Question about HP ScanJet 5530 Flatbed Scanner
1004 Twainpro error
I'm searchin' drivers for windows 7 64 bit
Epson error 1004
Hi Thet, The link below is a Windows web site, Please read error 1004 and solution.... This will help you....CHEERS..
http://www.saetechnologies.com/epson-easy-photo-print-an-error-1004-has-occurred/
Apr 01, 2016 | Epson Office Equipment & Supplies
I have sony vaio laptop window 7,64 bit with 500 gb harddrive having only one partition = c i want to make 4 partitions how can i make it without losing my recovery data default from manufacturer
Type Computer Management into the search box above the start icon. Select Disc Management, select the drive name you wish to adjust and right click on it. Select Shrink Size and select whatever size you require. When complete format the new partition.
Dec 24, 2014 | Sony VAIO Computers & Internet
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
Can't find drivers for my dell 8600 upgraded to win7,help
Sometimes you can use the Vista drivers for a device. Need more info, drivers 32 or 64bit?
Oct 31, 2012 | Dell Inspiron 8600 Notebook
I have an wireless Epson NX 230 printer 32 bit printer with Win 7 operating sys Emachine 64 bit desktop. Printer driver process says operating system does not support the driver. Test page does not...
Officially MS says it's not support, and Epson does not have an updated driver. Sorry.
If I'm running a 64-bit version of Windows, do I need 64-bit drivers for my devices?
Yes, all hardware devices need 64-bit drivers to work on a 64-bit version of Windows. Drivers designed for 32-bit versions of Windows won't work on computers running 64-bit versions of Windows.
Description: This file contains the Epson Stylus NX230 Printer Driver v6.91. The Epson Status Monitor 3 is incorporated into this driver.
Compatible Systems: Windows 7 32-bit, Windows Vista 32-bit, Windows XP 32-bit
Aug 30, 2012 | E-Machines Computers & Internet
Usb port on presario F500 quit working, they are seen by device manager but will not reconize a flashdrive when incerted, a mouse or any thing else. Using win 7,64 bit t3500 cpu.
This should be pretty easy to fix. I have seen this many times before. Here's what to do:
Go into device manager and expand 'universal serial bus controllers'.
Start at the very bottom, and start deleting the usb root hubs one by one. You will lose your touchpad control at some point, as the touchpad is actually a usb device. One of thwo things will happen.
1. The usb hubs will automatically be re-detected and re-installed.
2. You will just lose touchpad control after deleting one of the root hubs. If this happens, then shut down using the power button, and restart. Th usb hubs will be reinstalled once you log back into windows. Please let me know if this doesn't fix it.
Joe
Apr 07, 2012 | Compaq Computers & Internet
How to resove the error message "system does not minimum requirement to install this driver" while installing window xp 32-bit drivers on 64-bit notebook(thosiba-C640-11N)?
maybe your notebook is not compatible for xp64 bit try to upgrade in win7 x86 that's much better :))
dont worry on your file it will not be deleted unless you delete your partition. the folder name is "windows.old" that is the folder where save your old files from xp
Apr 01, 2012 | Computers & Internet
Error message saying I am missing microsoft version 2.0. Is there a bridge or patch to get the microsoft. I have tried to down load this version and I get a message saying I have a 32 bit map and it...
If you're using Windows 7, check if it's running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > Properties. Take note of the System Type.
Use the links below to download the Lexmark Z2420 Printer Driver from the Lexmark website: - Lexmark Z2420 Driver for Windows XP/Vista 32-bit/Windows 7 32-bit - Lexmark Z2420 Driver for Vista 64-bit/Windows 7 64-bit
Aug 12, 2011 | Lexmark Z2420 Printer
I have no sound driver
Please use the below link
For all drivers.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+945+Express+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D945GCCR
select the operating system then
select DRIVERS in select download type.
then download the sound drivers. and install.
For Audio drivers: Click on download
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19472&lang=eng
AUD_Vista_Win7_6.0.1.6201_PV.exe for vista or win7 AUD_XP_5.10.0.6201_PV.exe for xp. If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jul 02, 2011 | Intel D945GCCR Motherboard
HP ScanJet 5530 Flatbed Scanner Logo
172 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
