Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Picture is really dark
I tried paying around with the tint and stuff but it doesnt seem to help..the picture is really dark and a bit green. when a show has a dark scene, you cant barely seee the picture
  • 21 Answers
Sounds like one of two problems. first could be that the color convergenge chips on the circuit board have gone bad. the parts themselves are not very expensive, but a shop will charge upwards of 300 dollars in labor to do the repair. if you can solder, you could probably do it yourself. second problem it could be is a bad picture tube, but that seems unlikely since they usually last upwards of 20 years before getting weak or dim. if you are located near portland, oregon, i can do the work for you for much less. if you have any questions, please send me an email at thadoggma420@hotmail.com.
Sam
Posted on Jan 22, 2009
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
Z3 projector.3 years old. Blue tinge in one corner of projected picture. Grainy picture on dark scenes.
There may be some problem with your picture tube else try this that looks like retrace lines. Anyway, you should try to adjust screen pot not focus pot. Make sure you are turning blue screen pot (there are 3 focus pots and 3 screen pots) and do it slowly. If you turn it too much, it will affect your grayscale
Jun 23, 2008 | Televison & Video
Green tint that i cant get out, getting worse, less than a year old. Dark scenes are really bad
Another thought is that if the A1 voltage is too low, the tube will not track correctly. Either that or a replacement tube I would say without seeing the tv.
Mar 03, 2011 | Televison & Video
Picture is very blue, especially in dark scenes.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 21, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
I have a 55 inch phillips magnavox t.v. Im almost positive its a projection t.v., my problem is that the picture shows up really dark, you can see when the show is a bright show, but comes up a weird...
I would say your small signal module is bad. This is the board with the convergence ICs. Have a tech or yourself pull the board out and replace the ICs and some resistors. Checkout TVREPAIRKITS.com. They will have your model and its symptoms. Hope to guide you in the right direction!
Apr 29, 2010 | Philips Magnavox 55P9271 55" Rear...
There green tint in my picture on all my connections on vizio 47
Try shielded video cables and make sure you have your cables hooked up correctly. Sometimes you can conect them wrong, specially the red one. If you are using componet in on your tv, make sure the red one is not connected to your audio. The green tint is because you are missing red in your picture.
Mar 16, 2009 | Vizio VO47L 47 in. LCD TV
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Bad picture
My had the same problem except mine has turned yellow tint. I paid 65 dollars for someone to come and look at it and they told me that is was the Blue tube went out. They qouted me 700.00 to fix it.
Nov 27, 2007 | RCA (T120PAK12) VHS Tape (12-Pack)
TV Image not bright enough
leagreen
I'm not sure if my answer will help much, but it is free. My experieence with this site is that without paying for premium service, you won't get much help.
I had a similar problem with a different model Panasonic projection set.I got no answer on this site, but I did from an outside repairman.
Turn your color all the way down. If it looks black and white it is probably not a bulb problem. If you see a tint (blue, green, red) over the screen, it probably is a weak bulb.
The entire bottom front of my model was held on by velco and could be pulled off.
Behind this was a removable black panel. Behind this were adjustment screws for the three bulbs. This will probably only help temporarily if the bulbs continue to weaken, but it might buy you some time as the replacement bulbs are quite expensive. Good Luck
Oct 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Try # 2... Green Fog
The green gun in your picture tube is set a little too high. If you are experienced in removing the back cover of TV's,etc., you may try to find the drive and/or bias controls either on the circuit board that plugs on to the neck of the picture tube or mounted on the main circuit board of your TV. These controls are usually labeled. If you can find them, locate the green bias or drive control and back it down a little while watching the picture through a mirror. A slight adjustment may correct your problem.tJIS IS CALLED GRAY SCALE ADJUSTMENT. BE CAREFUL THERE ARE SOME HIGH VOLTAGE CIRCUITS NEARBY. WORK WITH ONE HAND AND USE AN INSULATED TOOL TO MAKE ADJUSTMENTS I hope this may help you.AGAIN BE CAREFUL!! Stargazer
Feb 26, 2007 | Toshiba 32HFX71 32" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
125 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
