Question about Janome Harmony 9102D Mechanical Sewing Machine
Tension settings for a janome 234d overlocker
Show diagram indicating differential and looper thread
3 Suggested Answers
fixitruss
  • 6 Answers
SOURCE: Janome 134D Overlocker
Set you differential at 1.0 and your loopers at about 3-4 the needle thread tensions are usually around 5 to 6.
 I would also suggest that you place four different color threads on machine to make it easier to adjust all. Now if you are using only 3 threads the same applies.
 Also------patience.
Posted on Oct 10, 2007
chris592
  • 86 Answers
SOURCE: I have a janome 234D
This is a tricky problem, without being in front of the machine.
1. check that thread comes thru machine with ease (pressure foot up)
2. rethread machine starting with lower looper (right hand thread)
3. make sure that when pressure foot is down there is some tension on the thread, (sometimes stuff gets stuck in the tension discs)
4. if that fails, suggest having a repair service check it out for you.
Posted on Apr 02, 2011
I need help in good tension for rolled hem in empisal 606D overlocker
Your owner's manual should have instructions for rolled hem settings. My Bernina manual has a the following settings:
Medium weight fabric
80/12 Universal needle
3 cones serger thread
Upper looper 3-5
Lower looper 7-9
Left needle (no thread)
Right needle 3-5
Stitch length 1-1.5
Cutting width 2-3
Differential feed N
Can use woolly thread in the upper looper, but the tension may need to be loosened since the woolly nylon thread will stretch.
Make It Handmade Threading Your Serger or Overlocker
Dec 19, 2015 | Sewing Machines
I have a new home janome model number 534 how do I
The Janome 534 that I know is an overlocker (or serger). If this is so, then when you open the front flap / door there should be a diagram showing the thread path. It is important though to first thread the inner (upper) looper, then secondly the outer (lower) looper, thirdly the inner (right) needle, and lastly the outer (left) needle.
Oct 09, 2014 | Sewing Machines
How do I sell problems
tension on an Elna L4 overlocker (or serger in USA) is controlled with the four dials on the front of the machine, an overlocker has a tension dial for each thread (usually 3, 4 or 5) and the mid range setting will be 5 on each dial. It is critical to lift the thread pole to its maximum height and follow the threading diagram correctly taking the thread from the cone, through the thread eyelets on the pole, then usually a thread carrier on top of the machine, down and around the tension dial, then usually through another couple of thread carriers until reaching the needle or loopers. Many overlockers will have a threading diagram inside the front looper cover and will use colour coding on the components so you can see where each thread goes.
Jun 02, 2014 | Elna Sewing Machines
What are the settings for overlocking stretch fabrics
For knits with lycra in, you are best to thread up four threads and seam with the 4 thread marrowing stitch like this, preferabbly with ball point needles in your overlocker, size 80. Use cones of polyester thread, 3,000 metres or 5,000 metres rather than normal thread. (Although if you have trouble matching thread colours you can use a small reel on the left needle as this is the thread that will show on the right side of the garment.)
Start with your machine tensions on 5, both needles in and threaded, stitch length of 2.5 and no differential (set it on zero) and test stitch. Using stretch or ballpoint needles is a good idea too to avoid any deflection and skipped stitches. Then practice serging on some fabric scraps, double layer and look at the seam, if it is tunnelling (pulling up the fabric), then move the cutting blade to the left. Test again and if still tunnelling, then loosen off the tension on the top and bottom loopers by a half number and test again.
If the opposite is happening and the threads are looping off the edge of the fabric, then move the cutting blade to the right to trim less fabric, test again. If still too loose, then tighten up the top and bottom looper tensions by a small amount and test again.
You want the seam to lie flat, the two looper threads to meet right on the cut edge and the needle thread to be just visible from the right side when you press open the seam.
There is always a small amount of adjustments needed on an overlocker when setting up for a new project as every fabric will behave differently. Don't tighten up the tension on the needles much past 5 though, or you may get thread breakage.
If you find that the seam is flutting then you can use the differential feed to adjust for this too.
There is some good overlocking info on Debbie Cosgroves website, www.sewing.about.com, with images which may help too.
Nov 07, 2011 | Janome MyLock 634D Mechanical Sewing...
How do I oil my Janome 664d overlocker
Does your overlocker have a threading diagram on the inside of the front cover? Often this will also show a couple of red dots where you need to oil.
Obviously always best to consult the manual if you have it; I haven't been able to find an image of the threading or oiling diagram for your machine.
