Question about Samsung HL-T5076S 50 in. TV
I bought this tv used today. The hdmi port was used from the cable box to the tv when I looked at it . Now at home, my cable box only has the coax port to hook up the cable and I'm showing weak or
    Habit-Forming:
    New Friend:
  • 5 Answers
What's the problem? could you tell it again? i can not understand, there is no hdmi port on your cable box? or what?
Posted on Jan 12, 2013
5 Suggested Answers
  • 9 Answers
SOURCE: weak signal showing on my l e d samsung haven't used it yet (new)
Try to double check the power cable is well connected if so you have to know that some screens come from the factory with some problem and in this case you have the right to replace it from the seller.
Posted on Dec 16, 2008
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
tvservice306
  • 458 Answers
SOURCE: Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Posted on Jan 01, 2010
Testimonial: "Thanks for the info! Very helpful!"
  • 159 Answers
SOURCE: The coax input on my
Hi, unfortunately the only ways to get the signal to the tv is with either coaxial, the red white and yellow rca cords, or hdmi and also the " RGB " inputs, also called "component video input ". some dvd players have component video outs-that could free up an hdmi port for you-same goes with cable boxes-if you have hd programming then your cable box may have an hdmi connection-if no hdmi it may have a " DVI " port, this is short for digital video interface-you then connect that to flat screen directly or if tv has no dvi input-they have dvi cables for component video inputting ( there will be the retangular dvi jack on one end and red green and blue rca cable ends on the other.). So shy of opening up televion and resoldering the broken coaxial and composite video input ( the yellow cable connection) that's about it. Thanks, I hope was of some use-and good luck, Prodzilla
Posted on Apr 13, 2011
My Comcast remote quit working with the cable box. The guide wont come up any more and my hd doesn't look like hd....just standard. I went to look in the back and I thought I had hd but I only have coax....
You need an hd cable between your cable box and tv. They don't provide them for free. Once you plug in your hdmi cable to the tv, change its input to the hdmi port you just plugged into. The guide is updated by the cable system on their internet but over the coax. Give it time, it should come back. If not, reset the cable box by unplugging itfrom the wall power, wait 5 seconds, plug it back in. It should come back.
Sep 02, 2017 | Televison & Video
Panasonic DMR - HW100ebk.......... with both coax
So you have looped the coaxial through the Panasonic to the TV and have a HDMI from the Panasonic to the TV, right. When you turn on the DMR select the appropriate HDMI connection with the TV remote and you will be OK.
Oct 11, 2013 | Televison & Video
I have a hitachi p50h401 and sound went out. someone said update software how do you do that? Thank You
well if the sound went out it may have only effected 1 output source, What type source are you using, HDMI, RCA, Composite, DVI, VGA with mini adapter? If for example the HDMI, port you are using has simply lost sound to that port, HDMI carries both sound and video so simply moving to HDMI 2 or even 3 may solve this issue. Also i would suspect the cable you are using, HDMI cables are often defective. If you are using coax thru your cable company i would also change that coax from your tv to the hd box.
May 28, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Hello I received a lg flatron plasma MZ42PZ14 and just wanted to connect the tv cable to the tv, but i can't find any coax on the tv. what can i do?
This kind of tv u must have cable or satalite tvs pay broadcasting signal cable,so u have a box .Tv have HDMI ports or RCA AV component cable input?The incomming broadcating tv signal go to the cable or satalite boxes.Than u use a HDMI cable or RCA AV component cable go through those boxes than to ur tv HDMI input ports or RCA AV component cable input holes.
Jan 22, 2011 | LG MZ-42PZ14 42 in. Plasma Television
I plugged in my cable HDMI into my RX - V365 Yamaha reciever. and HDMI into my TV. I get video, but cannot get my attached (to reciever) speakers to play. Help
RX-V365 doesn't support HDMI audio. You need to connect the cable box also via spdif cable for audio to work. Look at the box if it uses optical spdif or coax spdif. If optical, you see that optical input on receiver is named DTV/CATV, so use also DTV HDMI for video. Coax spdif is named DVD, so in this case you will need to use DVD HDMI input.
Also you need to configure the inputs accordingly.
Nov 14, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Philips hts3565d
WHERE CAN I GET A WIRE DIAGRAM TO WIRE UP SPEAKERS AND TO THE TV AND DVD PLAYER.I BOUGHT ONE USED AND THERE WERE NO INSTRUTIONS IN THE BOX.THAKS
Jun 15, 2008 | Audio Players & Recorders
Cabling -- Panasonic LCD TV into LG DVD player (model no. DV6812P)
Take the basic Red, White, Yellow component cable -- plug it into the backside of the DVD player and plug the other side into the back of the t.v. Make sure to plug the right colors into the right sockets. If there are no available AV inputs on the back of the t.v, plug the other end into your cable box (if you have one).
Mar 03, 2008 | Televison & Video
No HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Feb 16, 2008 | Denon AVR588 Receiver
Samsung HL-T5076S 50 in. TV Logo
104 people viewed this question
Jerry Greenberg
Jerry Greenberg
