I have a Sony color rear video projector model# KP-43T75 it's blinking for time won't stop I checked for the Bolges on the black piece there is none and it turns on no sound or picture and shuts it se
  • Televison & ... Master
  • 15,478 Answers
First let me say that you did good checking for bad capacitors that might have bulges. They can fail with no outward signs though. You have to use a special meter to check them. Second that light means:
Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
Your best course of action would be a new power supply board.
Posted on Jan 13, 2013
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: I have a 2001 color rear video projector model no kp-43t75 every time I turn it on it blinks 4time and shuts off no sound no picture can u help me
When the 4 blinks happens its indicating the Vertical deflection has stopped thats. usually caused by the Vertical out IC1509 (LA78045) and Verticak Buffer Q5A51 (2SC3311A) If you need further assistance let me know.
Posted on Jan 12, 2013
I have a Sony color rear video projector model number KP-43T75 and can find the bad spots in mother board
Unless you have alot of test equipment and alot of patience, it might just pay to put in a new one seeing you have it out already.
Jan 12, 2013 | Televison & Video
I have a Sony Color Rear Video Projector Model KP-57HW40. Its blue color is not working anymore and noticed some burn smell by the set which controls such blue color.
It may be the CRT drive board which is attached to the bottom of the Blue CRT. I would check that Board for signs of being burnt it may need to be replaced.
Jul 08, 2011 | Sony KP-57HW40 57" Rear Projection...
My jan 2002 sony color rear vidoe projector kp-51hw40 keeps turning off scc-p65g-a
When it turns off does the indicator blink? if so how many times does it blink?
Jun 14, 2011 | Sony KP-51HW40 51" Rear Projection...
I have a Sony color rear video projector KP-46WT20 and it has not been turned in about 2 years. I recently tried turning it on by plugging it in but it won't turn on instead, the standby button light...
The lamp is dead most likely. the blinking is actually coded as a message depending on the number of blinks. if you check the troubleshooting section of the manual it will tell you what the blinks mean
Mar 12, 2011 | Sony KP-61V85 61" Rear Projection...
KP-57WS520 Sony Projector - No picture
5 times blinks shows incorrect white balance (AKB) error. TV needs Screen Volts (G2) adjustment.
Take off lower front panel, find Focus Block that has 6 control knobs, adjust Screen volts of each CRT (red-green-blue) and problem will be solved.
Be Careful while working in TV.
Let me know if you have further question.
Thanks.
Dec 09, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony KP-43T75 color repair
This link has the instructions on how to fix this problem and other similar problems. You have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection TVs have the red, green, and blue pots in the same order as the picture that is listed on this link, so you may want to google search for your model's service manual. The service manual can also help you be able to remove the cover for your particular model of TV. I was able to find the service manual for my model, and sure enough, the order of the pots are reversed on mine, so I would have been adjusting the wrong color. Read all of the comments on this link too, because you can find other helpful tips and may even find someone with the same model of TV as you that gives more specific instructions for your model.
You may also find your model's service manual here:
http://esupport.sony.com/US/perl/index.pl
I hope this helps you!
Fare well. :)
Iconoclast
Jun 27, 2009 | Sony KP-51HW40 51" Rear Projection...
Color video rear projector...........color red is misaligned
convergence amplifier ICS !!! replace them and associated pico fuses ICS # start with STK
Dec 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
