Question about Whirlpool Aquatic Millennium VII - A17MIL7257
Combi boiler problem
Hi there, i have a combi boiler ideal c80ff the problem i am having is the when the timer goes to off the boiler is still on and the Radiator are still on, can you help
    Scholar:
  • 150 Answers
Most have an overrun built in for a few minutes. if much longer have you got a room thermostat anywhere to turn down
If it never turns off check the switch which controls ON/TIMED/OFF and turn to timed or off. if it still continues on timed then it's the timer
Posted on May 03, 2009
24 he potterton fails to start red light flashes,reseet same thing happends, no ignition,fan spins,for a very short while,
Posted on Aug 28, 2009
Ideal Logic + Combi C30 not firing up.
Isconnect from the hive ,it has been known the hive thrmostat fails on ideal boilers.
Mar 22, 2017 | Water Water Heaters
My ideal logic combi 30+ is saying ignition lockout and my radiatiors arent heating up as well as my water not turning hot. How can i fix this please?
Lockout is a safety feature. Usually a latching condition and needs to be investigated rather than blindly reset. (The Combi has a bit more intelligence.) With the ignition locked out, you can't hi-fire the boiler, so no hot water of either type. The 'L' should also show a code number - check your user manual (google) for more guidance.
I've had a lockout on a non-combi: it was caused by lack of circulation of central heating water through the boiler.... The system boiled and the trip tripped. The pump WAS running, but wear in a valve actuator resulted in the valve feedback saying valve open while it was physically shut.
Dec 31, 2016 | Water Water Heaters
Combi boiler hot water far to hot.
Yes the temp can be adjusted, the dial is behind the cover. Turn off power before removing cover.
Sep 11, 2009 | Water Heaters
Vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Mar 25, 2009 | Water Heaters
Missing instructions for setting timer on boiler
if the timer is built into the boiler there is a small switch on the right hand side. this can be moved up and down to bring the timer on and off.
if you log onto the ideal web site you should be able to download a copy of the programing instructions.
Feb 21, 2009 | Water Heaters
Ideal c80ff
differential is set too close and water temp set too low.dirty coil can have same result -how old is unit?
Oct 26, 2008 | Water Heaters
Whirlpool Aquatic Millennium VII - A17MIL7257 Logo
799 people viewed this question
Top Whirlpool Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
jdthefixer
Mike
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
