Question about Bose Acoustimass 15 System
Acoustimass Subwoofer has a low "hummm" sound when turned on.
I have a Bose Acoustimass 15 system. The small surround speakers work just fine. However, the Subwoofer module emits a low "hum" sound when unit is turned on. I unplugged all the speaker wires from the back of my stereo receiver, and the "humm" still exists. The only time the humm stops is when I unplug the receiver cable connector from the subwoofer module.
I removed the cover from the subwoofer and replaced the fuse, thinking that somehow that might fix the problem, however, the hum is still there. It is a constant hum that never goes away, and it is impossible to use the system. Any help or suggestions would be greatly appreciated.
Thanks!Acoutimass 15 contstant deep hum is happening with mine too. What was the solution to this problem. I want to keep this unit but need some techincal advise from someone who fixed this. Thx.
  • Bose Master
  • 19,396 Answers
The huummm is either a short on the speakers cable, or one capacitor in the amp circuits had blown, or the unit is not grounded.
Check if speakers cables are OK, if it is not speakers cable, then the unit must be taken apart and tested by a technician.
Posted on Jan 23, 2009
    Sergeant:
  • 221 Answers
Its not at all due to fuse its due to connection getting loose on the main board needs dry soldering on all the junctions and complete drying for 24 hours.also can happen if the ic is at its last stage can happen due tio any component getting overheated.
Posted on Jan 22, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Check the main wire it might be going short with the body of your woofer . Check the ground wire and make it properly connected to the body .This humm is coming due to the "AC" current which flowing in the body.
Thanks
Rylee
    Genius:
  • 1,269 Answers
A humm is probably caused by a grounded electronic component or parts. Sometimes, its due malfunctioning poetentiometer, you need to check that. Also it may require checking the board for faulty capacitor like a bulge or burned one. If you found one, replace that.
  • 679 Answers
It sounds like a bad ground, Run a wire to a pipe, if you can just to see, if you have alligator clips and a wire, that will work. I was just reading this morning about a device that establishes a better ground connection for the same issue. If I have time i'll backtrack it otherwise 9 out of ten times that is what is is
  • George Bill
    George Bill Jan 23, 2009
    How did you make out?
    President:
  • 1,214 Answers
A low frequency hum will occur when the wire connections between components (speakers) are not clean, tight, and neat. It's easy to cross wire when things are not neat. It is also possible that any factory supplied cabling has a broken wire inside of it, causing the problem.
I have a Bose Acoustimass 6 Series III the receiver is Yamaha 3066, this system is a 5.1 surround sound. Then I bought a pair of Bose 901 Series VI Direct/Reflective speaker system with active equaliz
The setup is possible, but with several compromises. First off, to use the active equalizer, you'll need to insert this into one of the 2 channel AV channels limiting your listening with the equalizer to stereo only. The acoustimass subwoofer acts a driver/power regulator for the little cube speakers. It probably will not be able to drive the 901s at the correct level when attached to the Acoustimass unit as front left/right speakers. You could try running a dedicated set of speaker leads to the 901s which may work and still allow surround sound, but you'll lose the equalization capability on the 901s.
Jan 21, 2015 | Bose Audio Players & Recorders
Bose acoustimass 15 no sound out of left and right speaker
The left and right front speakers may have been blown
Jan 28, 2013 | Bose Acoustimass 15 System
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
Have this Bose system connected to my Yamaha a/v receiver
If you have it literally conencted the way you say not much good will happen.
The speaker OUTPUTs for the Yamaha feed the INPUTS on the Acoustimass Module then the satellites branch out of the Acoustimass Module's OUTPUTs.
Acoustimass module
Bose® recommends putting your Acoustimass module at the same end of the room as the
television monitor. To prevent interference, keep the module at least 2 feet (.6 m) from the
television.
• You may hide the Acoustimass module behind or under furniture, but do not block the
opening. Be sure there is at least 2 inches (5 cm) between the opening and any surface.
• If the opening faces the wall it increases the bass; if it faces away it decreases the bass.
For the most bass response, place the opening 2 to 3 inches (5 to 8 cm) from a wall or
corner.
• Stand the Acoustimass module vertically or horizontally (Figure 6). To stand it on the
cable connection end, remove the cover by gently pulling it away
Move the sub closer to a wall or corner to increase the bass.
This is a SYSTEM and as such is not designed to be pieced out or separated. I don't recommend that you try it that way. I doubt it will improve the sound.
Apr 30, 2010 | Bose Acoustimass 10 III System
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Apr 23, 2009 | Yamaha RX-V663 Receiver
Center, and rear surround speakers
Sounds like the rear volume is just turned down. Cant be the amp if the front and subs are working
Aug 28, 2008 | Bose Acoustimass 15 System
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Aug 04, 2008 | Bose Acoustimass 15 System
Bose cinemate acoustimass module
try taking ones apart that have the rumbling and see if theres anything loose inside
Jan 21, 2008 | Bose Cinemate Digital Home Theater System...
Bose Acoustimass 15 System Logo
187 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
