Write an equation for the transformation of y=x
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
There are an infinite number of transformations. One is the null transformation, giving y=x .
Posted on Jan 12, 2013
Write an equation for each transformation of y=x
There are an infinite number of transformations and there isn't enough room here to list them all. One is the null transformation, giving y=x .
Jan 12, 2013 | Office Equipment & Supplies
3x+9y=17
  1. Transform this equation to its functional form:
  2. 9y=-3x+17 or y=(-1/3)x+17/9
  3. In the last equation, the slope is the coefficient of x, namely -1/3.
  4. A line parallel to this one must have the same slope (-1/3).
  5. So the equation of your line starts this way: y=(-1/3)x+b.
  6. To identify (calculate) b, you must make use of the fact that the parallel line passes through the point (1,5).
  7. That means that the coordinates of the point (1,5) satisfy the equation of the parallel line y=(-1/3)x+b
  8. Substitute 5 for y, and 1 for x and solve for b.
And that is as far I will go. I leave it to you finish up the work : find b and write the equation in the functional form, then convert it to the general form (Ax+By+C=0) if that is what you are asked to produce.
Aug 05, 2012 | Office Equipment & Supplies
How do i factor
This calculator is unable to factor a polynomial expression.
In general there are a few factoring methods
  1. Factor by grouping terms
  2. Factor by completing the square (quadratic polynomial)
  3. Factor by finding two integers such their sum is equal to the coefficient of the middle term, and their product is equal to the third (constant term). This is valid for a quadratic polynomial where the leading coefficient (of the x^2 term) is equal to 1. X^2+SX+P
A cubic equation can be solved algebraically, although two solutions may be complex. Use the Cardano formulas. A quartic equation can be solved by the formulas for the quadratic equation, if you transform the quartic equation to look like A(X^2)^2 + B(X^2) +C=0
Jul 31, 2012 | Casio FX-115ES Scientific Calculator
I am trying to see 2 different tables on my table screen from 2 different equations, but it when i go to the screen, instead of showing 2 different tables, it only shows one of them. I also noticed that...
In the Y= equation editor you can enter two functions, and graph them both or calculate a table for both. However, the two functions will be evaluated at the same values of X.
Rather than trying to guess what is happening, I will show you how to get your two tables.
If you have used one the applications Inequalz or Transform it si probably still stuck in memory, and you must unload it from the RAM before recovering the usual calculator behavio(u)r
  1. Press the [APPS] button, find Inequalz or Transform, point to it and click [ENTER].
  2. You will be asked to Continue or Quit the application.
  3. Press the number corresponding to Quit (usually 2).
  4. Press [2nd][Y=] (STAT PLOT). Press [4:PlotsOff][ENTER]
  5. Calculator replies Done.
Open the [Y=] equation editor. Type in your equations. Press [ENTER] at the end of each equation. Verify that the [=] signs after Y1, and Y2 remain highlighted when cursor is moved away from them.
Press [2nd][GRAPH] (Table) to see your 2 tables y1 and y2 calculated at the same X.
Hope it helps.
Thank you for rating the solution.
Dec 10, 2009 | Texas Instruments TI-84 Plus Calculator
My calculator will only graph one graph at a time.
This is simple... Back up all RAM, (press second+, then 2, then 1, press enter to back up something if backed up it will have a star by it) Then clear your RAM (pull out your batteries while the calc is still on or press second+, then 7, then 1)
Hope this helps!
Oct 07, 2008 | Texas Instruments TI-84 Plus Calculator
MATH Graph Style Icons
go to apps menu, go to transform app. click uninstall and go to y= screnn and should be a slash on the left and you should be able to graph more than one equation.
Aug 27, 2008 | Texas Instruments TI-84 Plus Calculator
Solving multiple non-linear equations
Type it like this: solve( equation1 and equation2 and moreEquations, {list of variables to solve for})
Put all of your equations right after the opening parenthesis separated by the word and, then a comma, then within curly braces each variable you want to solve for each separated by a comma.
Apr 26, 2008 | Texas Instruments TI-89 Calculator
Graphing
The first solution will allow you to watch your calculator graph two equations simultaneously rather than finishing one before graphing the next; it won't solve the problem of having the calculator unselect one equation when you select a second. To fix that problem, try the following:
In order to select additional graphs, the Transformation Graphing App will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family. Uninstalling the App does not erase it from the calculator, it disables it from interfering with the normal graphing modes. Below are the steps to successfully uninstall the App.
  • Press [APPS] key
  • Select Transfrm from the menu
  • Press 1:Uninstall
The illustration and solution are courtesy of Jesse Phillips, who cites this page from the Texas Instruments support site
- doug garfinkel, Children's Day School
Jan 15, 2008 | Texas Instruments TI-84 Plus Silver...
Graphing circles
You have two methods for drawing a circle on the FX-9750GPlus.
  1. Use the Conics graphing: The general equation of a circle is aX^2 + aY^2 + bX+cY+d=0
  2. Use the function graphing. But before you can do that you must transform the general equation (above) in such a way that you can write it as Y^2= X^2+EX+F. From this you can find the two branches Y1=SQRT(X^2+EX+F) and Y2=-SQRT(X^2+EX+F)
Oct 09, 2007 | Casio FX-9750GPlus Calculator
14 people viewed this question
k24674
jasbo
jasbo
