It doesn't turn on - Computers & Internet
  • anwar arenas Jan 27, 2013
    the fan isnt turning on but the amber lights keep blinking... wich chips exactly should i pull out?
    Genius:
  • 1,669 Answers
I would start with the fans going on...are they? Next, if it is not booting at all, start reseating the memory chips. Pull them out completely and push them in completely. Next check to see if the drives are getting power and turning. Be sure you have a monitor hooked up to it when you turn power back on. NEVER touch inside connections or memory chips when the power is on!
Posted on Jan 12, 2013
    New Friend:
  • 36 Answers
  • If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
    • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
    • Ensure that the processor power cable is securely connected to the system board.
    • Try reseating the ram and other cables and connectors, disconnect and reconnect. If there none of the 4 error code lights on the back of the case are lighting up nor do you hear any POST beeps on startup the motherboard could be dead.
2004 Ford Taurus won't start?
get your battery checked
May 27, 2013 | 2004 Ford Taurus
DVD recorder doesn't work
what is the problem, doesn't turn on or doesn't record .
Sep 27, 2012 | Televison & Video
Engine will not turn over
A FUEL PROBLEM. It doesn't over or doesn't keep running when gas is gone. Doesn't turn over, remove spark plug to let fuel out.
Nov 12, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2002 Dodge Caravan,3.3L,Engine won't turn over at the key.Battery,starter and relay are good.Relay doesn't function when plugged in.It has 2 feeds.If you run a ground to the ground side of the...
It has 2 feeds.If you run a ground to the ground side of the relay,engine turns over but doesn,t run ????? The PCM - engine computer isn't supplying the ground for some reason . Anti-theft system problem . Disables fuel an starting systems . Have you checked for codes ?DTC'S - diagnostic trouble codes .
Mar 04, 2018 | 2001 Dodge Grand Caravan
When I turn on my Canon ir 1018 it doesn't stop heating. i.e it doesn't get ready for photocopying. It keeps on turning but doesn't stop in order to get ready.
This sounds like a faulty fuser assy. Basically the machine is warming up but nevers gets to temperature. The lamp has probably blown and for some reason it is not giving any error.
I would put a new fuser in and all should be well.
Jul 19, 2011 | Canon IR1018J Black and White Copier
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
My 1993 corvette wont start
Car doesn't turn over,but ignition turns on? Doesn't happen all the time,it just happens.. If I let it sit for a while it all of sudden turns over and starts. Happened twice this year..
Nov 11, 2010 | 1993 Chevrolet Corvette
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
