Question about Whirlpool Gold 24" Tall Tub Built-In Dishwasher - White-on-White
Whilpool gu2300xt,wash cycle lights wont light,when i push start button goeswt calcell and drain and you can here drain pump then it shuts off
Cant get the wash lights to light,when yuo push start goes straight to cacel and drain,you here the drain pum going then will shut off,no water in bottom
  • Whirlpool Master
  • 3,247 Answers
It is likely there is some fault with the float switch. Which means the dishwasher thinks it is overfilled with water and tries to empty out to protect itself. This is why the pump turns on as soon as you try to run the dishwasher. Refer diagram. You need to check if the float (12) spring is responding by pressing it down and checking if it comes up. Also level switch could be faulty.
Posted on Jan 12, 2013
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
  • 641 Answers
SOURCE: Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
Posted on Jul 27, 2007
SOURCE: Whirlpool ADP 9520
press the start button (which is flashing) for a few seconds and it should start again?
Posted on Aug 20, 2008
SOURCE: Stays in wash cycle Whirlpool Dishwasher Du1050SS
my repairman contacted whirlpool about my washing machine staying on
wash.. to his surprise.. and mine.. and his co=workers.. this is the answer,
it worked.. and we have never heard this before.
In your original istallation booklet it tells you to let the dishwasher run til its complete
the first time you use it as it may rinse twice... my original installation man told me this also.
however.. if you suffer a "blip" in your electricity.. it could put the little dishwasher "brain"
out of whack.. it can run as long as 3 to 4 hours on wash to reset itself.. if you stop it
(like others have mentioned.. and which I did also).. it doesn't complete the reset and it
will attempt to do it the next time..
answer?.. just let it go once as unnerving as this is.. it works.. They did mention that
if it went to 5 hours.. call your repairman because you need a new mechanism.
karen in Dothan
Posted on Apr 03, 2009
SOURCE: dishwasher will not run. clean light flashes seven times
I tried the button sequence described by guest #1 but nothing happened.... is there anything more to it?
Posted on Jun 13, 2009
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
My machine wont run, i replaced the drain pump and thermostat sensor.
Depending on your model pushing soil level and spin speed at the same time then hitting the power button will start it in diagnostic mode from here out pushing start will check its features, door lock, low spin, high spin, pre wash, wash, bleach, softener, rinse, drain, spin...ext
Jun 01, 2014 | LG WM2688HWM TROMM SteamWasher
My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off...
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Dec 29, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a Kenmore Elite Dishwasher Model 665.172824000. We think it stopped part way throught the dry cycle. The green "Clean" light has been flashing since in 7 flash cycles non stop. I tried pushing...
So sorry but the partsdirect site for sears locked down my computer. Check where the drain hose connects to your pump and see if there is a small device the hose connects to that has 2 wires going to it. If it does unplug the wires, turn power off, wait 1 minute and turn power back on and see if it works with this disconnected. If it does you will need to replace this. It is like a sensor that says there is too much debris. Stupid part that was totally unnecessary in the first place. Sorry about the inconvenience.
Feb 07, 2010 | Dishwashers
Wsher stops in the rinse cycle wiht a n F4 message
f2 error means long drain or no drain
check the drain pump
replace drain pump if nessesary
Mar 17, 2009 | Kenmore Washing Machines
Dishwasher quit during cycle.
Need a little more info.. anyway.. open dr will shut off dw...close dr.. push power button until power on... lights on, but nothing happen.. try holding down drain and one of wash cycle.. repeat holding drain w/other buttons until you hear drain pump running.. make sure you hold both buttons for a few seconds.. if your drain pump works.. then, you might have a problem w/your wash motor or something is stuck in the impeller area.
Jan 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Wont start
The lights flash when the door is not shut all the way, or the sensor that detects that the door is shut is not sensing the door is shut. Try pushing in on the door while hitting the start button.
Feb 13, 2007 | Frigidaire 24 in. FDB1051RE Built-in...
Whirlpool Gold 24" Tall Tub Built-In Dishwasher - White-on-White Logo
313 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
