Question about Kenmore Elite 45986 Front Load Washer
List of error codes
Flashing f and then dl
    Sergeant:
  • 291 Answers
There is a panel at the bottom of your machine. There should be 3 screws at the bottom if it. Remove the screws and the panel. Usually there is a service booklet in a ziplock taped to the inside of the panel. If so it will contain all service codes. Let me know if it's not there.
Posted on Jan 12, 2013
  • B.H. Countryman Jan 12, 2013
    Codes are different for different machines and not sure if it's a door lock issue or long drain issue. If long drain you will need to clean the drain pump filter. If door lock issue door lock may need changed. Let me know.
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Whirlpool Duet HT Washer flashes code F dL.
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check Door Lock/Switch Assembly
Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
Mar 14, 2013 | Washing Machines
My maytag bravos washer is flashing DL, what does this mean, its not spinning!
The "dL" error code appears when an item inside the washer prevents the lid from locking properly. Open the washer and readjust any items that may be hitting the lid. The error code should go away once you properly close the lid
May 03, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
Error code dl
Hello,he "dl" error code indicates a problem with the door latch assembly.There should be a tech sheet inside the washer. It's usually located behind the bottom panel under the door, or along the inside of the casing on either the left or right hand side. The tech sheet will have a list of error codes, procedures on how to perform diagnostics, and troubleshooting hints. It's strongly recommended that you leave the tech sheet inside the washer, so you don't lose it.
Repairclinic.com carries the door latch for about $50 and is listed as item number 1094190.
Thanks
May 23, 2010 | Frigidaire ATF6000ES Front Load Washer
Flashes a code of "dL" and "F"
NOT MUCH INFO TO GO ON, BUT HERE GOES" A DL CODE IS A DOOR LOCK ERROR, A F CODE USUALLY HAS A # AFTER IT AND WOULD INDICATE AN ERROR. W/P HAD SOME MODELS THAT REQUIRED CHANGING THE DOOR LOCK-MECH AND CONTROL BOARD . HOPES THIS HELPS, PLEASE CONTACT ME @ HUBAPPLIANCE@COMCAST.NET AND PLEASE RATE ME.... THANKS
Jun 24, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Flashes "DL" and "F"
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code on the washer machine
DL/F is a door unlock error the door lock may be broken.
Mar 18, 2009 | Whirlpool Washing Machines
Error code DL...
DL indicated a door lock failure. it will flash DL, then a F followed by a number (80, 82, 84, 85)
Jan 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
20 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
