Question about Canon imageRUNNER 400S Copier
Paper wavy after coming out
When the copy comes out it is wavy
    Scholar:
  • 62 Answers
I've solved this million times, the problem is the rollers at the finishing area. they are small rubber rollers mounter on a steel arm. the piece has a part number as a whole piece (the rollers in the arm) there are at least two of those you've got to chance and for that you gotta remove the fixing ***'y. if more detailed needed let me know and i will gladly get those part numers for ya.
Posted on Jan 22, 2009
Copies come out severely wrinkled. What is causing this?
If the "wrinkles" are wavy or bubbly in nature then it's likely the fuser. If the "wrinkles" are making bends in the paper then it's likely there is some debris in the paper path or it is catching upon exit.
Apr 02, 2015 | Office Equipment & Supplies
Service manual hp 9800
I have an HP 9800 Deskjet that I print heavier self stick vinyl paper. The print comes out wavy. Lines aren't strait and images get blurred. Seems like the rollers might be worn causing it not to pull paper in right and centered.
Mar 25, 2014 | HP DeskJet 9800 InkJet Printer
What is a rotary paper cutter?
This is a cutter with a wheel-like blade that comes on a rail you can slide along. This lets you make cuts that are wavy or perforations. These are usually used at home becuase they are safer as the blade is wheel-like and not like a knife.
Jan 17, 2013 | Office Equipment & Supplies
Copy comes out very dark with wavy bands
try to clean the mirrors inside
if still dark and it makes over 50000 paper you need to change the drum & developer & blade
Jun 16, 2011 | Toshiba 2060 Copier
While copying a written document in A4 size paper vertically, the copy is coming horizontally and it does not copy the entire page. Even the problem occurs when the paper being copied is kept...
I would look at the paper in the paper tray to make sure the paper is going in the same direction that you wont & make sure that the paper tray is set to the correct paper size. You did not give a model, so I don't know how you input the paper size. But if the image is being cut off, one of the two things I suggested will solve the problem.
Sep 16, 2010 | Canon Office Equipment & Supplies
I got a canon imagerunner 400 and it copies very clean but the paper are very wavy when they come out
how long has the paper been in the drawer. sometime paper absorbs a lot of moisture and when the paper goes through the fixing unit the heated rollers press the water from the paper causing that problem.
Then there is the enviornment the machine is in as well.
and finally of course the fixing assembly might need rebuilt and or replaced due to heating issues.
Jun 14, 2010 | Canon imageRUNNER 400S Copier
Copies coming out wavy
If you mean the paper comes out curled then try a heavier paper or reduce the paper weight settings.
Apr 21, 2010 | Xerox DocuColor 12 Printer
The letters of the document when printed are wavy
Have you tried copying on the printer, will it also print wavy as well?
Because if you can copy fine and you cannot print properly using your printer it might be your computer. Why not use another application or program on your computer. In that case you can compare which has the issue.
Program such as MS Word, Powerpoint, Paint, Photoshop, etc
Feb 10, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Canon imageRUNNER 400S Copier Logo
221 people viewed this question
old marine
old marine
