Question about Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome...
How to remove Moen 100940 J2 faucet - Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome...
3 Suggested Answers
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
ftw1952
  • 10319 Answers
SOURCE: moen faucet removal
you will have two mounting nuts at each end and two water line to disconnect for removal under the sink on any faucet made
Posted on Feb 14, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How is the cartridge removed on the faucet?
    How To Repair Cartridge Sink Faucets at The Home Depot
    www.homedepot.com/.../project_guide_repairing_cartri...
    The Home DepotJul 22, 2013 - Quickly fix a leaky cartridge sink faucet with this detailed step-by-step ... On some models of faucet you may have to remove the cartridge with a
    Removing a moen cartridge from the faucet! If the plastic tool ...? 2:47https://www.youtube.com/watch?v=vGdExIS3b-oMar 5, 2013 - Uploaded by TheOldkid888This is a video on how to remove a moen cartridge from any moen faucet when the plastic tool does not do ...Installation Help / Animated Tutorials for Moen Faucetwww.moen.com/consumer-support/installation-help/tutorial?id...MoenUsing a Philips screwdriver, unscrew the handle screw and pull the handle up off from the faucet. Using pliers, loosen and remove the pivot retainer nut as well. Remove the washer from the cartridge and use pliers to remove the retaining clip.
    Dec 03, 2015 | Plumbing
    How to remove moen bath faucet handle that has no set screws and is all 1 piece
    1.) its not all one piece
    2.) the tower threads onto the valve body, you may need to loosen the mounting nut under the sink top with a basin wrench to relieve the pressure on the handle tower
    3.) this is the exploded parts view for your faucet: http://www.moen.com/shared/docs/exploded-parts-views/s498pt.pdf
    4.) this is the instruction sheet for your faucet, including a technical support number you can call: http://www.moen.com/shared/docs/instruction-sheets/ins1207.pdf
    Aug 26, 2014 | Moen Showhouse S498 Savvy Two Handle...
    Leaking CA87681 moen kitchen faucet
    Throw a cloth over the cover to prevent scratching the finish and grab it with a large pair of channel locks and unscrew it.
    Nov 18, 2013 | Moen 7907 Chateau Two-Handle Kitchen...
    Replace o rings on a moen adeline model 87787SL KITCHEN FAUCET
    How do I remove the faucet Moen model 87787 to place O-rings?
    Jan 30, 2013 | Moen Plumbing
    We have semi-successfully replaced our Moen cartridge for model 100940. We have no more leaks, the only problem is that the water will not stay on. When we lift the handle up, it immediately starts to...
    I know this is an old question, but I just had this issue when replacing the cartridge in my 100940 J1 Moen faucet. I had to tighten the Phillips-head screw down a little more that holds the plastic piece on to the cartridge stem. Hope that's the fix you needed.
    Apr 01, 2011 | Microwave Ovens
    My classmate
    Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
    Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    LEAKS. HAVE GASKET KIT. BUT CAN'T GET IT APART!!
    MOEN ARE NOTORIOUSLY difficult to get appart. There is a "Special tool" just for Moen faucets/tubs/showers. It is like an old "Brake drum puller" or "Faucet handle puller". I think about $10 to $12 at Home Depot or Lowes. FYI Moen and Delta both give "FREE PARTS" on "MOST" faucets for many years if not life, if your not in a hurry. Check your original paperwork for warranty. The washer at the end of the valve after being installed for more than a year, usually binds up and gets torn apart when removed. It makes it VERY difficult to remove, even with the "Special tool". They (Moen) give you a plastic wrench like thing that almost never works, with the purchase of a "New valve" DELTA800-345-3358 ..MOEN-800-289-6636
    Aug 22, 2010 | Moen 87555C Trianna Single Handle Pulldown...
    I have a kitchen single lever moen faucet and the cartridge wont come out. I have removed the retaining clip and all screws
    you may need to get the moen cartridge puller,either moen brand, or brass craft, they can be tough to pull some time's
    Feb 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Moen faucet removal
    Feb 13, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
    1,758 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