If it doesnt have this diagram and you don't have a manual then I would hazard a guess and say that you need to oil the loopers where they move through another metal part. So open up the front and have a look at the lower looper mechanisim, manually turn the flywheel to move the looper and you should be able to see what I mean. The lower looper will move back and forwards through a metal socket piece and the looper bar may look lubricated on each side. So give the metal holding bit a drop and the oil should work into it. There may be a similar looking bit for the top looper, have a look and give it a drop of oil.
Some overlockers will have an oiling point at the back of the sewing table, it may be a little hole marked with red paint.
Sep 06, 2011 | Janome MyLock 644D
How do I thread a janome 204d serger
Serger may have a threading diagram inside the front looper cover which should show the various thread eyelets that you need to pull the threads through and they may be numbered one to 4 also to indicate order of threading. The diagram is usually colour coded to match the tension dial colours and serger usually has colour dots on the different thread eyes to help you follow the thread path for each thread.
This video is great and hopefully will help you http://www.youtube.com/watch?v=zszJYQe2aws&feature=related, it has lay in tensions while yours has dials so just pull the thread around the dial right to left and then across to the next thread eye and this should pull the thread into tension. Dials are usually all set to 5 for normal stitch formation.
On my serger you thread up in the following order: top looper (second from right dial), bottom looper (right hand dial), then right needle, left needle; this video shows all threading going from right to left however, so if you have a numbered diagram inside your thread cover, then certainly use that order. But always loopers before needles.
Raise the thread aerial first before you start, put the cones onto the thread spools and if you have any cone holders (little plastic triangles) put them on the spools first to steady the cones. Now for each thread, take the thread tail from the cone, up through the aerial thread guide, then follow the coloured dots and take this down the front of the serger putting it into each coloured thread guide, through looper then up under the raised pressure foot. Repeat for next looper, then the needles.
Pull all 4 threads out under the foot to the left, lower foot, then chain off a little to start and test sew on fabric, adjusting the tensions if you need to.
Other adjustments are stitch length (usually a knob on right beside the flywheel numbered 1-4, blade position, a dial either left or right of the blade, press on the blade to release the tension on it before you try and move it. And differential feed, this is also a knob numbered 0.5 to 2 usually. If you can't see this on the right by flywheel then open up fabric plate (left cover) and look in there for these two adjustments.
I would suggest you start with tensions on 5, and stitch length of 2-3, and test sew on scraps of the fabric you wish to overlock. You can then either move the blade to cut wider or narrower to suit and adjust the two looper tensions if you need to close up the thread on the cut edge. There is no black and white settings as each fabric will behave a little differently, generally you adjust the looper tensions a bit until the stitch is encasing the cut edge and you have a seam width that suits the weight of the fabric.
Differential feed leave on zero unless you find you need it when a loose weave fabric goes wavy, then turn it down to close up the feeding. Sergers have two feed dogs, one before and after the foot and turning differential knob changes the ratio of feed between the two so either stretches the fabric, or pushes it together as it goes through the stitching sequence. So by turning differential feed up to 1.5 or 2 you are stretching the fabric and you can do a narrow rolled hem edge that is all fluted (lettuce edging).
I hope this helps you out a bit, if you are completely new to this machine and have never used a serger then I always suggest taking a class from a local dealer, it is really worth the money and time as they are quite different to sewing machines but once mastered, really change the dynamics of sewing and techniques are much more like commerical production with flat construction etc.
May 22, 2011 | Janome MyLock 204D Mechanical Sewing...
I have a janome 234D overlocker and when I start sewing the first thread (red) comes unthreaded....
Apr 02, 2011 | Janome Memory Craft 4000 Sewing Machine
The needles on my Janome 9102D keep breaking
I had a similar problem with my machine. What I've started doing with mine is setting the stitch length at 3 and the differential feed ratio at 1.0 then I set all 4 thread tensions at 3. I thread the machine from right to left, and then when everything seems to be working okay I take scrap material to test the tension and then set them to suit the material I'm using. Right now I'm working with a twill so my settings are 4-4-5-5. This seems to have stopped the thread slipping off the bottom looper and I haven't had any more needles break. I hope this is helpful.
Dec 02, 2008 | Janome Harmony 9102D Mechanical Sewing...
 Also------patience.
Oct 09, 2007 | Janome MyLock 634D Mechanical Sewing...
Janome Harmony 9102D Mechanical Sewing Machine Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
