Question about Bosch HBL 455 Stainless Steel Electric Double Oven
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
After changing the door hinge on my bosch hbl455auc upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
    Genius:
  • 1,669 Answers
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Posted on Jan 12, 2013
SOURCE: Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Posted on Jan 17, 2008
  • 36 Answers
SOURCE: Bosch oven won't pre-heat/heat with door closed
hi ,
according to me ,there is some issue with the cables that are connected the heat functionality of oven , because the same happned with my lg microwave , then the tech checked it , it was a cable fault , one of the cable was loose when the door was fully closed microwave was not working but when we leave some space while closing it it was working , so it is recomended if your oven is in warranty the call the company technicans to fix it , plase dont try if dont have expertis on it take help of tech who knows about microwave
Posted on May 24, 2008
SOURCE: Oven door not closing correctly
I had the same type of problem. I unhinged the door then disassembled the door (it's really quite easy)
after you take all the TORX screws out the everything comes apart! Don't worry about the screws putting them back is a snap! Now that you have the door apart take the door hinges out of the inner door plate.
If you look at then closely they will have a slight bend in them. Pay attention to how they would have been positioned on the door! Simply bend them slightly I used the edge of a step! My door now shuts completely! I hope this info helps many of you having the same problem! If you take the time it really is amazing how easy it is to solve the door issue! Thanks to my buddy RON.
Posted on Dec 03, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Plz rate my solution.
Thankyou.
Posted on Jan 05, 2009
SOURCE: bosch hbn41 ..43
BOSCH COOKER HBN41/43 GLASS ON INSIDE OF OVEN DOOR SLIPPED AND SMASHED
Posted on Mar 31, 2009
Double oven top door will not close
you need to change you oven hinges, change them as a pair cost around £40.00 to buy, not a hard job to do
Apr 07, 2010 | GE Profile JTP56 Electric Double Oven
Oven door will not close completely no tension.siemens 6 hob.
I told bosch which is the same as siemens that the door hinges are defective. I even told them how to fix the problem without changing the hinges .If you add three washers on each hinge this will bring the door in to close the same for the bosch ranges. ps ex tech:)
Feb 24, 2010 | Ovens
Bosch HBL 645 oven door won't close all the way
I am afraid that the door hinges are non adjustable, and the only solution is to replace them as a pair.
There should be some kind of latch mechanism at the end of the hinge
where it is fastened to the door to compress the hinge to enable you to remove them.
Hope this helps.
Jan 04, 2010 | Bosch Ovens
Bosch Double oven - top oven will not open - seems like it is locked
i am not aware of a bosch oven that locks the top door usually only main oven will lock if self clean pyro oven,the small oven never has this feature sounds more like a hinge problem check nothing is fouling the lower part of the oven door.
Dec 30, 2009 | Bosch HBL 755 Stainless Steel Electric...
Oven door will not close completely stays open about 1/4 inch
Hinges may need to be replaced. Rule of thumb, if one is changed, change the other as well. Also try WD40 open and close continuously, it may be stuck. But you will eventually have to change the hinges. Good luck.
Sep 03, 2009 | Bosch Ovens
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Nov 06, 2008 | Ovens
Aug 06, 2008 | Bosch HBL 435 Stainless Steel Electric...
- Secure lock nut.
Nov 14, 2007 | Bosch HBL 742 / HBL 746 Electric Single...
Bosch HBL 455 Stainless Steel Electric Double Oven Logo
328 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
