Question about Refrigerators
My Kenmore Refrigerator Model#106.53569202 will not make ice. .
I dont think it is getting water. It seemed to be working fine until I replaced the filter. The filter is installed properly and the water in the door is working fine.
  • 247 Answers
SOURCE: kenmore refrigerator ice/water in door not working
welcome-
what type of kenmore do you have (brand and model number)? this way it is easier to find infomation for you.
thanks and happy holidays
Tom
Posted on Dec 19, 2008
SOURCE: Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Posted on Apr 16, 2009
SOURCE: My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Posted on Feb 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: MY ICE MAKER WON'T WORK
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
heatman101
  • 43501 Answers
SOURCE: refrigerator ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnnmbnm
Posted on Sep 30, 2010
"I have a kenmore coldspot model 106.54382300. The freezer is working fine, but the refrigerator doesn't seem to be cooling. We just bought this used and it has worked fine until tonight, when we finally...
Can you hear a small fan blowing air inside the refrigerator? It sounds like the evaporator fan has gone out and it is not transferring the air from the freezer to the refrigerator in order to cool!
Oct 09, 2014 | Refrigerators
I have a Kenmore side by side model # 106.53609202 and its about 8 years old. About a month ago it stopped making ice. I've already replaced the water valve behind the fridge and waited 24 hours and...
OK, remove the cover on the face of the ice maker and let me know if the model look like this picture:
12_17_2011_1_36_01_am.jpgIf it looks like this model, I have the service manual for it with all the testing procedures.If it doesn't, see if you can get a model number off the unit. They make about 4 different model for this unit.
Happy Holidays!Richard
Dec 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore refrigerator model 106.56542400. The ice-maker does not work though the cold water works fine. How much it will cost me? Trying to see if buying a new one is cheaper. Thanks.
The cost depends on where the problem is. For example: If the ice maker is NOT getting water to make ice then it is probably the 2 line water valve solenoid or the sensor on the ice maker that would tell the 2 line water valve solenoid to send water up to the ice maker tray. Both of those replacements will cost you in the neighborhood of $25.00 - $40.00 plus a service call if you aren't able to do the work yourself.
If water is getting to your ice tray, but not kicking out the ice into the bin - that is usually a motor problem. And cost you as much as what a replacement ice maker would cost you.
To give you an idea of the cost of parts here is the layout for your unit: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10656542400/0582/0165000/K0707001/00012
Jun 24, 2011 | Kenmore Refrigerators
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Kenmore side by side refrigerator model 106.5702 will not make ice.
your ref board seems to be working fine
Did you test the water valve???
if yes and water valve works, than replace the Ice Maker
May 11, 2008 | Kenmore 53703 / 53706 Stainless Steel Side...
15 year old Kenmore side by side refrigerator
I had the same problem and had to have serveral parts replaced, it was very expensive $600.
Good Luck
Kathy
Sep 21, 2007 | Kenmore 22.0 cu. ft. Side-By-Side...
Whirlpool Side by Side Refrigerator Model # ED2FHEXNQOO
POSSIBLE YOU HAVE 2 SEPERATE WATER SOLENOIDS. THE SOLENOID FOR THE ICE MACHINE HAS A STRAINER AND ORFICE JUST INSIDE THE INLET SIDE OF THE WATER CONNECTION. CAREFULLY REMOVE THE ASSEMBLY AND CLEAN-IT. YOU CAN CHECK IF ICE MACHINE SOLENOID HAS POWER BY TAKING A METAL BUTTER KNIFE AND HOLDING IT JUST ABOVE THE COIL ... THE MAGNETIC FORCE SHOULD BE FELT TUGGING THE BLADE DOWN. LOSSEN THE NUT ON THE OUT-LRT SIDE OF THE ICE MACH. SOLENOID AND SEE IF YOU HAVE WATER ...
Apr 26, 2007 | Whirlpool GD2SHGX Refrigerator
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
