Question about E-Machines M5313 PC Notebook
M5313 won't power up. AC connect light on, no light or action from power switch
  • E-Machines Master
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Jan 13, 2013
97 chevy suburban AC clutch won't engage pressures
Looks like the low pressure switch gets power from a 10amp ac fuse. Power then goes to the ac relay which is powered on by the ac heat controller on the dash. Power then goes thru the high pressure switch to the compressor. The ac relay is grounded to the body. Do you have power on the lite and dark green wires going into the relay and is it grounded ?
Jul 26, 2013 | Cars & Trucks
Tip
LCD TV TROUBLE SHOOTING
1.Do not power on .
1 .1 Please check AC cable if connect to AC plug. Is true the connector don't connect to AC plug. Please connect it.
2.2 Please check AC cable if connect to AC power. Is true the AC cable don't connect to AC power. Please connect it.
3.3 Please check power board of fuse if broken. If the F1 fuse is broken, Please pull out the AC cable from AC power. Please check AC L power and AC N ground by multimeter, The read number is infinite, the fuse is broke. Then look up power board if not burn out place. Is true it. Please change power board or be changed power board.
2. The power on switch of green extinguish.
2.1 The power of led(indicator light) is red light, To touch power on key when indicator light wink. Is true that the power DC output have somewhere short circuit. Check connector J39,J31 .If not connector direction is wrong. Or the mainboard somewhere of power short circuit.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
on Feb 14, 2015 | iLO Televison & Video
Won't power on
It might be that the water flow switch is faulty, this will allow the unit to light up but will not start
Jul 12, 2013 | Heating & Cooling
I replaced the ac adapter on the motherboard of the Gateway NV5207u and now when I try to power it on, won't power on. battery light red
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
Mar 30, 2013 | Gateway NV5207u Notebook
Klipsch soundbar (SB1) won't power on ... green light on power adaptor seems to trip and go off when I power on the SB
I have read that this may be due to the order in how the AC adapter is attached to the sound bar. After some research I found that you need to unplug the AC adapter from the wall and the sound bar and let it sit for about 15min. Then flip the power switch "ON" on the sound bar and connect the AC adapter to the rear of the sound bar. Lastly, plug the adapter into the power outlet.
Feb 21, 2013 | Klipsch Audio Players & Recorders
SUA3000RMI2U won't carry load
Did you run this test without AC input?
Also what happens when you cut off the AC mains without any load connected to it? Will the UPS continue to run or does it switch off as well?
Dec 15, 2012 | APC Smart-UPS 3000VA USB & Serial...
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My AC adapter suddenly can't seems to be able to charge my battery. Please kindly advise
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 08, 2011 | Compaq Presario CQ40 Series Laptop Charger...
It seems to have no power the led light doesn't come on. its brand new, but I havent used it in about five years
Are you using battery or AC adapter for power?
Most pedals won't allow you to use both. Check that there is no battery installed if you're going to plug it in. If you are using a battery, Some pedals won't light an LED on battery power.
If problem persists, your pedal may be DOA
May 04, 2011 | Boss Mt 2 Metal Zone Effects Pedal
E-Machines M5313 PC Notebook Logo
20 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
