you take off the back. I have heard this fuse goes out often.
My advice....Stay away from Panasonic.!
Posted on Jan 26, 2008
    Scholar:
  • 47 Answers
These sets have a number of problems like yours which are associated with bad solder connections or cold solder joints. On this set one pin on the the start-up relay is usually open or intermittent The solution is to resolder connections on main p.c board. and especially on the vertical output IC. Also change the caps in the vertical section to avoid future problems. Scrivitron.
Posted on Jul 06, 2007
SOURCE:
Panasonic color TV model CT-32G9J won't turn on.
been a long time since fixed an crt tv. but if you have a stand by light the problem on this model is the control chip if remember right it sits on the left side near to the front. think its an 8 pin chip. these just go and it will not turn on. these chips are easy to get hold of and are cheap. you just need to remove it and replace with a new one. and the tv will work again. its not on the power board but is controlling the power start up. if there is no stand by light its a longer problem to solve. it could be a number of problems. would need to know if any problems happened before the tv did not turn on.
Jan 15, 2014 | Televison & Video
32'' Panasonic television. Power switch does not turn the set on.
1 It appears that connecting cable is faulty. Normally when you connect and push the power switch the standby light should lit. Try the cable on another appliance and see its function. Also switch on the TV and try to switch it on with your remote control.
Nov 19, 2009 | Televison & Video
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
May 30, 2009 | Panasonic Microwave Ovens
TV will not turn on, it makes a click and nothing happens?
repar is
replace stk 730-020 i have them in stock
replace c809 capasitor value is 22uf at63v not in stock
replace location f801 t4a not instock
[email protected]
thanks
daniel.
Jan 13, 2009 | Panasonic CT-32G11 32" TV
NO POWER OR LIGHTS WHEN POWER BUTTON PUSHED
Hello and welcome to FixYa!,
It sounds like the Power Board on you TV has Died, you will need to replace it in order for your TV to work again
Hope this helps --Full Str Pka
Dec 30, 2008 | Panasonic Televison & Video
Panasonic Problem
replace the fuse of the tv device (in the primary main power section),or contact the nearest repair shop.
Jul 18, 2008 | Televison & Video
Fuse constantly blowing on 32" Panasonic HDTV Tau (ModelCT-32HL42)
Change fuse from F6.3 amp to T6.3 amp (Slo-Blo).
The problem is the surge of current at turn on.
Oct 10, 2007 | Televison & Video
Panasonic CT-27G13 TV Logo
593 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
