Question about Connectify
It writing AP not supported - Connectify
How to Create a Wi Fi Network With Just a Computer?
Does your computer support wifi?
If it does, you can create a network through softAP. You need to write some lines of code to activate softAP. The work around is to download a free software called 'iball soft AP manager' (link is http://iball-soft-ap-manager.software.informer.com/download/). You may (or may be not) have to download the driver software for your wifi card as well.
Oct 18, 2016 | Computers & Internet
How Does a STA Synchronize the Channel When the Associated AP Switches to Another Channel?
  • If both the STA and AP support channel change notification, the AP sends an action frame (802.11h) to the STA after the AP switches to a channel. The action frame is used to notify the STA of switching the channel immediately or after n Beacon intervals. The STA then switches the channel and retains online.
  • If the AP supports channel change notification but the STA does not support channel change notification, the AP sends an action frame to the STA, notifying the STA of switching the channel immediately or after n Beacon intervals. The STA does not process the action frame, and goes offline after the AP switches to the channel.
  • If the AP and STA do not support channel change notification, the AP switches to a channel and the STA goes offline.
S2300 Switch Thunder link com
Oct 11, 2016 | Computers & Internet
Hard reset ap 6511
Dhruv-
Please contact Motorola Solutions for assistance. portal motorolasolutions com
Mark
Motorola Mobility Support
Sep 02, 2014 | Motorola AP-6511 Access Point
I downloaded google phone ap. When making a call, i can hear them, they cant hear me
Was the ap specifically designed for the ipad? Try a different phone ap, worst case. Write a message to the developers about your problem, they are happy to fix any problems you run into. It helps the sales of there program, in one way or another.
Mar 23, 2014 | Apple iPad 32 GB WiFi Tablet PC
How to resolve wifi access mode not supported
an AP is used to extend you wireless range and will connect to your router to provide network and internet access. An AP by itself cannot connect to the ISP since it does not use a WAN port
a router is an AP that will allow you to connect to your ISP for internet connection. A router can be configured to work as an AP but a AP cannot function as a router.
Feb 19, 2014 | Linksys Business Series WAP4400N...
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
??AP-1700 ???intel scsi? ??????4??????
looks like you need driver for your board go to asus download support type in board at search slot then download driver then install ok
Jan 05, 2011 | ASUS AP 1700 Server
Does the Symbol AP 3021 Access Point accept WPA encryption?
on the info i could find it only supports WEP.
but if your issue is to be more secure look up if it supports a sort of mac filter.
this will only keep everybody out of your router but your signal will only be WEP encrypted.
Feb 09, 2009 | Symbol Spectrum24 AP 3021 802.11b
Wlan dosent connect to net work
Make sure that your wlan is on, search your wifi ap broadcast by doble click wlan icon under the top corner desktop, double click search if wifi ap appear you can connect by doble click connect bar, if wifi have security you must write or set the security setting like wifi ap by consult with admin wifi. In order to best conection you must in range of wifi signal not so far from your ap.
Sep 26, 2008 | Sony Computers & Internet
Computers & Internet Logo
78 people viewed this question
Top Connectify Computers & Internet Experts
David Payne
David Payne
Are you a Connectify Computer and Internet Expert? Answer questions, earn points and help others
