Question about Dell Inspiron 6000 Notebook
Unit will not power up
Used after market charger plug/pack to charge unit. Computer died before i could plug in the charger. now unit wont turn on at all? there is power to the plug and its been plugged into the computer for a lil while now...but computer will not turn on
  • Dell Master
  • 32,281 Answers
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Jan 13, 2013
rachelgeek23
  • 155 Answers
SOURCE: Charging problem
It's definitely the motherboard based on the symptoms. You can send it to their out of warranty depot. Or you can purchase the motherboard from their spare parts sales dept, then look for a local tech who can install it for you.
Posted on Jan 02, 2009
  • 3940 Answers
SOURCE: Dell Laptop Charger, wont charge bat. but keeps computer running.
The center of the connetor for the AC adapter to the system has a very fine wire that is the sensing wire for the battery charger. It ID's the type adapter connected to the system. If the wire is bent or broken, the system cannot ID the adapter and the battery charger will not function.
If the wire is bent or broken, then replace the AC adapter. ALso try a different adapter and see if the issue occurs with it. If the issue happens with more than one adapter or if this adapter functions normmaly on another system, then the motherboard will need to be replaced.
Posted on Jan 17, 2009
timthorne911
  • 464 Answers
Dell has cheap chargers, the wire snapped on the inside underneath the rubber. My ex boyfriends charger had the same thing happen. You need to buy a totally new charger .
Posted on Mar 19, 2009
  • 4234 Answers
SOURCE: wont charge
The most common cause of this is the input jack being broken off of the mother board. There is a fair amount of stress on the jack which is surface mounted onto the motherboard. It is common for the connection to break off. This can be fixed easily by anyone that works on surface mounted equipment. Please note that the laptop will need to be dis-assembled to gain access to the area that needs repair. This is a fairly involved process and should not be attempted by someone not familiar with laptops. Expect to pay around $100 for this repair. No parts should be required.
Dan
Posted on May 05, 2009
leecom72
  • 4806 Answers
Hi there.
In some cases batteries tend to not charge up because one of the cells are damaged or drained to the point that they will not charge at all.
In other cases it can be the power board on the laptop motherboard itself which can have gone faulty, the only way to tell is to obtain another battery (preferably new) and see if it will charge the new one, if it does then you know that the battery is faulty, if it doesn't then you will have to take the laptop into a shop to be looked at.
This is the only way you are going to be able to work out which one of the two is the cause.
Good luck and thanks for using FixYa!!
Posted on May 07, 2009
Is it my Black and Decker PS185 18 Volt Battery Charger #418352-03 or my ps145 power pack
You need a volt meter, They are cheap and it will come in handy down the road. The volt meter will tell you if your charger is the problem or the battery has went to battery heaven.
Feb 14, 2013 | Black & Decker Black And Decker PS185 18...
My e525 emachine doesnot charge i plug the charger it work when i remove it it turns off
If the charger or power brick is able to power up the computer and you can use your computer but it does not charge the battery, then the battery is most likely faulty. They only last a few years, slowly loosing their ability to power your computer until they die.
Remove the battery and plug in the power connector into your laptop computer. Power on your laptop, if it powers on and you can use it, then you need a new battery.
Contact a computer store for a replacement battery.
Take care!
damnor01
Jun 30, 2011 | Acer eMachines 520-2890 Notebook
Power to unit but wont turn on
I own a Garmin also, my suggestion is plug it in to your computer, leave your computer on so it can charge up overnight. If in the morning it wont power on my suggestion would be to contact Garmin you may have a bad battery or some other internal problem. Garmins web site is www.Garmin.com Contact there Tech department to see what they would charge you to check out your unit. It has to be cheaper than buying a new one.
I hope this helps you out if so leave me some feedback.
Apr 03, 2011 | Garmin GPS
Left computer running with charger connected. Screen went blank and light showing power connected was no longer lit. New charger did not solve it. New battery (with some charge) worked. Still no charge so...
If your charger is working properly and the laptop is as well, then the laptop should work without a battery in it at all. If your new battery worked and laptop worked with it until the battery died, then the charger or charge port is damaged.
If it does not work with charger plugged in without a battery, then your charger(s) or the laptop charge port itself may be damage or broken. Or worse, the laptop may be dead.
If the laptop does nothing even with a good battery with charge (no fans, no boot, nothing on-screen, no noises) you're laptop could be dead; likely a burned motherboard or processor. It may have overheated or something along those lines.
Jun 13, 2017 | HP Compaq 6730s Notebook
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
My battery on my compaq cq50 140 us wont cut on
sir/mam you`re battery pack is need to re-pack or change the Battery pack.if you want to safe and long life Battery Pack if you use the unit inside youre house use only a charger then remove the battery pack from unit do not use both supply,like a battery with charger.if baterry full only battery,if you charge the battery charge only..
This is a only a tips For Long Life Battery Pack and Unit..Thanks
Apr 29, 2009 | Compaq Presario Notebook
Magellan Maestro 4250 wont charge
No the device is not defective. magellan has this stupid usb interface problem preventing the unit from being charged and used at the same time, they do that so you have to use there charger. the unit will say usb connected and will not boot up like normal at all. unit will be locked up until the usb is unplugged. most usb devices charge at 5v with 500mA, and the magellan requires 5v 1A. Ipod Charger charges at the 1A with 5v but wont work
Dec 03, 2008 | Magellan Maestro 4250 GPS
Garmin 200w does not hold charge
Hello Jeffery81,
Sounds like either a bad charger or a bad rechargeable battery pack inside of the GPS. If the unit doesn't remain powered up even when it is plugged into the charger, my guess is that the charger is the problem. Do you have an alternate way to charge the GPS? Like a 12 volt vehicle power cord or a USB cable to connect it to your computer? If so, try charging the GPS using that alternate method. If the item charges and functions normally, you will know for sure that the problem lies with the charger. If not, then the problem is either the battery pack inside the GPS or some other part of the unit's charging circuitry. In that case, you should contact Garmin technical support for additional assistance.
Best Regards,
Ken
"Go Ahead. Use Us."
May 19, 2008 | Garmin nuvi 200W GPS
I have a nuvi 200 that wont run when it is hooked up to a power supply
Vehicle Power Cable to the nüvi and connect the otchapin.screen1.jpgher end to your computer, your nüvi does not operate as a GPS unit - it goes into some sort of charging mode. However, if you FIRST turn on the nüvi in the battery mode then go into the test mode (press the battery icon for about 8-9 seconds) from the main screen, THEN PLUG in the USB cable, and finally exit the test screen, your nüvi will restart chapin.screen2.jpg(reboot) and it will operate just like it was plugged into the cradle connection in your vehicle.
This mode will charge the battery
AND operate as a GPS.
It works with my computer USB cable, my cell phone charger and my car charger for my cell phone.
Don't forget to turn off the nüvi before unplugging."
Mar 01, 2008 | GPS
The Nuvi 200 only has a 5 hour battery. Once charged, it can be removed from the charger, but the battery will only last 5 hours. Can you plug it into the car charger and navigate while charging BEFORE the battery dies? If so, and you don't have to remove the charger, you can leave the unit plugged in while you navigate without damage to the unit.
Feb 09, 2008 | Garmin nuvi 350 GPS Receiver
Dell Inspiron 6000 Notebook Logo
49 people viewed this question
Alun Cox
