Question about Cell Phones
How do set auto answer feature?
Just bough this phone and it has auto answer feature. But i checked everything i could on phone to set feature nothing in manual as well
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cell Phones Master
  • 102,366 Answers
What make and model is "this" phone?
Posted on Jan 12, 2013
  • kman Jan 12, 2013
    it is a samsung sgh c414m
2 Suggested Answers
  • 31 Answers
SOURCE: Auto Answer
Hello PattiPaige,
The feature to disable answering the phone when you open the flip can be found under:
Settings & Tools
- Call Settings
- In Call Setup
- Answer Options
- Set option to Off
This will disable the flip from answering the call when opened.
As for increasing the font size, i don't believe there is an option to do so. If I become aware of one I'll try to get back to you on.
Hope this helps,
cHiPz
Posted on Mar 24, 2008
How do I turn off auto answer on Alcatel fierce XL
How to Reset the Alcatel Onetouch Fierce 2 XL Auto answer problem.
Out of the box many Alcatel OneTouch Fierce devices are configured to auto answer. There is no menu option to modify this. The ONLY solution is a FACTORY Reset
How to: Tap: Settings, Backup & Reset, Factory Reset, Erase all data, the phone will reboot and function normally thereafter.
Dec 30, 2015 | Alcatel Cell Phones
Sharp plain paper ink jet fax ux-b750
to stop the fax automatically switching to fax mode you have to set it to manual to recieve calls and dissable the fax,there should be an auto/fax and call mode, therefore when someone calls it will go to your voicemail, but that means that you will not be able to recieve a fax. Normally auto mode, will first try the fax, if no fax is recognised it will switch to normal line ringer, then if no answer it should go to your voicemail if unanswered.
Oct 01, 2007 | Office Equipment & Supplies
How do you take off auto answer on alcatel onetouch fierce xl 5054
good The trophies list is certainly at the end of this document, original site Trophy themselves, Snapchat is definitely extremely nice.
Dec 12, 2015 | Alcatel Cell Phones
How to receive a fax
Check if the auto answer is turned on. Also, check the ring pattern if it is set to Auto. If this is a shared line with your phone and you have an answering machine, set your fax to pick up 5 rings higher than your answering machine.
If you have a voicemail service, you'll need to get a distinctive ring feature from your phone company for it to work.
Apr 13, 2012 | Lexmark Prospect Pro205 Wireless...
My phone keeps sending everything to voice mail, but i want it to just go to regular answering machine, how do i change it? The red light at the bottom next to voice mail is on. I've looked through the...
You'll need to find out from your phone service provider how to disable or change the settings on your voice mail. The service is part of your phone line and has nothing to do with the phone, so it's not covered in the manual. Normally the phone service provider gives you a set of instructions (or provides them on their website) explaining how to use the features on your line.
You typically enter "star codes" (*72, for instance) to enable a feature or change its settings. Voicemail usually has two modes: "busy", where it will pick up a message if your line is in use, or "no answer", where the voicemail picks up after a set number of rings. You would want to choose "busy" so that your home answering machine will take the call when you aren't on the phone, and voicemail only kicks in if someone else calls while the line is already in use.
Contact your service provider and they should be able to tell you the magic codes for your system.
Feb 27, 2011 | AT&T DECT 6.0 Cordless Phone System with...
Will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
Jul 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How do I turn off the automatic answering feature on mu Samsung s3500
hello,
1. go to the menu,
2. select the settings,
3. select call settings,
4. you'll see the answer option,
5. turn off the auto answer,
take care
May 30, 2010 | Samsung S3500 Cell Phone
Auto answer cell phones
the lg voyager as the auto answer feature.
May 08, 2009 | LG Incite Cell Phone
How to set the auto answering system
My TAW-848 has FOUR manuals. Which one are you looking in?
The auto answer is either controlled from the AUTO ANS button on the phone, or programmed in the system. Since each system is different, you need to look at the Operating/User manual for personal features for your phone. In the TA, it's PROGRAM 41 for TONE call and then the AUTO ANS button will work. IIRC (bench system is in the van at the moment) if you use 42 for VOICE call, the AUTO ANS button won't work at all. It's similar in TAW and TDA systems.
Carl
Nov 10, 2008 | Panasonic KX-T7730 Corded Phone
Can't turn off mute on panasonic phone
[Mute /Auto Answer] is a dual function button.
Mute flashes when it is on and Auto Answer lit solid. Both of these features toggle on and toggle off. Auto Answer will turn on and off during the on-hook condition. Mute is employed during call.
If these lights are not associated with the Mic working, you may have a bad set.
Jan 05, 2008 | Panasonic KX-T7453 Corded Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
