Question about Toshiba Satellite 15" Flat Panel LCD Monitor
Key for bios
Hi, my name is rosemary and I am trying to get to the bios on my toshiba 1410 s173, i am not sure how to do so so i was wondering if some one could help me with my issue
  • 101 Answers
As your computer boots up quickly run your finger across all the f key buttons and then it will pop up your bios. hee hee
Posted on Jan 22, 2009
Toshiba 1410 cooling fan replacement
Contact a Toshiba repair center in your area, Alternatively a computer technician will do.
DIY install, components may be found on Gumtree or e-Bay.
Take care!
damnor01
Apr 28, 2012 | Toshiba Satellite 1410-S173 Notebook
How to change RTC battery of Toshiba Satellite 1410
RTC battery is located underneath the palmrest - to the left of the touchpad - they don't usually die, as they are Lion rechargeables. Unless your Satellite 1410 is losing date and time every time it is turned off, you probably don't need to replace it. But if you need to replace it, make darn sure that you replace it with a rechargeable and nothing else.
If you need to get to it, you'll need to remove the keyboard, then the square aluminum bracket above the heatsink, then get to the bottom, remove all the F6 and F26 screws, then you must make sure to disconnect the WiFi antennas. After that, the top case (including the palmrest) will unsnap from the bottom case and you'll be able to see the RTC battery.
Aug 30, 2011 | Toshiba Satellite 1410-S173 Notebook
Bios Password locked and need to get it removed, model 1410-s173 to check out system for any issues.
Are you the one who set up the BIOS password? If not, unfortunately, there's no way for us to retrieved the password. The only way you can reset the password to default settings is to reseat the CMOS battery on the motherboard, its a circular thing that looks like a battery of a watch,sometimes a pin hold it, just detached it then wait for at least 30 minutes then connect it back again,
Note: Before you reseat the CMOS battery,make sure that everything is unplugged on the computer, like AC adapter,battery and all external devices...
Hope this will help...Your response is very much appreciated...
Jan 24, 2011 | Toshiba Satellite 1415-S105 Notebook
Bios password locked im my toshiba 1415,S173 ,how can I resolve
To prevent a thief from using your computer, the only way to "reset" the password on a "notebook" computer is to find your original sales-receipt, and to telephone Toshiba, and get them to help you.
Nov 09, 2009 | Toshiba Satellite 1415-S173 Notebook
Toshiba satellite 1415 S-173 BIOS entry key
Try this...
Toshiba® 335 CDS ESC Toshiba Protege ESC Toshiba Satellite 205 CDS F1 Toshiba Tecra ESC then F1 or F2 Toshiba Notebook [Newer models]
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
Nov 04, 2009 | Toshiba Satellite 1415-S173 Notebook
How do i get to run the cd to repair os
From BIOS setup, change the boot order as the firsy boot device as CD/DVD drive. Reboot the after inserting bootable OS disk in to drive. It will prompt you to press any key to boot from CD. Follow the steps.
Jul 14, 2009 | Toshiba Satellite 1410-S173 Notebook
How to manual on replacement of cmos batter in Toshiba 1410-S173
cmos battery is present inside the motherboard...go to tosibha website and enter ur model no...der u can download the hardware mannual for the particular model
Jul 04, 2009 | Toshiba Satellite 1410-S173 Notebook
Boot via LAN
The wake up on LAN is usually setup from the BIOS configuration.
If you BIOS doesn't have this option then it is not possible.
Apr 28, 2009 | Toshiba Satellite 1415-S173 Notebook
Need to replace keyboard on my Toshiba Satellite 1410-s173. How do I gain access? Which screws should be removed and which should be left alone?
The plastic strip above the keyboard - you need to remove it (start by using a small, flat screwdriver and using the Windows key as leverage). After that, it's three screws (L, middle, R), then set it upside down over the touchpad, and disconnect the cable by lifting the connectors up.
That oughta do it!
Apr 18, 2009 | Toshiba Satellite 15" Flat Panel LCD...
Toshiba 1410. Won't turn on
Sounds like a dead battery, You need to try it with an alternative battery, most laptops won't aeven switch of if the battery is damaged, also try ro pull out the motherboard and find for dry joints. i.e. any lose transistor or capacito and try to re-solder it, the put the laptop back together,
Feb 27, 2008 | Toshiba Satellite 1410-S173 Notebook
Toshiba Satellite 15" Flat Panel LCD Monitor Logo
191 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
