Question about Kenmore Dishwashers
Why is my dishwasher running without water? - Kenmore Dishwashers
  • Kenmore Master
  • 3,247 Answers
It is likely the sound you are hearing is that of the pump motor which is triggered because the flood switch has been triggered. This means the dishwasher is trying to empty itself to avoid damage likely casued by water leak. You need to find out why the flood switch is triggered. It would be helpful if you provide the model number of the dishwasher.
Posted on Jan 12, 2013
Ge dishwasher -runs without water
the fill solonoid is stuck or has bad connection on the coil or has failed. it is located within inches of water hook up fitting.
Aug 13, 2014 | GE 24 In. Stainless Steel Dishwasher -...
Dishwasher is 20 yrs old and last nite it went through the cycle without running in water. 1st time this has happened. Is this something I can fix?
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Aug 30, 2011 | Dishwashers
My Whirlpool dishwasher is stuck on the clean cycle?
If it continues to run without any alarms or flashing light, I would assume the heater is packed up. It is looking for the water to reach the correct wash temperature.
Try to run on the cold water cycles and see if there is any difference.
Mar 21, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Maytag model #DWU8860BAE water not coming in hose. Runs through cycle without water.
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
heatman101
Dec 20, 2010 | Dishwashers
No water in the dishwasher Bosch SHX43M02-48. We turned of the water and forgot to turn it back on and ran the dishwasher. Now the it will not let water in?
Hi, By the information you've supplied, I'd guess you burnt out the coil in the water/fill valve by running it without a water supply to the valve. Are there any other unusual symptom's or error codes ? i.e. drain pump running none stop ? Can you put water into the tub manually and run a rinse cycle without issue ? In any event the valve is pretty inexpensive, usually about $30 or so. The part # 425458 works on all bosch, thermador, gaggenau, and siemens dishwasher built since the early to mid 90's up to present day. Hope this was helpful to you. Thanks for visiting "fixya" today. Good luck. macmarkus :)
Mar 05, 2010 | Bosch Dishwashers
My GE 500 dishwasher is making a high pitch noise. There is also no water in the bottom of the dishwasher. I think it might be the water pump.
pump running dry(without water)
1)check the water hose connected to the machine(solenoid filter block)
Jan 07, 2010 | GE Dishwashers
Machine runs full cycle without water!
The most common reason for this problem is the inlet valve (Solinoid valve) has failed and does not open when the DW timer tells it to before each wash and rinse cycle.
That valve is just inside the place where the hot water supply hose connects to the dishwasher.
There can be other causes but this is by far the most common reason.
Good Luck!
Apr 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
Our Nautilus dishwasher won't turn on. I can hear a buzzing noise, but nothing is happening. Does anyone now what I should do?
The same thing happens with my dishwasher. I have made it work by doing the following. When you start up the cycle, turn the dial to just a tick before "start." If you hear the buzzing, but no water is running, unlock and then lock the dishwasher door again. This usually gets it running. If it's still not running water, unlock, advance the dial a little bit, and lock again. This should work. You need to be around for the early parts of the dishwashing cycle because this machine tends to stop up and buzz without running water until it gets past "short wash." Every time this happens, do the same thing, unlock and lock, and advance the dial a little when necessary. Once you get past "short wash," it should complete the wash without intervention.
Feb 22, 2009 | GE Nautilus 24" Built-in Dishwasher
How do you "undo" the aqua stop?
create an inverted trap in ther dishwasher drain line so the water cant back feed
Jul 09, 2008 | Bosch 24 in. SGS43C02 Classixx Built-in...
Dishwashers Logo
57 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
